Pessoal, to com um problema com smtp autenticado...nao sei porque ele sempre diz que o relay é negado...
Nos logs:
/var/log/qmail/qmail-smtp/current
@4000000048090c960b8180d4 tcpserver: status: 1/200
@4000000048090c960b81945c tcpserver: pid 3727 from 189.12.209.251
@4000000048090c960b819c2c tcpserver: ok 3727 servidor.grupoheringer.com.br:201.65.221.171:25 18912209251.user.veloxzone.com.br:189.12.209.251::1107
@4000000048090c9700b2d34c tcpserver: end 3727 status 0
@4000000048090c9700b2e2ec tcpserver: status: 0/200
Meu script do qmail-smtpd:
#!/bin/sh
QMAILDUID=`id -u vpopmail`
NOFILESGID=`id -g vpopmail`
MAXSMTPD=`cat /var/qmail/control/concurrencyincoming`
LOCAL=`head -1 /var/qmail/control/me`
if [ -z "$QMAILDUID" -o -z "$NOFILESGID" -o -z "$MAXSMTPD" -o -z "$LOCAL" ]; then
echo QMAILDUID, NOFILESGID, MAXSMTPD, or LOCAL is unset in
echo /var/qmail/supervise/qmail-smtpd/run
exit 1
fi
if [ ! -f /var/qmail/control/rcpthosts ]; then
echo "No /var/qmail/control/rcpthosts!"
echo "Refusing to start SMTP listener because it'll create an open relay"
exit 1
fi
exec /usr/local/bin/softlimit -m 2000000000 \
/usr/local/bin/tcpserver -v -R -l "$LOCAL" -x /etc/tcp.smtp.cdb -c "$MAXSMTPD" \
-u "$QMAILDUID" -g "$NOFILESGID" 0 smtp \
/var/qmail/bin/qmail-smtpd mail.grupoheringer.com.br \
/mailhome/bin/vchkpw /usr/bin/true 2>&1
Ja procurei de tudo, to quase pirando...
Alguem tem ideia?
Citação
