Ok Xará!!! estou esperando suas configs =)
				Amigo adptei suas regras de acordo com as qu eu faço, coloque e veja como q ficou.
detalhe, pelo que vi em suas regras posso estar enganado mas me parece q vc esta atendendo cliente nela, pq vi umas marcações de proxy ai junto, se tiver o ideal seria vc fazer o balanceamento separado dos clientes. Caso as regras n derem certo nos relate o seu problema.
Código :/ip firewall mangle add action=mark-connection chain=input comment=ether1_conn disabled=no in-interface=LINK1 new-connection-mark=ether1_conn passthrough=yes add action=mark-connection chain=input comment=ether2_conn disabled=no in-interface=LINK2 new-connection-mark=ether2_conn passthrough=yes add action=mark-routing chain=output comment=to_ether1 connection-mark=ether1_conn disabled=no new-routing-mark=to_ether1 passthrough=no add action=mark-routing chain=output comment=to_ether2 connection-mark=ether2_conn disabled=no new-routing-mark=to_ether2 passthrough=no add action=accept chain=prerouting comment="fora load DST" disabled=no dst-address-list=sem_balance in-interface=LOCAL add action=mark-connection chain=prerouting comment=ether1_conn disabled=no dst-address-type=!local in-interface=LOCAL new-connection-mark=\ ether1_conn passthrough=yes per-connection-classifier=both-addresses:2/0 add action=mark-connection chain=prerouting comment=ether2_conn disabled=no dst-address-type=!local in-interface=LOCAL new-connection-mark=\ ether2_conn passthrough=yes per-connection-classifier=both-addresses:2/1 add action=mark-routing chain=prerouting comment=to_ether1 connection-mark=ether1_conn disabled=no in-interface=LOCAL new-routing-mark=to_ether1 \ passthrough=no add action=mark-routing chain=prerouting comment=to_ether2 connection-mark=ether2_conn disabled=no in-interface=LOCAL new-routing-mark=to_ether2 \ passthrough=no /ip firewall nat add action=masquerade chain=srcnat comment=to_ether1 disabled=no out-interface=LINK1 add action=masquerade chain=srcnat comment=to_ether2 disabled=no out-interface=LINK2 /ip route add comment="BALANCEAMENTO DE CARGA - LINK1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=201.90.162.161 routing-mark=to_ether1 scope=30 target-scope=\ 10 add comment="BALANCEAMENTO DE CARGA - LINK2" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=189.22.8.1 routing-mark=to_ether2 scope=30 target-scope=10 add comment="LINK2 - TELEFONICA" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=189.22.8.1 scope=30 target-scope=10 add comment="LINK1 - EMBRATEL" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=201.90.162.161 scope=30 target-scope=10
				Vlw xará, estarei testando AGORA
Sobre o proxy, é apenas um teste, mas nao estou usando nao. pode desconsiderar.
Jaja posto o resultado
				Blz.. testado.. e infelizmente nao aprovado =/
http://img62.imageshack.us/img62/3294/95893852.png
Me diz uma coisa Xara, qual diferença do seu para a do m4d3?
E outra coisa... por que sera que continua taxando só um link?
				Aí pessoal, meu balanceamento ficou beleza agora. Tinha incluído umas regras duas vezes e agora tá beleza. Fiz também o que o Tiago Matias me orientou de colocar as interfaces EthLinkx em pppoe-outx e assim sucessivamente. Só que agora não consigo acessar de fora a máquina. Como faço para, de fora, ir direto para o ip xxxxxxxx da máquina que quero sem passar pelo balanceamento?
				CONSEGUI
Troquem de both-address para both-address and ports
PERGUNTA:
Amigos por que sera que quando deixo both-address para both-address and ports ele "soma os links" mas tem gente dizendo que ele ta dando problema com paginas...
Se eu voltar both-address ele nao "soma" PQ?
Ta ai:
http://img18.imageshack.us/img18/6820/semttulowg.png
Última edição por thiagotgc; 30-09-2009 às 17:03.
				Não pergunte a mesma coisa em topicos diferentes por favor.
sua resposta veja aqui >>> https://under-linux.org/f128610-pcc-17#post438209
Ps. se vc tivesse explicado desde o começo que queria SOMAR OS LINKS já teriamos resolvido seu problema, mas em todos os seu topicos vc so diz q não esta funcionando, e não que em um download não se soma todos os links.
Última edição por tiagomatias; 30-09-2009 às 17:27.
				Tiago, em todo momento eu disse que ele só estava carregando apenas UM(1) LINK... eu até postei imagens.
Mas td bem, o importante é que agora esta OK...
				Ajuda aí pessoal. Depois que coloquei o pcc o voip não funciona mais. Como faço para passar direto sem o pcc. E preciso também acessar de fora a maquina com o ip xxx.xx.xxx.xxx mas não tá passando pelo MK. Como faço? Ajuda aí galera.
				Sobre o VoIP eu nao sei o que voce precisa... Sobre o acesso ao MK tente isso
Isso libera acesso ao MK de qualquer IP, ou seja... modifique a regra conforme sua necessidadeadd action=accept chain=input comment="INPUT - IPs Gerenciamento -+-+-+" disabled=no src-address=0.0.0.0/0
Espero ter ajudado
				Entao eu esqueci de dizer que a regra ali eh Filte Filter
/ip firewall filter
OK?
				Parou de funcionar. Estava funcionando com a regra quando coloquei em mangle e nat, mas agora parou. Tentei incluir tb em filter como disse, mas não funcionou. Alguém pode ajudar? E sobre o voip alguém tem alguma sugestão. Ajuda aí pessoal.
				Como faço para uma requisição vinda da porta 5060-5062 sai por fora do pcc? Estava pesquisando e vi que essas portas são as usadas pelo voip. Ajuda aí. Tá difícil alguém ajudar hein.
