  1. Toda e qualquer conexão 443 da bloqueada. e na configuração do proxy
    esta porta encontra-se em portas padrões e SSL permitidas.
    1204650138.876 10 192.168.0.22 TCP_DENIED/403 1302 CONNECT
    omega.contacts.msn.com:443 gislene.silva NONE/- text/html
    1204650138.901 1 192.168.0.22 TCP_DENIED/403 1302 CONNECT
    1204650138.914 1 192.168.0.22 TCP_DENIED/403 1302 CONNECT
    1204650138.930 1 192.168.0.22 TCP_DENIED/403 1302 CONNECT
  2. Você não tem nenhuma regra bloqueando msn?
  3. Posta ai seu firewall e nat pra gente dar uma olhada....
  4. # Do not modify '/var/ipcop/proxy/squid.conf' directly since any changes
    # you make will be overwritten whenever you resave proxy settings using the
    # web interface!
    # Instead, modify the file '/var/ipcop/proxy/advanced/acls/include.acl' and
    # then restart the proxy service using the web interface. Changes made to the
    # 'include.acl' file will propagate to the 'squid.conf' file at that time.
    shutdown_lifetime 5 seconds
    icp_port 0
    http_port 192.168.0.254:800
    cache deny QUERY
    cache_effective_user squid
    cache_effective_group squid
    umask 022
    pid_filename /var/run/squid.pid
    cache_mem 64 MB
    cache_dir aufs /var/log/cache 300 16 256
    error_directory /usr/lib/squid/advproxy/errors/Portuguese
    access_log /var/log/squid/access.log
    cache_log /var/log/squid/cache.log
    cache_store_log none
    useragent_log /var/log/squid/user_agent.log
    strip_query_terms off
    log_mime_hdrs off
    forwarded_for off
    via off
    auth_param basic program /usr/lib/squid/advproxy/auth/ncsa_auth /var/ipcop/proxy/advanced/ncsa/passwd
    auth_param basic children 5
    auth_param basic realm IPCop Advanced Proxy Server
    auth_param basic credentialsttl 60 minutes
    authenticate_ip_ttl 10 minutes
    acl for_inetusers proxy_auth REQUIRED
    acl for_extended_users proxy_auth "/var/ipcop/proxy/advanced/ncsa/extended.grp"
    acl concurrent max_user_ip -s 1
    acl with_allowed_useragents browser (MSIE.*[)]$)|(Windows\-Media\-Player)|(NSPlayer)|(Wget)|(Industry\sUpdate\sControl)|(Windows\sUpdate)|(Service\sPack\sSetup)|(Progressive\sDownload)|(Windows\-Update\-Agent)|(Microsoft\sBITS)
    acl within_timeframe time MTWHFAS 00:00-24:00
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 # https
    acl SSL_ports port 563 # snews
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl Safe_ports port 563 # snews
    acl Safe_ports port 800 # Squids port (for icons)
    acl IPCop_http port 81
    acl IPCop_https port 445
    acl IPCop_ips dst 192.168.0.254
    acl IPCop_networks src "/var/ipcop/proxy/advanced/acls/src_subnets.acl"
    acl IPCop_servers dst "/var/ipcop/proxy/advanced/acls/src_subnets.acl"
    acl IPCop_green_network src 192.168.0.0/255.255.255.0
    acl IPCop_green_servers dst 192.168.0.0/255.255.255.0
    acl CONNECT method CONNECT
    #Access to squid:
    #local machine, no restriction
    http_access allow localhost
    #GUI admin if local machine connects
    http_access allow IPCop_ips IPCop_networks IPCop_http
    http_access allow CONNECT IPCop_ips IPCop_networks IPCop_https
    #Deny not web services
    http_access deny !Safe_ports
    #Set custom configured ACLs
    http_access allow IPCop_networks for_extended_users
    http_access allow IPCop_networks for_inetusers !concurrent within_timeframe with_allowed_useragents
    http_access deny all
    #Strip HTTP Header
    header_access X-Forwarded-For deny all
    header_access Via deny all
    maximum_object_size 4096 KB
    minimum_object_size 0 KB
    request_body_max_size 0 KB
    reply_body_max_size 0 allow all
    visible_hostname IPCOP
    cache_mgr cpd@olecram.com
    url_rewrite_program /usr/sbin/squidGuard
    url_rewrite_children 5
  5. Apenas era a ordem das regras no urlfilter. a que liberava estava depois das que bloqueava a url. mais tb o reinstalei antes.
    Obrigado a todos por tentarem me ajudar
    SOU BURRO
  1. Alguém sabe....
    Por Futuremax no fórum Servidores de Rede
    Respostas: 18
    Último Post: 08-10-2004, 13:50
  2. ALguem sabe ?....
    Por nopp_lnx no fórum Servidores de Rede
    Último Post: 26-02-2003, 12:51
  3. Mensagens de retorno em português no sendmail? Alguém sabe c
    Por Ganymede no fórum Servidores de Rede
    Último Post: 25-02-2003, 09:50
  4. Alguém sabe como fazer?
    Por cristianmr no fórum Servidores de Rede
    Último Post: 27-12-2002, 08:51
  5. Alguém sabe???
    Último Post: 29-11-2002, 19:40
