-  PBX IP (SIP)
					 PBX IP (SIP) PBX IP (SIP)
							Prezados,
 Tenho nos escritorios PBX IP, em todos uso RB 750G para fazer o roteamento.
 Preciso colocar estes PBX IP para se falar, eles usam protocolo SIP, ja fiz varias configuracaos e nao obtive sucesso, internamente esta tudo funcionando, somente o acesso externo que esta totalmente prejudicado.
 Vejam ai as regras e vejam se conseguem ajudar.
 aplicadas as seguintes regras
 [admin@MikroTik] > /ip firewall export
 # nov/26/2010 11:22:07 by RouterOS 4.10
 /ip firewall connection tracking
 set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
 tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
 tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
 tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
 /ip firewall nat
 add action=masquerade chain=srcnat comment="Net" disabled=no out-interface=INTERNET
 add action=dst-nat chain=dstnat comment="IIS FAT" disabled=no dst-port=83 in-interface=INTERNET \
 protocol=tcp to-addresses=192.168.10.196 to-ports=83
 add action=accept chain=dstnat comment=WINBOX disabled=no dst-port=8291 in-interface=INTERNET \
 protocol=tcp
 add action=dst-nat chain=dstnat comment="IPP SCX-4725" disabled=no dst-port=8082 in-interface=\
 INTERNET protocol=tcp to-addresses=192.168.10.10 to-ports=631
 add action=dst-nat chain=dstnat comment="IPP ML-2850" disabled=no dst-port=8081 in-interface=\
 INTERNET protocol=tcp to-addresses=192.168.10.11 to-ports=631
 add action=dst-nat chain=dstnat comment=PBX disabled=no dst-port=5060 protocol=udp to-addresses=\
 192.168.10.20 to-ports=5060
 add action=dst-nat chain=dstnat comment="WEB PBX" disabled=no dst-port=8083 in-interface=INTERNET \
 protocol=tcp to-addresses=192.168.10.20 to-ports=443
 /ip firewall service-port
 set ftp disabled=no ports=21
 set tftp disabled=no ports=69
 set irc disabled=no ports=6667
 set h323 disabled=no
 set sip disabled=no ports=5060,5061
 set pptp disabled=no
					 Re: PBX IP (SIP) Re: PBX IP (SIP)
							A NAT esta explicita no PBX IP, digo nas configurações  ??
