    Padrão Samba+AD+Debian 4.0
    nstalei o Debian 4.0 para ser servidor de arquivos e ficar integrado ao Ad do windows 2003....então segui vários tutoriais mas na hora de adicionar o servidor ao dominio dá a mensagem:
    data:/home/novaf# net ads join -U administrator
    [2008/04/07 15:23:38, 0] param/loadparm.c:set_boolean(2780)
    ERROR: Badly formed boolean in configuration file: "10.0.1.2".
    [2008/04/07 15:23:38, 0] param/loadparm.c:lp_bool(2199)
    lp_bool(10.0.1.2): value is not boolean!
    Host is not configured as a member server.
    Invalid configuration. Exiting....
    meu /etc/krb5.conf:
    [realms]
    NFAREC.LOCAL = {
    kdc = 10.0.1.2
    admin_server = 10.0.1.2
    ATHENA.MIT.EDU = {
    meu smb.conf:
    security = ADS
    password server=10.0.1.2
    realm = NFAREC.LOCAL
    #Para o ADS, e estas abaixo para o winbind:
    idmap uid = 10000-20000
    winbind gid = 10000-20000
    winbind enum users = yes
    winbind enum groups = yes
    template homedir = /tmp
    template shell = /bin/bash
    o Ip do servidor de dominio+ad: 10.0.1.2
    dominio: nfarec.local
    o que pode ser esse erro? __________________
    olha acho que resolvi....tinha ago errado no wins....mas mesmo assim quando dou o comando para adicionar aparece outra mensagem:
    data:/home/novaf# net ads join -U administrador
    e o resultado do comando:
    data:/home/novaf# testparm
    Load smb config files from /etc/samba/smb.conf
    Can't find include file /etc/samba/dhcp.conf
    params.c:Parameter() - Ignoring badly formed line in configuration file: encrypt passwords' in the smb.conf(5) manpage before enabling.
    Processing section "[homes]"
    Processing section "[printers]"
    Processing section "[print$]"
    Global parameter security found in service section!
    Global parameter password server found in service section!
    Global parameter realm found in service section!
    Global parameter idmap uid found in service section!
    Global parameter winbind gid found in service section!
    Global parameter winbind enum users found in service section!
    Global parameter winbind enum groups found in service section!
    Global parameter template homedir found in service section!
    Global parameter template shell found in service section!
    Loaded services file OK.
    Server role: ROLE_STANDALONE
    Press enter to see a dump of your service definitions
    [global]
    workgroup = NFAREC.LOCAL
    server string = %h server
    obey pam restrictions = Yes
    passdb backend = tdbsam
    passwd program = /usr/bin/passwd %u
    passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n *password\supdated\ssuccessfully* .
    syslog = 0
    log file = /var/log/samba/log.%m
    max log size = 1000
    panic action = /usr/share/samba/panic-action %d
    invalid users = root
    include = /etc/samba/dhcp.conf
    [homes]
    comment = Home Directories
    valid users = %S
    create mask = 0700
    directory mask = 0700
    browseable = No
    [printers]
    comment = All Printers
    path = /var/spool/samba
    create mask = 0700
    printable = Yes
    browseable = No
    [print$]
    comment = Printer Drivers
    já consegui resolver o problema de adicionar a máquina no domínio...estava faltando o servidor default no /etc/krb5.conf:
    que no caso era o ip do servidor pdc+AD.
    já consigo ver todos usuários e grupos do dominio:
    exemplo:
    NFAREC\gean
    NFAREC\diego
    NFAREC\rogerio
    NFAREC\junior.santos
    NFAREC\hiltevan
    NFAREC\djalma.santos
    NFAREC\preta
    NFAREC\alexsandro.silva
    NFAREC\sivaldo
    NFAREC\gerson
    NFAREC\genildo
    NFAREC\iwam_application
    NFAREC\iusr_application
    NFAREC\michael
    NFAREC\rose
    NFAREC\ademicio
    NFAREC\alisson
    NFAREC\isabela.gomes
    NFAREC\gabriela.carvalho
    e grupos tb...mas quando tento acessar a máquina samba através de uma máquina windows digitando \\10.0.1.1 ou \\data não entra...nem aparece opção de colocar usuário e senha mas consigo pingar nela mas vejo que ela nao aparece como um dominio na árvore do AD, o que pode ser? criei um compartilhamento básico para testar:
    [teste]
    comment = Diret�rio comum a todos
    path = /home/teste
    read only = no
    browseable = yes
    public = yes
    directory mask = 0770
    create mask = 0770
    Olá...
    essas duas mensagens podem ajudar!
    ainda não tive tempo de fazer esse teste aqui no meu ambiente de teste.. mas devo realizá-lo nas próximas semanas! talvez eu passe pelas mesmas dificuldades
    abraços!
