pessoal desculpe pela iguinorancia...... mas tenho notado que meu web-pro nao tem funcionado ...ou funciona mas nao tem gravado no hd..... alguem poderia dar uma olhada em minhas configuraçaes para ver se esta tudo bm mesmo
aprendi a fazer um looging e observar o que tenho no hd .....mas a pagina do log quando aponto para disk ....parece vazia ....isto esta me intrigando
OBRIGADO A TODOS PELA PACIENCIA .....PAZ ......
LEMBRE-SE DEUS ESTA NO COMANDO APESAR DAS DIFICULDADES DA NOSSA VIDA ...
TErminal vt102 detected, using multiline input mode
[admin@MikroTik] > ip web
[admin@MikroTik] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 3128
hostname: "proxy"
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: "webmaster"
max-object-size: 4096KiB
cache-drive: system
max-cache-size: 10485760KiB
max-ram-cache-size: 98304KiB
status: running
reserved-for-cache: 10485760KiB
reserved-for-ram-cache: 2048KiB
[admin@MikroTik] ip web-proxy> export
# feb/09/2008 07:40:57 by RouterOS 2.9.27
# software id = Z7IJ-KSN
/ ip web-proxy
set enabled=yes src-address=0.0.0.0 port=3128 hostname="proxy" \
transparent-proxy=yes parent-proxy=0.0.0.0:0 \
cache-administrator="webmaster" max-object-size=4096KiB cache-drive=system \
max-cache-size=10485760KiB max-ram-cache-size=98304KiB
/ ip web-proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" \
disabled=no
disabled=no
add src-address=192.168.1.0/24 dst-port=80 \
url="%2e%44%4c%4c/%73%70%2e%68%74%6d%6c" action=deny comment="" \
disabled=no
url="%2e%64%6c%6c/%73%70%2e%68%74%6d%6c" action=deny comment="" \
disabled=no
url="%31%2d%73%65%2e%63%6f%6d/%68%6f%6d%65%2e%68%74%6d%6c" action=deny \
comment="" disabled=no
add src-address=192.168.1.0/24 dst-port=80 url="%62%69%67%62%72%2e%63%63" \
action=deny comment="" disabled=no
add src-address=192.168.1.0/24 dst-port=80 url="%65%68%74%74%70%2e%63%63" \
add src-address=192.168.1.0/24 dst-port=80 url="%65%68%74%74%70%2e%63%63/" \
add src-address=192.168.1.0/24 dst-port=80 url="%6e%6b%76%64%2e%75%73" \
add src-address=192.168.10.0/24 dst-port=80 \
url="%77%77%77%2e%63%6f%6f%6c%77%77%77%73%65%61%72%63%68%2e%63%6f%6d/%7a/%6\
3/%78%31%2e%63%67%69%36%35%36%33%38%37" action=deny comment="" disabled=no
url="%77%77%77%2e%65%2d%66%69%6e%64%65%72%2e%63%63" action=deny comment="" \
disabled=no
add src-address=192.168.1.0/24 dst-port=80 url=".dll/index.htm" action=deny \
add src-address=192.168.1.0/24 dst-port=80 url=".dll/sp.htm" action=deny \
add url="http*globo*get_video*" action=allow comment="Globo BBB" disabled=no
add url="http*globo*video*" action=allow comment="Globo BBB" disabled=no
add url="http*youtube*get_video*" action=allow comment="youtube" disabled=no
/ ip web-proxy cache
add url=":cgi-bin \\?" action=allow comment="don't cache dynamic http pages" \
disabled=no
disabled=no
add url=":cgi-bin \\\\?" action=allow comment="no cache dynamic http pages" \
disabled=no
add url="https://" action=allow comment="no cache dynamic https pages" \
disabled=no
Citação
