  1. Olá pessoal,
    possuo um note ACER ASPIRE 5710, instalei o Ubuntu 7.10 e o som nao esta funcionando...
    nao sei se é problema de driver, dando um "cat" em /proc/interrupts
    aparece isso!!
    0: 483778 0 IO-APIC-edge timer
    1: 2291 0 IO-APIC-edge i8042
    8: 49 0 IO-APIC-edge rtc
    9: 3036 0 IO-APIC-fasteoi acpi
    12: 107 0 IO-APIC-edge i8042
    14: 13972 0 IO-APIC-edge libata
    15: 0 0 IO-APIC-edge libata
    17: 24741 0 IO-APIC-fasteoi uhci_hcd:usb3, eth0
    18: 75715 0 IO-APIC-fasteoi uhci_hcd:usb2, libata, ipw3945
    19: 26 0 IO-APIC-fasteoi uhci_hcd:usb1, ehci_hcd:usb5
    20: 363884 0 IO-APIC-fasteoi uhci_hcd:usb4, i915@pci:0000:00:02.0
    21: 0 0 IO-APIC-fasteoi sdhci:slot0, sdhci:slot0
    22: 11628 0 IO-APIC-fasteoi HDA Intel
    NMI: 0 0
    o Alsa esta instalado tambem...
    se alguem puder ajudar...
    grato !!
    Everton
  2. executa os comandos abaixo e veja se reconhece o driver de som
    Código :
    update-pciids
    lspci
  3. Citação Postado originalmente por lucianogf Ver Post
    Código :
    update-pciids
    lspci
    Opa !
    fiz os comandos, e reconhece a placa, aparece o controle de volume, mas o XMMS nao toca nada, nem o Rhythmbox...
    o "lspci" retornou isso !!
    :00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
    00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
    00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
    00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
    00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 02)
    00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
    00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
    00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
    00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02)
    00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
    00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
    00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
    00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02)
    00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02)
    00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
    04:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express (rev 02)
    05:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
    06:00.0 FLASH memory: ENE Technology Inc ENE PCI Memory Stick Card Reader Controller
    06:00.1 SD Host controller: ENE Technology Inc ENE PCI SmartMedia / xD Card Reader Controller
    06:00.2 FLASH memory: ENE Technology Inc Unknown device 0720
    06:00.3 FLASH memory: ENE Technology Inc ENE PCI Secure Digital / MMC Card Reader Controller
    Everton
  4. vá nas configurações do xmms e veja como está com relação ao driver de som..
    na linha de comando tem o "play", execute-o seguido de algum arquivo de som.
    Código :
    $ play arquivo.mp3
    se não tocar é algo de errado que não está certo..
    você também pode ver no dmesg se deu algum erro no boot
    Código :
    dmesg | less
  5. Citação Postado originalmente por lucianogf Ver Post
    Código :
    $ play arquivo.mp3
    Código :
    dmesg | less
    Com o play, toca mas tambem nao sai som...
    no dmesg, nao tem nenhum erro, a nao ser a linha abaixo !
    3.104435] PCI: Using ACPI for IRQ routing
    [ 13.104437] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
    [ 13.104441] PCI: Cannot allocate resource region 7 of bridge 0000:00:1c.0
    [ 13.104499] PCI: Cannot allocate resource region 8 of bridge 0000:00:1c.0
  1. Som não funciona no Ubuntu
    Por vsrodrig no fórum Tutoriais
    Último Post: 21-03-2017, 20:56
  2. Respostas: 1
    Último Post: 05-06-2013, 21:12
  3. Som não funciona - Acer 5251/Ubuntu 10.10
    Por MsCubas no fórum Sistemas Operacionais
    Último Post: 06-05-2011, 14:45
  4. Som não Funciona - UBUNTU 8.04
    Por joelschafer no fórum Sistemas Operacionais
    Respostas: 5
    Último Post: 02-07-2008, 11:30
  5. Placa de Som nao funciona em jogos
    Por Bigode no fórum Servidores de Rede
    Respostas: 5
    Último Post: 12-06-2005, 17:11
