boa noite pessoa.. estou precisando de uma ajudinha...
estou seguindo o tutorial do patrick brandão para fazer o radius..
quando eu altero no arquivo radiusd.conf e descomento a linha SQL, ele levanta o servidor mas da um erro no LOG
Thu May 8 18:13:57 2008 : Info: Ready to process requests.
Thu May 8 18:14:30 2008 : Info: Using deprecated naslist file. Support for this will go away soon.
Thu May 8 18:14:30 2008 : Info: rlm_exec: Wait=yes but no output defined. Did you mean output=none?
Thu May 8 18:14:30 2008 : Info: rlm_eap_tls: Loading the certificate file as a chain
Thu May 8 18:14:30 2008 : Info: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
Thu May 8 18:14:30 2008 : Info: rlm_sql (sql): Attempting to connect to root@localhost:/radius
Thu May 8 18:14:30 2008 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0
Thu May 8 18:14:30 2008 : Error: rlm_sql_mysql: Couldn't connect socket to MySQL server root@localhost:radius
Thu May 8 18:14:30 2008 : Error: rlm_sql_mysql: Mysql error 'Can't connect to local MySQL server through socket '/var/lib/my
Thu May 8 18:14:30 2008 : Error: rlm_sql (sql): Failed to connect DB handle #0
Thu May 8 18:14:30 2008 : Info: Ready to process requests.
o que poderia ser...
obrigado
Citação
