    Padrão Arez - Como amansar esta fera?
    Amigos...
    Utilizo MK 2.9.27 e estou com um grande problema com nosso inimigo, o Arez, a luta está constante com pouco sucesso... Preciso da ajuda de todos... vamos la...
    Ah... Todas as regras aqui postadas são de ilustres amigos que colaboram com o fórum, peço desculpas eu não saber cita-los...
    Conto com a colaboração de todos...
    Tentativas de amansar a fera (Estou tão louco que bloqueando ate cliente):
    / ip firewall filter
    add chain=forward protocol=udp src-port=0 action=drop comment="wares UDP 0" \
    disabled=no
    add chain=forward protocol=udp dst-port=0 action=drop comment="" disabled=no
    add chain=forward p2p=warez action=drop comment="" disabled=no
    add chain=forward protocol=tcp src-port=135-139 action=drop comment="Dropa \
    varios Forward" disabled=no
    add chain=forward protocol=tcp src-port=445 action=drop comment="" disabled=no
    add chain=forward protocol=udp src-port=2000-65535 action=drop comment="" \
    disabled=no
    add chain=forward protocol=tcp p2p=all-p2p action=drop comment="" disabled=no
    add chain=forward protocol=udp p2p=all-p2p action=drop comment="" disabled=no
    add chain=forward src-address=192.168.21.25 protocol=tcp action=drop \
    add chain=forward src-address=192.168.21.25 protocol=udp action=drop \
    add chain=forward src-address=192.168.21.22 protocol=tcp action=drop \
    add chain=forward src-address=192.168.21.22 protocol=udp action=drop \
    Ja tentei também por marcação de pacotes...
    / ip firewall mangle
    add chain=prerouting p2p=all-p2p action=mark-connection \
    new-connection-mark=p2p_conn passthrough=yes comment="MARK P2P" \
    disabled=no
    add chain=prerouting connection-mark=p2p_conn action=mark-packet \
    new-packet-mark=p2p passthrough=yes comment="" disabled=no
    / queue tree
    add name="P2P-Down" parent=global-in packet-mark=p2p limit-at=0 queue=default \
    priority=8 max-limit=15000 burst-limit=0 burst-threshold=0 burst-time=0s \
    disabled=no
    add name="P2P-Up" parent=global-out packet-mark=p2p limit-at=0 queue=default \
    priority=8 max-limit=5000 burst-limit=0 burst-threshold=0 burst-time=0s \
    disabled=no
    Controle de Conexões Simultaneas
    add chain=forward src-address=192.168.21.0/24 protocol=tcp tcp-flags=syn \
    packet-mark=!semlimite connection-limit=20,32 action=drop \
    comment="Limitando numero conexoes simultaneas" disabled=no
    Gostaria de agradecer a todos que colaboraram com o tópico
Nome:	         Conn.JPG
Visualizações:	272
Tamanho: 	202,2 KB
ID:      	1381   Clique na imagem para uma versão maior
Nome:	         Regra.JPG
Visualizações:	241
Tamanho: 	150,2 KB
    Citação Postado originalmente por bitim Ver Post
    Amigos...
    disabled=no
    disabled=no
    disabled=no
    / queue tree
    disabled=no
    disabled=no
    Olá kara, esse assunto já foi muito discutido aqui no forum, até o momento ñ tem nenhum método eficaz para "controlar" o ares, vc poderá bloquear de vez ou então fazer o q fiz na minha rede q foi bloquear por horário pois até eu mesmo gosto de baixar algumas coisas de vez em qdo, então para ñ ter reclamação dos cliente bloqueio durante o dia até as 10 da noite e libero até as 8 da manhã....
    Padrão Faz o que eu fiz...e votará sua paz...
    Camarada é o seguinte:
    Um colega (iniciante) aqui do forum postou que descobriu um detalhe, que softwares criptografados que fazem download (P2P) precisam de portas altas para se conectar e começar os downlods, ele então bloqueou as portas TCP de 10000-65535 e as UDP a partir da 1025-65353, com isso ele descobriu que os softwares não conseguem criptografia e caem no controle p2p normal.
    Fiz o teste aqui, apliquei para rede inteira, para minha surpresa funcionou muito bem, o animal que estava acabando com a minha rede estava enjaulado agora, então pensei, não posso sacrificar a rede toda por causa de um cliente, então fui analizando as conexões das pessoas que usavam portas altas e fui aplicando a regra no ip de cada um, deixando quem não faz esse tipo de download fora dessas regras.
    Um (expert) do forum entrou no tópico e disse (NÃO FUNCIONA) então eu respondi para ele que ele não era dono do forum pra dizer se funcionava ou não ou o que tinhamos que colocar nos nossos MK ou não, putzzzzz arranjei uma briga com esse cara ( o que fez o manual).
    Mas finalizando por incrível que pareça esse pequeno detalhe que o nosso colega iniciante descobriu resolveu meu problema aqui com essas pragas, chegou de novo o sabiddão e disse ( VAI MIGRAR PARA PORTA 443 OU 80) já faz uma semana e isso não aconteceu, a rede voltou a ser o que era e agora é só elogios.
    Dê um toch nos ip's que usarem as portas altas e aplique o bloqueio a eles e verá na queue simple eles sempre ('''verdinhos).,
    Aqui resolveu...e aqui está o tópico que falei: https://under-linux.org/forums/mikro...o-tem-vez.html
    Abração e boa sorte.
    Citação Postado originalmente por Roberto21 Ver Post
    Caros amigos...
    Como podemos observar em minha regras... Mais enjaulado que isso, nao vejo como... Quanto mais eu "enjaulo" o bicho... Mais ele atenta... Sai abrindo portas aleatorias, conforme figura anexa...
    Estou bloqueando a porta 0 UDP/TCP
    disabled=no
    add chain=forward protocol=udp dst-port=1024-65535 action=drop comment="" \
    disabled=no
    E mais a regra do arez...
    Deem uma olhada em minhas regras acima...
Nome:	         Regras.JPG
Visualizações:	275
Tamanho: 	146,9 KB
    Olá camarada!!
    Fica chateado comigo não mas esse seu firewall não está bem configurado, ao menos se for a imagem anexada está faltando muita coisa além de algumas regras não estarem na sequência correta (até o das portas (0) e bloqueio do arez.
    Você não pode bloquear da porta 2000 em diante senão como o web-proxy irá funcionar?
    Mesmo sem você pedir olhe aqui, estou postando as minhas regras de firewall filter para você observar como está, e o ''''''animal'''' (eheheheh) está sobre controle...
    Para te ajudar...
    OBS: Algumas regras de filter não funcionam por completo sem as regras de mangle que possuo, principalmente as de limite de conexões, mas se você aplicar essas regras de filter e modificar os ip's para o seu range de ip's o negócio irá mudar, se precisar de ajuda para isso chama aqui...
    Abração.
    Última edição por Roberto21; 21-11-2007 às 20:48.
    Padrão bloqueio total p2p
    \ip firewall filter rules
    Chain=forward
    p2p=all-p2p
    Action=drop
    \ip firewall nat
    Chain=dstnat
    Protocol= tcp
    Dst. Port=80
    In. Interface=ether1 (interface dos clientes)
    Action=redirect
    To Ports=3128 (porta do seu webproxy)
    \ip firewall nat
    Chain=dstnat
    Protocol= tcp
    Dst. Port=500-1800
    Action=redirect
    \ip firewall nat
    Chain=dstnat
    Protocol= tcp
    Dst. Port=1900-8280
    Action=redirect
    \ip firewall nat
    Chain=dstnat
    Protocol= tcp
    Dst. Port=8300-65535
    Action=redirect
    Essas regras bloqueia bitorrent, ares, emule, etc. A questão de deixar algumas portas livres é para não bloquear o MSN, Orkut, etc.
    João Silva
    +55 61 9221-8120
    Olá camarada!!
    Para te ajudar...
    Abração.
    Roberto21,
    Poxa obrigado pela atenção, estou incluido suas regras aqui para testar... Posto depois os resultados....
    pra mim a maior dificuldade no mkt foi que o firewall dele nao tem como definir policy drop e ir liberando tudo.. entao como o tal nao tem o que precisava.. fiz o contrário.. no inicio do meu firewall tenho regras q bloqueiam portas que nao liberar... foi trabalhoso descobrir todas as portas que preciso.. mas fora isso.. tudo sob controle. so se o cara usar p2p sobre https (443) ou sobre porta http (80). as outras portas, "necatibiriba" (nada).
    no meu caso o bloqueio é total mesmo, nao é o caso de controle de banda, e sim o bloqueio definitivo. isso ai aliado a um address-list com os ips dos clientes.. fica facil controlar so os clientes e deixar sua rede interna livre de bloqueios.
    regras...
    # aqui bloqueio as portas tcp
    add chain=forward protocol=tcp dst-port=1-19 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=23-24 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=26-52 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=54-79 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=83-109 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=111-142 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=144-249 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=251-442 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=444-464 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=466-553 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=555-562 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=564-992 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=994 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=996-1321 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1323-1353 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1355-1524 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1526-1754 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1756-1862 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1864-1991 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1993-2081 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=2084-2094 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=2097-2275 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=2277-2499 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=2501-2630 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=2632-3006 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=3008-3127 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=3129-3455 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=3457-4975 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=4977-4999 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=5051-5060 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=5162-5189 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=5194-5499 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=5501-5899 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=5901-6120 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=6123-6666 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=6670-6808 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=6810-6890 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=6902-7000 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=7002-7999 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8021-8049 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8051-8079 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8081-8181 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8183-8280 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8282-8351 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8353-8359 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8366-8371 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8373-8443 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8445-8766 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=8768-8999 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=10000-28804 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=28806-31999 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=32001-65535 action=drop comment="" disabled=no
    # aqui bloqueio as portas udp
    add chain=forward protocol=udp dst-port=1-52 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=54-122 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=124-553 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=555-1064 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=1066-1321 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=1323-1862 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=1864-3006 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=3008-3579 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=3700-4999 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=5051-5060 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=5062-5189 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=5194-6890 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=6802-6900 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=6902-7000 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=7002-8351 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=8353-8359 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=8366-8999 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=10000-65535 action=drop comment="" disabled=no
    perceba que as portas que quero liberar estão fora das portas especificadas.
    neon
