    Question Tentativa de login via SSH remota
    Está dando esta mensagem aqui em meu MK...
    Alguém pode me ajudar.
    Pelo que vejo é uma tentativa de invasão? Como posso bloquear?
    feb/25/2008 12:04:22 system,error,critical login failure for user fabio from 200.107.11.181 via ss
    h
    feb/25/2008 12:04:27 system,error,critical login failure for user fermin from 200.107.11.181 via s
    sh
    feb/25/2008 12:04:32 system,error,critical login failure for user gabino from 200.107.11.181 via s
    sh
    feb/25/2008 12:04:37 system,error,critical login failure for user genaro from 200.107.11.181 via s
    sh
    feb/25/2008 12:04:42 system,error,critical login failure for user hilaria from 200.107.11.181 via
    ssh
    feb/25/2008 12:04:47 system,error,critical login failure for user hilario from 200.107.11.181 via
    ssh
    feb/25/2008 12:04:51 system,error,critical login failure for user ignacio from 200.107.11.181 via
    ssh
    feb/25/2008 12:04:55 system,error,critical login failure for user jenaro from 200.107.11.181 via s
    sh
    Terminal vt102 detected, using multiline input mode
    [[email protected]] >
    echo: system,error,critical login failure for user juliana from 200.107.11.181 via ssh
    echo: system,error,critical login failure for user juliano from 200.107.11.181 via ssh
    Citação Postado originalmente por luock Ver Post
    Aplica essas regras aqui no seu MK>
    ip firewall filter
    add chain=input action=drop dst-port=22 protocol=tcp \
    src-address-list=black_list comment="DROP SSH BRUTE FORCE" disabled=no
    add chain=input action=add-src-to-address-list connection-state=new \
    dst-port=22 protocol=tcp src-address-list=ssh_stage3 \
    address-list=black_list address-list-timeout=1d comment="" disabled=no
    dst-port=22 protocol=tcp src-address-list=ssh_stage2 \
    address-list=ssh_stage3 address-list-timeout=1m comment="" disabled=no
    dst-port=22 protocol=tcp src-address-list=ssh_stage1 \
    address-list=ssh_stage2 address-list-timeout=1m comment="" disabled=no
    dst-port=22 protocol=tcp address-list=ssh_stage1 address-list-timeout=1m \
    Ou simplesmente mude as portas ( ip > services ).
    Ou ainda determina so pra seu range de ip interno.
    Amigo seria de mais valia ter dado o link do site onde tem essas dicas....segue abaixo:
    Bruteforce login prevention (FTP - MikroTik Wiki)
    Citação Postado originalmente por Roberto21 Ver Post
    ip firewall filter
    Padrão :D
    Agradeço a ajuda ai.
    Problema resolvido!
