MK- MINI PCI CARD ATHEROS 54MBPS EMP-8602 PLUS-S 600MW
802.11a/b/g
Wireless Mini-PCI Adapter
EMP-8602 Plus-S
The EMP-8602 PLUS-S is a mini-PCI type
supporting dual-band (2.4GHz & 5GHz)
With the highest output power available
today in a very small form factor, EnGenius
EMP-8602 Plus-S is the perfect solution using
networking technology.
Specifications
Features:
Physical Specifications:
Environmental:
Network:
Up to 54Mbps data transfer rate
Flexible designs for embedded systems or OEM project
based applications
Fully interoperable with IEEE802.11a/b/g compliant products
Automatic data rate scaling at 54,48,36,24,18,12,11,9,6,5.5,2,1Mbps
Updated 64/128-bit WEP engine for improved throughput
Uses latest IEEE802.1x Client Support(EAP-TLS, EAP-TTLS
supplicant)
Advanced power management for extended battery life
Improved indoor multipath distortion for higher link quality in an
indoor environment
Output Power up to 28dBm in 11b/g mode, 22dBm in 11a mode
Extended tuning ranges for worldwide use and DFS/TPC for
international operation
Support for 802.11e standards for Wireless Multimedia
Enhancements QoS
Form Factor: Mini-PCI Type IIIA
Dimensions: 59.60mm X 44.45mm
Antenna Connector: 2x U.FL Connectors
Operating Voltage: 3.3V +/- 0.15V
Temperature Range:
Operating: 0ºC to 70ºC
Storage: -20ºC to 80ºC
Humidity (non-condensing):
5%~95% Typical
Compliant: FCC Part 15/UL
Media Access Protocol:
CSMA/CA
Modulation Technology: OFDM
802.11a/g: OFDM (64-QAM, 16-QAM, QPSK, BPSK)
802.11b: DSSS (DBPSK, DQPSK, CCK)
Security:
64/128-bit WEP data encryption
IEEE802.1x Client Support(EAP-TLS, EAP-TTLS supplicant)
WPA/WPA2- Wi-Fi Protected Access(64, 128-bit WEP with
TKIP/AES, Pre-Share Key)
Network Standards:
IEEE802.11a IEEE802.11b IEEE802.11g IEEE802.1x
IEEE802.11i IEEE802.11h IEEE802.1e IEEE802.1j
Radio:
Frequency Band:
802.11a:
5.15~5.35GHz,
5.47~5.725GHz, 5.725~5.825GHz
802.11b/g:
U.S., Europe and Japan product covering 2.4 to
programmable for different country regulations
Radio Type:
Direct Sequence Spread Spectrum (DSSS)
Operation Channels:
11 for North America
Receive Sensitivity (Typical):
5.15~5.82 GHz
6Mbps @ -90dBm 54Mbps @ -74dBm
2.412~2.472 G(IEEE802.11g)
6Mbps @ -92dBm 54Mbps @ -76dBm
2.412~2.472 G(IEEE802.11b)
11Mbps @ -92dBm 1Mbps @ -96dBm
Current Consumption:
Tx Current: 1A
Rx Current: 400mA
Card on Current: 400mA
Sleep Current: 100mA
Available Transmit Power *subject to country regulations*:
5.15~5.25 GHz(IEEE802.11a)
22dBm @6 ~ 24Mbps
20dBm @36Mbps
18dBm @48Mbps
17dBm @54Mbps
5.25~5.35GHz(IEEE802.11a)
20dBm @6 ~ 24Mbps
18dBm @36Mbps
16dBm @48Mbps
15dBm @54Mbps
5.500~5.700GHz(IEEE802.11a)
21dBm @6 ~ 24Mbps
19dBm @36Mbps
17dBm @48Mbps
16dBm @54Mbps
5.745~5.85GHz (IEEE802.11a)
20dBm @6 ~ 24Mbps
18dBm @36Mbps
16dBm @48Mbps
15dBm @54Mbps
2.412~2.472G(IEEE802.11g)
27dBm @6 ~ 24Mbps
[email protected]
24 [email protected]
[email protected]
2.412~2.472G(IEEE802.11b)
28dBm. @1, 2, 5.5 and 11Mbps
