    Padrão Cache-Full
    amigos estow com uma duvida que está marcado de vermelho e fiqueium pouco perdido perdido
    algem poderia dá uma olhada nessas regras e ver se ta td certinho .
    / ip firewall mangle
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes comment="Cache-squid" disabled=no
    add chain=output connection-mark=squid-connection-HIT action=mark-packet new-packet-mark=squid-packet-HIT passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=ether2 src-address=10.10.0.0/24 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" disabled=no
    add chain=forward src-address=10.10.0.0/24 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=ether1 connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT CONNECTION" disabled=no
    add chain=output out-interface=ether2 dst-address=10.10.0.0/24 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY
    disabled=no
    / queue tree
    aq tinha o nome cliente
    add name="downstream" parent=aq uso oq packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="upstream" parent=global-in packet-mark=test-up limit-at=512000 queue=default priority=1 max-limit=512000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT limit-at=2000000 queue=default priority=8 max-limit=2000000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    agradeço a todos do under sempre nos ajudando.
    Sep 2005
    Governador Valadares
    pode tirar essa linha
    Moderador Avatar de minelli
    Aug 2006
    Olá Telearconet vejo que vc tb é um dos que quer enganar seus usuarios.
    Bom por isso darei sua resposta resumidamente e restante terá de pesquisar o intem em vermelho é pra selecionar a prioridade da regra.
    o problema ñ é enganar o proposito é oferecer o melhor serviço e rapidez já q tesmos alternativas.
    como link é um pouco caro.
    Sei q essa regra faz isso mais pra quer serve essa segra
    add name="downstream" parent=global-in ou out packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    sempre tenntando aprender
    Explicar melhor a sua afirmação, de que cache-full é "enganar o cliente" minelli.
    Aug 2006
    Padrão Proxy Full
    Olá EdilsonLSouza, ñ veja a diferença:
    Ao vc habilitar o cache full o cliente verá que sua velocidade contratada continua a mesma por ex. 256k e qd faz down de algo q ñ está no cache vem a 32k, porem para que nós tenhamos a possibilidade de adquirir mais clientes com o mesmo link sem necessitar aumenta-lo então ativamos o proxy full fara uma enorme economia de banda, mas o cliente sabe que sua banda é 256 e que tem um cache e td que vem do cache vem liberado pq eu trabalho assim e explico ao cliente qd assinamos o contrato.
    Veja a diferença o que o colega acima quer é que qd o cliente entre no RJnet por ex marca uma velocidade que ñ é real, que ñ é a oferecida pelo cliente. Cada uma trabalha de uma forma, mas vai bastar 1 experto pra poder colocar um processo em qqr um que faça isso e só dividir a velocidade contratada por 8 e já se sabe a taxa de dow ou vice versa se tem a taxa de down multiplica por 8 e se tem a banda.... é só um alerta cuidado. Já vi um provedor da cidade vizinha fechar as portas por ordem juducil por causa desse motivo. É só um alerta.
    Procurem trabalhar honestamente......., é mais caro mas fale a pena.
    Talking
    Minelli, tem como vc posta suas regras d proxy? pq eu entendo como funciona mas nao sei fazer.. ou vc usa um outro servido a parte fazer este serviço? VLW
    Agradeço a resposta, mas o tópico se trada de proxy-full / cache-full? Não li sobre MEDIDORES DE VELOCIDADE, por isso fiz a pergunta, você mesmo usa profy e cache, por quê explicar o cliente que em sua maioria é um simples usuário, caso o cliente queira processar e se não estiver em contrato a tecnica de nada adianta explicar, concorda?
    Aug 2006
    Padrão Respostas
    Bom vamos lá :
    Bom como todos aqui podem perceber os nomes Proxy e Cache são usados com o mesmo objetivo ao abrirem um tópico referindo-se a mesma coisa apesar de terem diferença:
    Código :
    Na verdade o que você está falando são termos distintos, o que acontece é o seguinte:
    Proxy - Intermediário entre a net e a rede interna (ao pé da letra), entenda como um servidor(gatway) de internet para a rede interna da sua empresa. Exemplos disso são: Squid, etc.
    Cache - O cache é um armazenamento de qualquer tipo de documento (páginas da internet, arquivos, etc) para uma visualização mais rápida posteriormente. Exemplo disso: O usuário X abre a página da belladasemana. O servidor cache armazena essa página na HD para quando o usuário Y fizer a requisição da mesma página, ela não seja puxada da internet novamente, a menos que a mesma tenha sido alterada.
    Cache-Full - A mesma coisa do Cache mas vem sem limite se estiver no HD.
    O Squid (sistema de web-proxy do MK até a versão 2.9.51 pois após essa versão os desenvolvedores criaram seu proprio web-proxy ficando uma porcaria por não marcar pacoto como X-Cache: Hit...), junta os dois elementos acima, tornando-se um servidor PROXY-CACHE, ou seja: Ele é tanto um servidor de internet para a sua rede interna, como um servidor de caching de páginas visualizadas e arquivos.
    Observação: Não entenda "Servidor de internet" como servidor de algum provedor, como UOL, mas sim um gargalo de rede ou um gateway.
    Proxy transparente: Os usuários utilizam o seu proxy obrigatoriamente, sendo transferidas todas as requisições feitas com destino à porta 80 da internet para a porta 3128 (a do Web-Proxy Squid). Diz-se TRANSPARENTE pelos usuários não perceberem que eles estão utilizando o mesmo. Para ativa-lo tera que criar regras de redirecionamento.
    O colega acima está montando um devio tipo toda vez que o cliente acessar alguns medidores de velocidade ele libera a banda do restante funciona normal.
    Ao explicar aos clientes vc está sendo + que transparente apesar de varios não saberem o que é a maioria pesquisa e se informa sem contar a parte boa propagam que existe um diferencial em seu sistema em comparação a concorrencia.
    Mais duvidas mandem ai, em quanto eu souber respoder, estarei respondendo.
    Quanto as regras, são as mesma do video do Alexandre Correa.
    Citação Postado originalmente por EdilsonLSouza Ver Post
    Mineli, também não entendi o "enganar" poderia explicar?
    tbm gostaria de saber como se esta "enganando" pq
    eu fiz um desta forma e todos estão baixando na velocidade contratada mesmo e não por um "suposta velocidade mentiroza"
    a velocidade deles soma sim a quantidade normal que eu tenho
    o bom é que ganho mais uma folga nos sites somente isso
    se for errado gostaria que vc postace ai passo a passo onde estamos enganado blz
    e agradeço por tudo que for colocar aqui...
    Aug 2006
    Padrão Ultima Tentativa
    Pessoal ñ digo enganar por usarem o proxy full............
    O que digo enganar seria fazer um QOS dos pacotes com destino os sites que medem velocidade.
    Alguem entendeu o que estou querendo dizer......... gente olha as regras q ele postou.
    Padrão analizar...
    Este proxyfull esta file para ambas configuraçoes ou verçoes.
    add chain=output action=mark-connection new-connection-mark=superproxy passthrough=yes src-port=3128 protocol=tcp comment="SUPER-PROXY" disabled=no
    add chain=output action=mark-packet new-packet-mark=superproxy passthrough=yes connection-mark=superproxy comment="" disabled=no
    add chain=output action=return connection-mark=superproxy comment="" disabled=no
    /queue simple
    add name="SUPER-PROXY" target-addresses=0.0.0.0/0 dst-address=0.0.0.0/0 interface=all parent=none packet-marks=superproxy direction=both priority=8 \
    queue=default/default limit-at=0/0 max-limit=0/0 total-queue=default-small disabled=no
    / ip firewall nat
    add chain=dstnat dst-port=80 action=redirect to-ports=3128 comment="PROXY REDIRECTION" disabled=no
    Segunda opção
    MK 2.9.xx
    /ip firewall mangle
    add action=mark connection chain=output coment=X-Cache: Hit disable=no new-connection-mark=squid_hit passthrough=yes protocol=tcp src-port=3128
    add action=mark packet chain=output connection-mark=cache_hit disable=no new-packet-mark=cache full passthrough=yes
    /ip queue tree
    name=Squid parent=global-out packet-mark=cachefull queue-type=ethernet-default Priorit=8
    MK 3.x
    /ip firewall mangle
    add action=mark-connection chain=output content=!X-Cache:HIT disabled=no new-connection-mark=cache_hit passthrough=yes protocol=tcp src-port=3128
    add action=mark-packet chain=output connection-mark=cache_hit disabled=no new-packet-mark=cachefull passthrough=no
    /ip queue tree
    name=squid parent=global-out packet-mark=cachefull queue type=ethernet-default Priorit=8
    Última edição por djjean2006; 22-04-2008 às 21:09.
