- POPFile / Postfix
POPFile / Postfix
Pessoas !!!
nao sei se alguem ja ouviuu falar sobre o POPFile, um filtro de mensagens para o postfix, algo que ajude como antispam , algo assim , tenho um servidor de email com conectiva 8/postfix
ja tentei mil e um antivirus/antispam e todos alguma coisa agarra !!! ou uma dependencia ou nem lembro mais o qnt de erro ja consegui , pede para instalar o BerkeleyDB, mas qnd rodo o
[root@blablabla]# make
gcc -c -I/usr/local/BerkeleyDB.4.6/include -fno-strict-aliasing -I/usr/include/db1 -I/usr/local/include -O2 -march=i386 -mcpu=pentiumpro -DVERSION=\"0.20\" -DXS_VERSION=\"0.20\" -fPIC -I/usr/include/gdbm -I/usr/include/db1 -I/usr/lib/perl5/5.6.1/i386-linux/CORE BerkeleyDB.c
BerkeleyDB.xs: In function `my_db_open':
BerkeleyDB.xs:1212: warning: passing arg 2 of pointer to function from incompatible pointer type
In file included from BerkeleyDB.xs:1398:
constants.h: In function `constant_15':
constants.h:2480: `DB_TXN_GETPGNOS' undeclared (first use in this function)
constants.h:2480: (Each undeclared identifier is reported only once
constants.h:2480: for each function it appears in.)
BerkeleyDB.xs: In function `XS_BerkeleyDB__Env__db_appinit':
BerkeleyDB.xs:1635: `DB_CLIENT' undeclared (first use in this function)
BerkeleyDB.xs:1701: warning: passing arg 2 of pointer to function from incompatible pointer type
BerkeleyDB.xs: In function `XS_BerkeleyDB__Hash_db_stat':
BerkeleyDB.xs:2198: warning: passing arg 2 of pointer to function from incompatible pointer type
BerkeleyDB.xs:2198: warning: passing arg 3 of pointer to function makes pointer from integer without a cast
BerkeleyDB.xs:2198: too few arguments to function
BerkeleyDB.xs: In function `XS_BerkeleyDB__Btree_db_stat':
BerkeleyDB.xs:2362: warning: passing arg 2 of pointer to function from incompatible pointer type
BerkeleyDB.xs:2362: warning: passing arg 3 of pointer to function makes pointer from integer without a cast
BerkeleyDB.xs:2362: too few arguments to function
BerkeleyDB.xs:2376: structure has no member named `bt_maxkey'
BerkeleyDB.xs: In function `XS_BerkeleyDB__Queue_db_stat':
BerkeleyDB.xs:2550: warning: passing arg 2 of pointer to function from incompatible pointer type
BerkeleyDB.xs:2550: warning: passing arg 3 of pointer to function makes pointer from integer without a cast
BerkeleyDB.xs:2550: too few arguments to function
make: *** [BerkeleyDB.o] Error 1
me aparece esse seguinte erro, ja procurei no google a noite intera e acreditem , nao achei nada sobre esse erro , nem no site do proprio Berkeley, negocio ta tenso galera
alguem por acaso tem um conectiva 8 com postfix com algum antispam , ou um programa para filtro de mensagens por cabecalho , ou corpo da mensagem , algo que possa me ajudar ?
grato
Felipe de Lima Rosa
