ja esta no site para download
MikroTik Routers and Wireless
http://www.mikrotik.com/download/CHANGELOG_3
What's new in 3.23:
*) fixed installation on fresh disks or VMs;
*) add 802.1ad Service Tag support for VLAN;
*) wireless - fix for RTS/CTS when used together with dynamic ACK timeout;
*) serial ports are now grouped per USB device;
*) added gsm info command to ppp-client;
*) added URL support to fetch tool;
*) added dial-on-demand mode to PPTP & L2TP clients;
*) ssh - now non-interactive console commands can reference variables;
*) fixed TFTP server logging;
*) fixed problem - "/system upgrade" (autoupgrade) did not show proper package
architecture and was unable to fetch new packages;
*) fixed bug - hotspot 'walled garden ip' rules did not work on some boards
after reboot;
*) added '/interface print stats' command;
*) improved support for OSPF as PE-CE routing protocol;
*) added OSPF sham links;
*) fixed a bug in set-bgp-prepend-path routing filter;
*) fixed some MPLS TE reoptimize bugs;
*) added MPLS TE bandwidth management features;
*) netwatch - ignore items with interval 0s, this value was causing
netwatch to fail;
*) routing-test - added new type of gateway argument: ip address together with interface;
*) api - 'disabled' property was not available from api since 3.21, fixed;
*) api - added support for retrieving OID values;
*) api - removed special behaviour of 'find' command under API. Use
'print' command with queries instead of 'find'. This change fixes
scripts that are started from API and contain 'find' command.
*) console - removed support for octal numbers, now string of digits with
a leading zero is interpreted as decimal number;
*) console - added binary ~ operator that matches value against
POSIX extended regular expression;
*) console now accepts decimal numbers with k/K M G T P suffixes for
values of some properties;
*) console - fixed export problems:
if long line is wrapped just before space charater, the space character
has to be escaped, otherwise it is lost;
errors during export generated a comment line that was incorrectly enclosed
in quotes;
*) scheduler - added owner and policy properties; all existing
scheduler entries will get owner name "*sched" and policy
read,write,test;
*) routing-test - allow to specify that route gateway is in the main routing table;
*) added route cache statistics;
*) fixed mesh protocol;
*) graphing - fixed IP address mask display issue for low endian architectures;
Usando a mais de 24hrs, e me parece que esta tudo bem, parece que a resposta do web proxy esta muito mais rapida, aqui na versao 3.22 os dois hds ficavam como backup, agora ta normal, parece ou pode ser impresão mais o sinal da wireless tbm melhorou, o consumo do processador tbm esta mais baixa. Continuo monitorando...
Sera que foi resolvido o problema de controle de banda...
Boa tarde pessoal
Implantado a quase 48 horas e até agora tudo normal, aparentemente o processamento baixou, e o tempo de resposta para os clientes tambem melhorou, alem de ter corrigido um problema com quantidade de conexoes pppoe, o qual na 3.13 eu tive problemas.
O consumo de memoria aparentemente aumentou um pouco, estou monitorando, ainda é cedo para dar uma opiniao concreta, mas a primeira vista aparenta que aumentou.
Monitorando. Até o momento Estável.
alguem sabe como ultilizar configurar o auto update
para que seja automatico esse processo de atualização ?
alguem da usando hotspot nessa versão 3.23.... eu mudei pra essa versão.... e qdo eu termino a configuração do hotspot e reinicio o pc, e nao conscigo mais loga... nem aparece mais no winbox.
to usando uma placa mães asus P5PKL-AM.
Será que convém deixar de usar hotspot e trabalhar só com o queues e ip arp?
Amigo, aqui tambem não encontro ip nem mac no scaner com winbox antes de logar, deve ser alguma proteção de scan...
Se vc instalar do zero e scanear consegue encontrar o mac e ip 0.0.0.0, depois de configurada que some ao scan...
Espero ter ajudado e espero que esse não seja na verdade mais um bug no MK.
boa noite amigo + ta certo mostra o ip no winbox e n conectar!
vc so vai aparecer o ip e consegui conectar pelo winbox quando vc conectar pela tela de logim
depois q vc ter conectardor com usuario e senha ae sim vc vai conseguir conectar pelo winbox com o ip. desejo ter ajudado vlw
Hum estranho amigo eu ja usei da versao 2.7.9 ta a 3.23 q agora to usando e ta rodando perfeitamente tem q rever as configuraçoes se vcs quizer posso da uma força djacesso.net@hotmail.com vlw
Última edição por djacesso; 01-05-2009 às 15:04.
Estou com o mesmo problema com uma maquina rodando a versao 3.20, quando eu habilito o hotspot e algum usuario se autentica a maquina trava e so reiniciando.
O estranho é que eu habilito o hotspot e fica normal, so trava quando alguem loga nele.
Será que este problema foi corrigido na versao 3.23?
Aguardo retorno.
Opa amigo ae vc ta usando dhcp tb ne ae da dano conflito de ip ae o MK vai e trava eu ja passei por isso se vc quizer posso le da uma força djacesso.net@hotmail.com
