Aqui está a imagem das minhas interfaces e das minhas rotas:
O link da NET (Virtua) é através de cable modem conectado direto a RB, e pega endereço via DHCP.
Os 2 outros links (GVT) estão roteados no modem.
http://www.awgnet.com.br/Images/pcc2.jpg
				Seguem os scripts solicitados:
/ip firewall mangle
add action=mark-connection chain=input comment="" disabled=no in-interface=\
wan_gvt1 new-connection-mark=wan_gvt1_conn passthrough=yes
add action=mark-connection chain=input comment="" connection-state=new \
disabled=no in-interface=wan_net1 new-connection-mark=wan_net1_conn \
passthrough=yes
wan_gvt2 new-connection-mark=wan_gvt2_conn passthrough=yes
add action=mark-connection chain=output comment="" connection-mark=\
wan_gvt1_conn disabled=no new-connection-mark=to_wan_gvt1 passthrough=yes
wan_net1_conn connection-state=new disabled=no new-connection-mark=\
to_wan_net1 passthrough=yes
wan_gvt2_conn disabled=no new-connection-mark=to_wan_gvt2 passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=\
10.1.1.0/29 in-interface=lan
10.1.1.8/29 in-interface=lan
add action=mark-connection chain=prerouting comment="" disabled=no \
dst-address-type=!local in-interface=lan new-connection-mark=\
wan_gvt1_conn passthrough=yes per-connection-classifier=\
both-addresses:16/0
wan_gvt2_conn passthrough=yes per-connection-classifier=\
both-addresses:16/1
wan_net1_conn passthrough=yes per-connection-classifier=\
both-addresses:16/2
both-addresses:16/3
both-addresses:16/4
both-addresses:16/5
both-addresses:16/6
both-addresses:16/7
both-addresses:16/8
both-addresses:16/9
both-addresses:16/10
both-addresses:16/11
both-addresses:16/12
both-addresses:16/13
both-addresses:16/14
both-addresses:16/15
add action=mark-routing chain=prerouting comment="" connection-mark=\
wan_gvt1_conn disabled=no in-interface=lan new-routing-mark=to_wan_gvt1 \
passthrough=yes
wan_net1_conn connection-state=established disabled=no in-interface=lan \
new-routing-mark=to_wan_net1 passthrough=yes
wan_gvt2_conn disabled=no in-interface=lan new-routing-mark=to_wan_gvt2 \
passthrough=yes
/ip route
add check-gateway=ping comment="" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=10.1.1.9 routing-mark=to_wan_gvt2 scope=30 \
target-scope=10
0.0.0.0/0 gateway=189.103.80.1 routing-mark=to_wan_net1 scope=30 \
target-scope=10
0.0.0.0/0 gateway=10.1.1.1 routing-mark=to_wan_gvt1 scope=30 \
target-scope=10
add check-gateway=ping comment="" disabled=no distance=2 dst-address=\
0.0.0.0/0 gateway=10.1.1.9 scope=30 target-scope=10
0.0.0.0/0 gateway=10.1.1.1 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=3 dst-address=\
0.0.0.0/0 gateway=189.103.80.1 scope=30 target-scope=10
Agradeço antecipadamente a ajuda.
 agora ferrou de vez a cabeca
				Nao entendi nadaagora amigo aprimor, se as azuis ficam em aul pq ficam de backup, entao o balance não usa as duas entradas?? ou seja, se to em ponte e tenho 2 dsl de 2 com o balance vou ter sempre 2m e os outros 2 mg vao ficar em azul apenas pra qd o link principal cair?? confesso que to zuadao agora....deculpe, fo o que entendi
 Problema nos vídeos da globo.com
				Seguindo o modelo de regras que o tiago postou,caso alguém encontre problemas para visualizar vídeos da globo.com , segue a regra pra tirar ele fora do lb
add address=201.7.176.0/20 comment="Globo" disabled=no list=loopback
Vlws...
 Pcc fica lento
 Pcc fica lento
				ola pessoal estou fazendo implantação do pcc, so que faço a configuração seguindo esta wiki PCC - MikroTik Wiki, no meu servido proxy (mikrotik) fica mais lenta navegação.
estou colocando um link 4mb mais adsl de 4mb.
oque tenho que fazer para isso funcionar e melhorar o desenpenho?
Obrigado
				Pessoal, fiz uma balanceamento através da explicação do PCRam, só que estou com uma dúvida cruel que é a seguinte. Tenho dois velox de 01MB ligados na RB450 só que estou querendo que o mesmo manda a quantidade necessária de link para as demais portas que aqui ficaram com o padrão ether3, 4, 5. Só que fui baixar um arquivo e percebi que só estava usando um link "Velox-2" só que na verdade estou querendo que seja usado os dois simultaneamente assim terei ainda mais velocidade na navegação. Estou usando esse sistema em minha casa e quero ver como realmente funciona e o pessoal puder me ajudar eu agradeço bastante.
pelo pouco conhecimento que tenho este balanceamento não soma os links e sim divide a carga entre eles no caso de downloads ele só vai somar caso utilize algum programa de gerenciamento de downloads, um exemplo é no meu caso usando o utorrent consigo baixar a mais de 700kb/s aonde tenho virtua 1mb e 2 speedys de 2 e 4mb, caso esteja falando alguma besteira alguém me corrija.
				estou acompanhando esse post e o outro que tambem fala do pcc, e estudando os 2 estou tentando implentar aqui na minha rede,, tenho aqui 2 links, um de 256 e outo de 512.
só que quando eu coloquei o pcc pra rodar o hotspot parou, não abre mais nem a pagina de autenticação, estive olhando os conceitos do outro topico, mas não consegui achar o erro das minhas configurações, vou postar elas abaixo, para que os amigos possam me dar uma luz..
Att
Helder
Código :/ip address add address=172.16.0.254/24 broadcast=172.16.0.255 comment="Rede Local - Clientes Prefeitura" disabled=no interface="Rede Local" network=172.16.0.0 add address=189.80.16.82/29 broadcast=189.80.16.87 comment="Ip Link 256" disabled=no interface="Oi UP 256" network=189.80.16.80 add address=189.80.219.82/29 broadcast=189.80.219.87 comment="Ip Link 512" disabled=no interface="Oi UP 512" network=189.80.219.80 add address=10.10.10.1/24 broadcast=10.10.10.255 comment="Rede Local - Clientes Rua" disabled=no interface="Rede Local" network=10.10.10.0 / ip firewall mangle add chain=input in-interface="Oi UP 512" action=mark-connection new-connection-mark=Oi_UP_512_conn add chain=input in-interface="Oi UP 256" action=mark-connection new-connection-mark=Oi_UP_256_conn add chain=output connection-mark=Oi_UP_512_conn action=mark-routing new-routing-mark=to_Oi_UP_512 add chain=output connection-mark=Oi_UP_256_conn action=mark-routing new-routing-mark=to_Oi_UP_256 add chain=prerouting dst-address=189.80.219.80/29 action=accept in-interface=Rede Local add chain=prerouting dst-address=189.80.16.82/29 action=accept in-interface=Rede Local add chain=prerouting dst-address-type=!local in-interface="Rede Local" per-connection-classifier=both-addresses:2/0 \ action=mark-connection new-connection-mark=Oi_UP_512_conn passthrough=yes add chain=prerouting dst-address-type=!local in-interface="Rede Local" per-connection-classifier=both-addresses:2/1 \ action=mark-connection new-connection-mark=Oi_UP_256_conn passthrough=yes add chain=prerouting connection-mark=Oi_UP_512_conn in-interface="Rede Local" action=mark-routing new-routing-mark=to_Oi_UP_512 add chain=prerouting connection-mark=Oi_UP_256_conn in-interface="Rede Local" action=mark-routing new-routing-mark=to_Oi_UP_256 / ip route add dst-address=0.0.0.0/0 gateway=189.80.219.81 routing-mark=to_Oi_UP_512 check-gateway=ping add dst-address=0.0.0.0/0 gateway=189.80.16.81 routing-mark=to_Oi_UP_256 check-gateway=ping add dst-address=0.0.0.0/0 gateway=189.80.219.81 distance=1 check-gateway=ping add dst-address=0.0.0.0/0 gateway=189.80.16.81 distance=2 check-gateway=ping / ip firewall nat add chain=srcnat out-interface="Oi UP 512" action=masquerade add chain=srcnat out-interface="Oi UP 256" action=masquerade
Não sei se reparou se n me engano aquele outro usa-se nas regras uma opção a mais chamado connection-state=new com essa opção ativa vc pode usar o hotspot na mesma maquina do loadbalaced, mas o ideal é colocar o loadbalaced em uma maquina diferente do hotspot, mas caso n possa, utilize da forma q te disse, nas outras regras do Luciano m4d3 está para funcionar junto.
abraços
 Vídeos Terra...
 Vídeos Terra...
				No site do terra.com.br os vídeos_terra,parecem estar ok,entretanto o tv_terra da a mensagem de vídeo não encontrado.Antes eu usava o thundercache2.x e tinha que desabilitar o plugin do terra,só assim os vídeos carregavam numa boa,mesmo usando o LB por PCC.
Tiago! Experimentei usar as ranges de ip para o terra,não obtive sucesso.Mas como eu citei,parece ser o plugin do terra(Caso use o TC)....
Atualmente estou usando o TC3,vou desabilitar o plugin do terra,depois posto aqui o resultado...
t+
				A navegação ficou lenta após implantar o LB por PCC?
Reparou se a carga entre ambos estão bem divididas?
Aqui tenho uma mescla de Dedicado + DSL.Deixo os modens todos em modo bridge,assim ganho desempenho no processamento de pacotes.
Poste mais informações...
t+
				Amigos por que sera que quando deixo both-address para both-address and ports ele "soma os links" mas tem gente dizendo que ele ta dando problema com paginas...
Se eu voltar both-address ele nao "soma" PQ?
				amigo, com a opçào both-address and ports ele soma o link como vc viu, mas somente quando o cliente usa um gerenciador de download. Até a versão 3.27 tinha testado com ele e o mesmo dava algumas paginas expiradas "conexões espiradas" elas se perdiam... etc
por isso parei de usar.
Ps. so soma os links se vc usar algum gerenciador de download
