    Padrão Vgetty - Erro estranho
    Ola pessoal, alguem aqui do forum utiliza o mgetty/vgetty "SSistema de call center".
    configurei esse sistema aqui, mas ate agora não consegui deixar funcionando 100% o problema e quando o sistema atende o telefone, e nos log aparecer os defeitos rs
    ou seja ele atende e na mesma hora desliga sem deixar a pessoa ouvir as opções do menu.
    04/16 23:41:20 dem vgetty: experimental test release 0.9.32 / with duplex patch
    04/16 23:41:20 dem mgetty: interim release 1.1.35-Feb22
    04/16 23:41:20 dem reading program vgetty configuration from config file /etc/mgetty/voice.conf
    04/16 23:41:20 dem reading port modem configuration from config file /etc/mgetty/voice.conf
    04/16 23:41:20 dem check for lockfiles
    04/16 23:41:20 dem locking the line
    04/16 23:41:21 dem lowering DTR to reset Modem
    04/16 23:41:21 dem send: \dATQ0V1H0[0d]
    04/16 23:41:22 dem waiting for ``OK'' ** found **
    04/16 23:41:23 dem send: AT[0d]
    04/16 23:41:23 dem waiting for ``OK'' ** found **
    04/16 23:41:23 dem detecting voice modem type
    04/16 23:41:24 dem Rockwell detected
    04/16 23:41:25 dem initializing ROCKWELL voice modem
    04/16 23:41:25 dem vgetty: Modem returned ERROR
    04/16 23:41:25 dem can't set record gain
    04/16 23:41:26 dem waiting...
    04/16 23:42:04 dem wfr: waiting for ``RING''
    04/16 23:42:08 dem wfr: waiting for ``RING''
    04/16 23:42:13 dem wfr: waiting for ``RING''
    04/16 23:42:19 dem wfr: waiting for ``RING''
    04/16 23:42:24 dem reading ring_type ring configuration from config file /etc/mgetty/voice.conf
    04/16 23:42:25 dem vgetty: Executing shell script /usr/local/vocp/bin/vocp.pl with shell /usr/bin/perl
    04/16 23:42:25 dem vgetty: Got child -1 exit status -1 signal
    04/16 23:42:27 dem closing voice modem device
    oo doido.. tranquilo??
    o modem está retornando erro ao programa, isso que consta nos LOGs..
    já experimentou com um modem bom:??? heheheh "rockwell"???
    hehehehe
    ele nunca falou mal de alguem hehehe por isso e bom ...
    pior que pra arrumar um modem bom ISA so no museu rs....
    e pq tem que ser ISA? existem modems bons PCI.
    Win modem é lixo, tem que ser hard modem.
