    Padrão O que é isso?
    Pessoal,
    acabei de colocar um server em produção, daí estou monitorando ele com maior frequência.
    Usei o comando dmesg, e ele retornou-me as seguintes mensagens:
    swapper: page allocation failure. order:1, mode:0x20
    [<c014bfb1>] __alloc_pages+0x2d1/0x2f0
    [<c0162818>] cache_alloc_refill+0x2c8/0x4f0
    [<c0161e59>] cache_flusharray+0x59/0xd0
    [<c0162aac>] __kmalloc+0x6c/0x80
    [<c03ac843>] __alloc_skb+0x53/0x110
    [<c03e4e95>] tcp_collapse+0x1a5/0x380
    [<c03e519c>] tcp_prune_queue+0x12c/0x320
    [<c03e5b9c>] tcp_data_queue+0x80c/0xc00
    [<c03c8e79>] __nf_conntrack_find+0x19/0x120
    [<c03ca4db>] nf_conntrack_in+0x27b/0x5a0
    [<c03e7686>] tcp_rcv_established+0x2a6/0x920
    [<f8a0a75b>] ipt_do_table+0x21b/0x350 [ip_tables]
    [<c03eda33>] tcp_v4_do_rcv+0xc3/0x310
    [<c03cddda>] nf_ct_deliver_cached_events+0x8a/0xa0
    [<f8a1b25b>] ipv4_confirm+0x2b/0x50 [nf_conntrack_ipv4]
    [<c03f008d>] tcp_v4_rcv+0x78d/0x930
    [<c03d2aa0>] ip_rcv_finish+0x0/0x280
    [<c03d3622>] ip_local_deliver+0x122/0x2c0
    [<c03d2d20>] ip_local_deliver_finish+0x0/0x200
    [<c03d32bc>] ip_rcv+0x2ac/0x4f0
    [<c03b0f52>] netif_receive_skb+0x232/0x310
    [<c03b2a3b>] process_backlog+0x8b/0x120
    [<c03b2c81>] net_rx_action+0xc1/0x210
    [<c0125782>] __do_softirq+0x82/0xf0
    [<c0125827>] do_softirq+0x37/0x40
    [<c0125a65>] irq_exit+0x75/0x80
    [<c0105430>] do_IRQ+0x40/0x80
    [<c054a540>] unknown_bootoption+0x0/0x250
    [<c010f8b5>] smp_apic_timer_interrupt+0x55/0x90
    [<c010346f>] common_interrupt+0x23/0x28
    [<c01017b0>] default_idle+0x0/0x40
    [<c01017df>] default_idle+0x2f/0x40
    [<c0100dcd>] cpu_idle+0x6d/0x90
    [<c054adf8>] start_kernel+0x3d8/0x4a0
    Mem-info:
    DMA per-cpu:
    CPU 0: Hot: hi: 0, btch: 1 usd: 0 Cold: hi: 0, btch: 1 usd: 0
    CPU 1: Hot: hi: 0, btch: 1 usd: 0 Cold: hi: 0, btch: 1 usd: 0
    Normal per-cpu:
    CPU 0: Hot: hi: 186, btch: 31 usd: 179 Cold: hi: 62, btch: 15 usd: 53
    CPU 1: Hot: hi: 186, btch: 31 usd: 110 Cold: hi: 62, btch: 15 usd: 58
    HighMem per-cpu:
    CPU 0: Hot: hi: 186, btch: 31 usd: 115 Cold: hi: 62, btch: 15 usd: 8
    CPU 1: Hot: hi: 186, btch: 31 usd: 162 Cold: hi: 62, btch: 15 usd: 7
    Active:255598 inactive:353568 dirty:66 writeback:0 unstable:0
    free:40777 slab:61540 mapped:1226 pagetables:149 bounce:0
    DMA free:3524kB min:68kB low:84kB high:100kB active:3496kB inactive:2192kB present:16256kB pages_scanned:0 all_unreclaimable? no
    lowmem_reserve[]: 0 873 2778
    Normal free:2184kB min:3744kB low:4680kB high:5616kB active:386316kB inactive:240216kB present:894080kB pages_scanned:0 all_unreclaimable? no
    lowmem_reserve[]: 0 0 15239
    HighMem free:157400kB min:512kB low:2556kB high:4600kB active:632580kB inactive:1171864kB present:1950660kB pages_scanned:0 all_unreclaimable? no
    lowmem_reserve[]: 0 0 0
    DMA: 82*4kB 0*8kB 0*16kB 0*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 1*2048kB 0*4096kB = 3528kB
    Normal: 372*4kB 1*8kB 1*16kB 1*32kB 0*64kB 1*128kB 0*256kB 1*512kB 0*1024kB 0*2048kB 0*4096kB = 2184kB
    HighMem: 29520*4kB 3963*8kB 250*16kB 33*32kB 4*64kB 0*128kB 3*256kB 1*512kB 1*1024kB 0*2048kB 0*4096kB = 157400kB
    Swap cache: add 703, delete 33, find 30/36, race 0+0
    Free swap = 2341232kB
    Total swap = 2343912kB
    Free swap: 2341232kB
    720880 pages of RAM
    491504 pages of HIGHMEM
    7139 reserved pages
    499477 pages shared
    670 pages swap cached
    66 pages dirty
    0 pages writeback
    1226 pages mapped
    61540 pages slab
    149 pages pagetables
    Isso pode ser algum problema?
    " swapper: page allocation failure. order:1, mode:0x20"
    Da duas uma... ou o seu servidor esta com problema na memoria, ou no disco na area de swapping. (seja ela partição ou arquivo).
    Teste primeiro a sua memoria, existem varios programas para isso, como o memtest.
    Apr 2007
    Caruaru - Pernambuco
    Submundo,
    Bom dia. Realmente o relatório informa que você está tendo problemas na alocação da swapping, ou seja, teu swap deve está em algum bad block do HD. Faça o que mistymst falou, teste primeiro a memória, depois faça alguns testes no Disco Rígido. Vou deixar em anexos dois programas para análise de memória e e HD. O que vai em imagem (.nrg) basta gravar no cd e dá o boot por ele que ele faz a varredura completa na memória e o HD Tune, é pequeno, instale e faça os testes necessários para averiguação do HD.
    Espero ter ajudado.
    Atenciosamente,
    Citação Postado originalmente por MDdantas Ver Post
    Submundo,
    Espero ter ajudado.
    Atenciosamente,
    Bom Dia MDdantas,
    Conhece algum programa que possa fazer o teste no hd ou memória com o server em produção??
