    Padrão Re: Compliance test para versões 5.5.9 e 5.5.10
    Acabei de enviar o email, seguindo as orientações do @UBNT-Chadi. Vamos ver se consigo alguma resposta!
    Email recebido da UBNT.
    "Hi Rafaell,
    Thanks for your reply.
    I can totally understand the trouble you're facing, but we had to remove compliance test option to shipping our products in many countries, as per the FCC regulations.
    If you could arrange the legal documents showing that you can use the compliance test option, I'll escalate your ticket to the appropriate team to assist you with the further procedure.
    Hope you understand my limitations.
    For the time, I'll set this ticket to Suspended/Close for now, but when you received any additional updates for me, please feel free to reply to this email at any time and it'll automatically reopen the ticket.
    Hope that's helpful.
    Thanks!
    Allan S.
    Ubiquiti Networks"
    outro email, @UBNT-Chadi, poderia me ajudar no preenchimento dessas informações que são solicitadas nos anexos?
Nome:	         Letter agreement re Modified Products (04mar14).pdf
Visualizações:	203
Tamanho: 	92,9 KB
ID:      	56024Acknowledgement re Modified Products (04mar14) (1).doc
    Kevin Perry (Ubiquiti Networks)
    Nov 25 10:44
    Hi Rafaell,
    Before we can send you the firmware with these frequencies we need you to fill out and sign these two documents that I've attached. We also need to ask that you not discuss or share the firmware with anyone else.
    Once you get the completed documents back to me I will then send you the firmware.
    Thanks!
    Kevin Perry
    Ubiquiti Networks"
    Citação Postado originalmente por faelldantas Ver Post
Visualizações:	203
Tamanho: 	92,9 KB
    Nov 25 10:44
    Hi Rafaell,
    Thanks!
    Kevin Perry
    Ubiquiti Networks"
    Fael é só preencher os campos como solicitado, é um formulário bem simples.
    Pede o seu nome, produto a ser modificado, quem terá acesso ao firmware, nome da sua empresa e contato.
    Att,
    Consegui fazer funcionar sem precisar resetar os rádios...
    a) Faça o Downgrade do firmware para a versão 5.3.5
    https://mega.co.nz/#!ywx2XCyY!HJNW4N...4awi8LyV2JMCRk
    b) Mude o país para Compliance Test e aplique
    c) Atualize para a versão 5.5.10
    d) Acesse o rádio por ssh e execute:
    touch /etc/persistent/ct
    save
    reboot
    Pronto seu rádio estará com compliance test ativado na versão 5.5.10...
    Aqui ficou redondinho....
    Eu estou pegando so nanoloco com esse firmware (v5.5.9 XW)! E e so acessa-lo pelo SSH e colar essa linha de comando que abilita o CT no radio.
    echo "radartool cactime 1000" > /etc/persistent/rc.poststartecho "echo '<option value=\"511\">===Compliance Test===</option>\n' >> /etc/ccodes.inc" >> /etc/persistent/rc.poststart
    chmod +x /etc/persistent/rc.poststart
    cfgmtd -w -p /etc/
    reboot
    Quando ele reinicia ja vem somente com o CT.
    @mauriciodelima, interessante....
    Já tentou somente executar os comandos diretamente na versão 5.5.10 (sem fazer o downgrade)?
    Esses comandos nada mais fazem do que criar um arquivo em branco (/etc/persistent/ct), salvar essas configurações na flash e rebotar o equipamento.
    Citação Postado originalmente por marcioelias Ver Post
    Já tentei sim, porém só funciona se o rádio já estiver em compliance test... queria saber se alguém aqui sabe como fazer um template no AirControl 2 para executar esse comando em todos os rádios ao mesmo tempo.
    Pessoal, com as orientações do @UBNT-Chadi, mandei a documentação para lá e o pessoal me respondeu e me enviou a firmware, XW 5.5.9 e XM 5.5.8 já modificada!
    Citação Postado originalmente por mauriciodelima Ver Post
    save
    reboot
    Já tinha uma nanobeam com a 5.5.10 e fiz somente o passo "d" e deu certinho!
    Obrigado!
    Fabricio
    Vou testar pra tirar as dúvidas..
    Seria (em teoria) colocar os comandos separados por ; no campo command de uma nova action a ser executada em todos os equipamentos.
    Código :
    touch /etc/persistent/ct; save; reboot
  13. #33
    Se você não conseguir. vai nesse site aqui, é o melhor.
    http://community.ubnt.com/t5/Install...-7/td-p/971089
  14. #34
    Citação Postado originalmente por gnsoares Ver Post
    Já conhecia esse site, inclusive já postei o link dele aqui em outra thread. Funciona!
  15. #35
    O mini how-to que passei se aplica a quem deseja ativar o compliance test depois de ter escolhido o país. Mas se for um rádio do zero basta executar a opção "d" antes de selecionar o país.... cara tem certas coisas que eu não entendo...
    Já tive problemas da versão 5.3.5 que vinha com menos canais, depois tiver problema com essa versão sem compliance test... to saindo fora de UBNT; a mesma putaria esta acontecendo com essas versões do mikrotik que toda hora aparece uma bug novo...
  16. #36
    Utilizando os script's mencionados, o compliance test fica liberado mas o radio cliente demora muita pra conectar (quando conecta). A solução é setar o canal manualmente na scan list, o que poderá prejudicar o bom funcionamento caso o AP precise ser mudado de canal. Alguem tem uma solução pra isso? @UBNT-Chadi,vou encaminhar a solicitação ao suporte da ubiquiti fundamentado no seu comentário. Sabe me dizer se a versão XW 5.5.10 "oficial" com CT liberado tem esse inconveniente?
  17. #37
    Citação Postado originalmente por Yuri Caitano Ver Post
    Yuri na versão oficial funciona perfeitamente !
  18. #38
    Demora por que o range de canais a serem varridos é muito grande. Use o Frequency List e defina uma lista de 4 ou mais canais tanto na AP quanto nas estações, sempre que for mudar o canal da AP mude para um dos canais da Frequency List, que em teoria todos os clientes deste AP devem ter a mesma.
  19. #39
    Opa @marcioelias, a demora é diferente, é devido ao script. Entendo que sem scan list ele vai escanear todo o range, mas isso não passa de alguns segundos, coisa de um minuto e meio no maximo. Agora demorar varios minutos ou nem conectar já é diferente. E é isso que acontece quando habilitado esses scripts. Só roda com scan list, e pequeno. Aí ficar escolhendo canal antes é latada...
  20. #40
    Cara, fiz testes aqui, pode pegar a última versão (5.5.10) acessar via SSH e rodar esse comando:
    Código :
    Pronto! Ao inicializar vc já terá todas as opções de Country Code, assim como Compliance Test e sem nenhum script mirabolante!!
    OBS: Também funciona para a 5.5.9, não testei anteriores.
