    Padrão O que tem de errado neste LB
    PessoALL,
    Tenho dois Links, Dinamico X Fixo
    Os dois são Roteados da mesma Empresa, um estou usando um ROTEADOR para mudar os GW, com isso ter dois GW diferentes.
    Então estou tentando configurar minha rede dessa forma:
    /ip firewall mangle
    add chain=prerouting in-interface=GANTZM1 connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=con110 passthrough=yes comment="BALANCEAMENTO DE ROTAS"
    add chain=prerouting in-interface=GANTZM1 connection-mark=con110 action=mark-routing new-routing-mark=con110 passthrough=no
    add chain=prerouting in-interface=GANTZM2 connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=con111 passthrough=yes
    add chain=prerouting in-interface=GANTZM2 connection-mark=con111 action=mark-routing new-routing-mark=con111 passthrough=no
    /ip firewall nat
    add chain=srcnat routing-mark=con110 action=src-nat to-addresses=LINK1 disabled=no comment="NAT PARA BALANCEAMENTO"
    add chain=srcnat routing-mark=con111 action=src-nat to-addresses=LINK2 disabled=no
    /ip route
    add dst-address=0.0.0.0/0 gateway=189.1.10.1 check-gateway=arp interface=LINK1 gateway-state=reachable scope=255 target-scope=10 routing-mark=con110
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=arp interface=LINK2 gateway-state=reachable scope=255 target-scope=10 routing-mark=con111
    Ainda muito novato, estou tentando fazer por minha conta através de leituras aqui no nosso fórum.
    Agradeço a todos.
    Padrão LB
    Segue as regras com algumas alterações.. testa ai e posta o resultado pra gente:
    /ip firewall mangle
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=con110 passthrough=yes comment="BALANCEAMENTO DE ROTAS"
    add chain=prerouting in-interface=Local connection-mark=con110 action=mark-routing new-routing-mark=con110 passthrough=no
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=con111 passthrough=yes
    add chain=prerouting in-interface=Local connection-mark=con111 action=mark-routing new-routing-mark=con111 passthrough=no
    /ip firewall nat
    add chain=srcnat connection-mark=con110 action=src-nat to-addresses=189.1.10.1 to-ports=0-65535 disabled=no comment="NAT PARA BALANCEAMENTO"
    add chain=srcnat connection-mark=con111 action=src-nat to-addresses=192.168.10.1 to-ports=0-65535 disabled=no
    /ip route
    add dst-address=0.0.0.0/0 gateway=189.1.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con110
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con111
    Onde Local é a interface onde estao os clientes. Essa ultima rota é para o proprio servidor, conexoes geradas nele proprio, sem essa rota não funciona.
    Espero que resolva seu problema.. qualquer coisa post
    ATT. Gabriel Siena
    Olá gsiena, as interfaces GANTZM1 e GANTZM2 são meus cartões onde os clientes se conectam...
    Não seriam elas?
    Olá,
    Estou tentando colocar um LB para funcionar na minha rede, tenho dois links de 650k cada:
    Minha Rede:
    Range: 192.168.20.1, Interface GANTZM2 (cartão + antena)
    Range: 192.168.30.1, Interface GANTZM1 (cartão + antena)
    Link1: IP: 192.168.10.105, GW: 192.168.10.1
    Link2: IP: 189.1.10.142, GW: 189.1.10.129
    Meu LB:
    /ip firewall mangle
    add chain=prerouting in-interface=GANTZM1 connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=con110 passthrough=yes comment="BALANCEAMENTO DE ROTAS G1"
    add chain=prerouting in-interface=GANTZM1 connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=con111 passthrough=yes
    add chain=prerouting in-interface=GANTZM1 connection-mark=con111 action=mark-routing new-routing-mark=con111 passthrough=no
    add chain=prerouting in-interface=GANTZM2 connection-state=new nth=1,2,0 action=mark-connection new-connection-mark=con120 passthrough=yes comment="BALANCEAMENTO DE ROTAS G2"
    add chain=prerouting in-interface=GANTZM2 connection-mark=con120 action=mark-routing new-routing-mark=con120 passthrough=no
    add chain=prerouting in-interface=GANTZM2 connection-state=new nth=1,2,1 action=mark-connection new-connection-mark=con121 passthrough=yes
    add chain=prerouting in-interface=GANTZM2 connection-mark=con121 action=mark-routing new-routing-mark=con121 passthrough=no
    /ip firewall nat
    add chain=srcnat connection-mark=con110 action=src-nat to-addresses=192.168.10.105 to-ports=0-65535 disabled=no comment="NAT PARA BALANCEAMENTO"
    add chain=srcnat connection-mark=con111 action=src-nat to-addresses=189.1.10.142 to-ports=0-65535 disabled=no
    add chain=srcnat connection-mark=con120 action=src-nat to-addresses=192.168.10.105 to-ports=0-65535 disabled=no
    add chain=srcnat connection-mark=con121 action=src-nat to-addresses=189.1.10.142 to-ports=0-65535 disabled=no
    add chain=srcnat action=src-nat to-addresses=189.1.10.142 to-ports=0-65535 disabled=no
    /ip route
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con110
    add dst-address=0.0.0.0/0 gateway=189.1.10.129 check-gateway=ping scope=255 target-scope=10 routing-mark=con111
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con120
    add dst-address=0.0.0.0/0 gateway=189.1.10.129 check-gateway=ping scope=255 target-scope=10 routing-mark=con121
    add dst-address=0.0.0.0/0 gateway=189.1.10.129 check-gateway=ping scope=255 target-scope=10 disabled=no
    Nas imagens, aparece um desenquelibriu muito grande nos links, embora o Mangle e o NAT estejam enquilibrados:
Nome:	         interfaces.JPG
Visualizações:	340
Tamanho: 	29,8 KB
Nome:	         rotas.JPG
Visualizações:	229
Tamanho: 	39,7 KB
Nome:	         nat.JPG
Visualizações:	239
Tamanho: 	14,2 KB
Nome:	         mangle.JPG
Visualizações:	153
Tamanho: 	34,6 KB
    Como pode ter há um problema que não consigo identificar por falta mesmo de experiencia, é meu primeiro LB com ajuda do amigo mson77 os quais agradeço muito!
    Abraços!
    Padrão Load balance duas ranges
    Ola amigo, eu ainda nao tinha feito um LB com duas ranges, duas interfaces... mas vamos la, tente fazer dessa forma:
    Range: 192.168.20.0, Interface GANTZM2 (cartão + antena)
    Range: 192.168.30.0, Interface GANTZM1 (cartão + antena)
    Meu LB:
    /ip firewall mangle
    add chain=prerouting in-interface=GANTZM1 connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=con110_r1 passthrough=yes comment="BALANCEAMENTO DE ROTAS G1"
    add chain=prerouting in-interface=GANTZM1 connection-mark=con110_r1 action=mark-routing new-routing-mark=con110_r1 passthrough=no
    add chain=prerouting in-interface=GANTZM1 connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=con111_r1 passthrough=yes
    add chain=prerouting in-interface=GANTZM1 connection-mark=con111_r1 action=mark-routing new-routing-mark=con111_r1 passthrough=no
    add chain=prerouting in-interface=GANTZM2 connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=con110_r2 passthrough=yes comment="BALANCEAMENTO DE ROTAS G2"
    add chain=prerouting in-interface=GANTZM2 connection-mark=con110_r2 action=mark-routing new-routing-mark=con110_r2 passthrough=no
    add chain=prerouting in-interface=GANTZM2 connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=con111_r2 passthrough=yes
    add chain=prerouting in-interface=GANTZM2 connection-mark=con111_r2 action=mark-routing new-routing-mark=con111_r2 passthrough=no
    /ip firewall nat
    add chain=srcnat connection-mark=con110_r1 action=src-nat to-addresses=192.168.10.105 to-ports=0-65535 disabled=no comment="NAT PARA BALANCEAMENTO"
    add chain=srcnat connection-mark=con111_r1 action=src-nat to-addresses=189.1.10.142 to-ports=0-65535 disabled=no
    add chain=srcnat connection-mark=con110_r2 action=src-nat to-addresses=192.168.10.105 to-ports=0-65535 disabled=no
    add chain=srcnat connection-mark=con111_r2 action=src-nat to-addresses=189.1.10.142 to-ports=0-65535 disabled=no
    /ip route
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con110_r1
    add dst-address=0.0.0.0/0 gateway=189.1.10.129 check-gateway=ping scope=255 target-scope=10 routing-mark=con111_r1
    add dst-address=0.0.0.0/0 gateway=192.168.10.1 check-gateway=ping scope=255 target-scope=10 routing-mark=con110_r2
    add dst-address=0.0.0.0/0 gateway=189.1.10.129 check-gateway=ping scope=255 target-scope=10 routing-mark=con111_r2
    Entendeu? as configurações de NTH devem ser iguais pras duas interfaces, entao definimos o nome das connection-marks como con110_r1, con111_r1, con110_r2 e con111_r2. Esse r1 e r2 quer dizer, rede1 e rede2 ..só abreviei. Teste ai e poste os resultados!
    ATT. Gabriel Siena
    Olas....
    Gostaria de tecer 02 comentarios:
    a) As regras do GSIENA estão perfeitas... exceto quanto ao uso dos contadores. GSIENA usa o mesmo contador (id=1) para controlar balancing das 02 interfaces. A minha humilde opiniao é que deveria usar contadores com id distintos.
    b) Na tabela de roteamento do EdilsonLSouza... refiro-me a imagem postada... entendo que as regras de roteamento possuem prioridades.Creio que deva ser revisada a ordem de processamento das regras de roteamento. Minha humilde contribuição.
    Abracos,
    Min, a ordem da tabela de roteamento não muda manualmente, só clicando na coluna... acredito que não seja possível mudar as ordem.
    Padrão Funcionou o LB?
    Boa tarde caro EdilsonLSouza, só estou postando novamente pra saber se funcionou o seu LB com as regras que passei por ultimo.
    Obrigado
    Gabriel Siena
    Oi Gsiena, ajudou bastante, eu descobrir que na ultima postagem você fez certo só erro no contador, usou o mesmo contado para as duas interfaces, tipo:
    G1: 1,1,0 e 1,1,1
    G2: 1,2,0 e 1,2,0
    Só fiz modificar o contado que é a segunda casa, ai funcionou... mas parou e desconfio que esteja com a RB532 sobrecarregada, estou trocando esta semana para um PC, ai vou saber se tudo deu certo.
    Mas de qualquer forma agradeço muito mesmo.
    Citação Postado originalmente por gsiena Ver Post
    Obrigado
    Gabriel Siena
    Olá amigão... uso essas regras para balancear 2 links e funciona perfeitamente...
    Você teria ai as regras para balancear 3 links? tipo.. qual nth usar para 3 links?
    Outra coisa... agora com 3 links serial melhor continuar usando este tipo de balanceamento automatico ou na sua opiniao seria melhor eu balancear por ip ou entao por tipo de serviço?
    vlw Dr...
    abraços
