    Padrão load balance mikrotik
    GAlera é o seguinte fim o loadbalance no MK com um link dedicado + adsl brasiltelecom, so que quando coloco ele para funciona o site do Badesco nao entra da erro no gateway.
    Tirando a adsl funciona tudo ok.
    linhas de comando mikrotik
    / ip firewall mangle
    add chain=prerouting in-interface=wifi connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=odd passthrough=yes comment="LB Odd" disabled=no
    add chain=prerouting in-interface=wifi connection-mark=odd action=mark-routing new-routing-mark=odd passthrough=no comment="Odd LB" disabled=no
    add chain=prerouting in-interface=wifi connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=even passthrough=yes comment="LB Even" disabled=no
    add chain=prerouting in-interface=wifi connection-mark=even action=mark-routing new-routing-mark=even passthrough=no comment="Even LB" disabled=no
    / ip firewall nat
    add chain=srcnat connection-mark=even action=src-nat to-addresses=189.11.136.1 to-ports=0-65535 comment="LB Redirect Even" disabled=no
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=192.168.1.100 to-ports=0-65535 comment="LB Redirect Odd" disabled=no
    / ip route
    add dst-address=0.0.0.0/0 gateway=189.11.136.1 scope=255 target-scope=10 routing-mark=even comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.1.100 scope=255 target-scope=10 routing-mark=odd comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=189.11.136.1 scope=255 target-scope=10 comment="LB Route No Mark"
    Obrigado se alguem puder me ajudar
    ate mais
    Citação Postado originalmente por evertonfritz Ver Post
    / ip firewall nat
    / ip route
    ate mais
    cara balanceamento por conexao e fria......vc munda o ip no meio da transaçao bancaria ai o site do banco te kika....se tem que fazer e politica de roteamento....exemplo.....Xclientes sem pelo link dedicado...>Xclientes saem pelo adsl.....ow entao todas as portas saem pelo link1 e a porta 80 sai pelo link2...espero ter te ajudado
    Não é fria fazer isso não...
    Só precisa tratar as excessões.
    Cria algumas regras no Mangle, especificando destino do Bradesco, para sair por determinada rota (coloca ela antes das demais regras no mangle)
    Aqui utilizo isso há muito tempo, funcionando bem.
    Ah.. alem do Bradesco, tambem vai ser necessario algumas para Orkut e hotmail.
    Valeu pelas dicas.
    teria como dar um exemplor desta regra para eu fazer um teste.
    Obrigado
    ;;; Bradesco
    chain=prerouting dst-address-list=bradesco action=mark-routing new-routing-mark=bancos passthrough=no
    Obs.:
    nos Address list criei uma lista chamada bradesco, com os ips que sei do banco.
    Se quiser coloque o ip manualmente no mangle
    onde diz 'bancos' na regra acima, voce coloca o nome de uma rota que voce tenha criado lá no IP -> Routes
