    Padrão Erro ao instalar driver wireless usb EW-7318USg
    Ai pessoal BlZ!!!
    To com um problema chato aqui sou novato em linux vamos dizer que não entendo nada sobre ele então vou encher a paciencia de vcs um pouco.
    Estou tentando instalar um driver usb aqui mais to apanhando feio do fedora8.
    Abaixo vai o log do terminal se alguem puder me dar um HELP eu agradeço.
    [[email protected] ~]# cd Download
    [[email protected] Download]# tar zxvf RT73_Linux_STA_Drv1.0.4.0.tar.gz
    RT73_Linux_STA_Drv1.0.4.0/
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/defconfig
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/README
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/driver_ralink.h
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/wpa_supplicant_example.conf
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/drivers.c
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/Makefile
    RT73_Linux_STA_Drv1.0.4.0/WPA_Supplicant/driver_ralink.c
    RT73_Linux_STA_Drv1.0.4.0/Module/
    RT73_Linux_STA_Drv1.0.4.0/Module/md5.h
    RT73_Linux_STA_Drv1.0.4.0/Module/rt73.h
    RT73_Linux_STA_Drv1.0.4.0/Module/load
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_def.h
    RT73_Linux_STA_Drv1.0.4.0/Module/rtusb_data.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rtusb_io.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rt73sta.dat
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_info.c
    RT73_Linux_STA_Drv1.0.4.0/Module/license
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_wep.c
    RT73_Linux_STA_Drv1.0.4.0/Module/auth.c
    RT73_Linux_STA_Drv1.0.4.0/Module/README
    RT73_Linux_STA_Drv1.0.4.0/Module/mlme.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_main.c
    RT73_Linux_STA_Drv1.0.4.0/Module/assoc.c
    RT73_Linux_STA_Drv1.0.4.0/Module/Makefile.4
    RT73_Linux_STA_Drv1.0.4.0/Module/md5.c
    RT73_Linux_STA_Drv1.0.4.0/Module/connect.c
    RT73_Linux_STA_Drv1.0.4.0/Module/ReleaseNote
    RT73_Linux_STA_Drv1.0.4.0/Module/rt_config.h
    RT73_Linux_STA_Drv1.0.4.0/Module/wpa.h
    RT73_Linux_STA_Drv1.0.4.0/Module/auth_rsp.c
    RT73_Linux_STA_Drv1.0.4.0/Module/config.mk
    RT73_Linux_STA_Drv1.0.4.0/Module/mlme.h
    RT73_Linux_STA_Drv1.0.4.0/Module/wpa.c
    RT73_Linux_STA_Drv1.0.4.0/Module/Makefile.6
    RT73_Linux_STA_Drv1.0.4.0/Module/iwpriv_usage.txt
    RT73_Linux_STA_Drv1.0.4.0/Module/ifcfg-rausb0
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_type.h
    RT73_Linux_STA_Drv1.0.4.0/Module/unload
    RT73_Linux_STA_Drv1.0.4.0/Module/sanity.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_init.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp.h
    RT73_Linux_STA_Drv1.0.4.0/Module/rtusb_bulk.c
    RT73_Linux_STA_Drv1.0.4.0/Module/oid.h
    RT73_Linux_STA_Drv1.0.4.0/Module/rtmp_tkip.c
    RT73_Linux_STA_Drv1.0.4.0/Module/rt73.bin
    RT73_Linux_STA_Drv1.0.4.0/Module/STA_iwpriv_ATE_usage.txt
    RT73_Linux_STA_Drv1.0.4.0/Module/sync.c
    RT73_Linux_STA_Drv1.0.4.0/Module/Configure
    [[email protected] Download]# cd RT73_Linux_STA_Drv1.0.4.0
    [[email protected] RT73_Linux_STA_Drv1.0.4.0]# cd Module
    [[email protected] Module]# cp Makefile.6 ./Makefile
    cp: sobrescrever `./Makefile'? s
    [[email protected] Module]# make
    make -C /lib/modules/2.6.23.1-42.fc8/build SUBDIRS=/root/Download/RT73_Linux_STA_Drv1.0.4.0/Module modules
    make: *** /lib/modules/2.6.23.1-42.fc8/build: Arquivo ou diretório não encontrado. Pare.
    make: ** [all] Erro 2
    que distribuição você está usando?
