    Padrão Script - iptables
    Pessoal,
    Estou postando abaixo o meu script de firewall e gostaria de uma opinião de vocês.
    #!/bin/sh
    # Definindo as variaveis.
    M1=192.168.x.y
    M2=192.168.x.y
    M3=192.168.x.y
    M4=192.168.x.y
    M5=192.168.x.y
    M6=192.168.x.y
    DG=yyy.yyy.yyy.yyy
    DNS1=aaa.aaa.aaa.aaa
    DNS2=aaa.aaa.aaa.aab
    IPT=/sbin/iptables
    FW_INT=192.168.x.y
    FW_EXT=ccc.ccc.ccc.ccc
    INT_INT=eth0
    INT_EXT=eth1
    LAN=192.168.x.y/24
    MUTLEY=192.168.x.y
    PABX=192.168.x.y
    SIP=ddd.ddd.ddd.ddd
    VPN=eee.eee.eee.eee
    # Limpando as chains.
    "$IPT" -F
    "$IPT" -X
    for tables in nat mangle filter
    do
    "$IPT" -t "$tables" -F
    "$IPT" -t "$tables" -X
    done
    # Definindo a politica padrao.
    for filter in INPUT OUTPUT FORWARD
    do
    "$IPT" -P "$filter" DROP
    done
    # Protecao contra IP spoofing.
    "$IPT" -A INPUT -s "$LAN" -i ! "$INT_INT" -j DROP
    "$IPT" -A INPUT -s ! "$LAN" -i "$INT_INT" -j DROP
    # Stateful.
    "$IPT" -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    "$IPT" -A OUTPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    "$IPT" -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
    # Tabela NAT
    # Liberando conexao no PABX.
    "$IPT" -t nat -A PREROUTING -s "$DG" -d "$FW_EXT" --dport 987 -j DNAT --to "$PABX"
    "$IPT" -t nat -A PREROUTING -s "$DG" -d "$FW_EXT" --dport 22 -j DNAT --to "$PABX"
    # Compartilhando Internet.
    "$IPT" -t nat -A POSTROUTING -s "$LAN" -i "$INT_INT" -j MASQUERADE
    # Chain INPUT
    # Liberando trafego na interface de loopback.
    "$IPT" -A INPUT -i lo -j ACCEPT
    # Liberando ssh.
    for micro_ssh in "$M5" "$MUTLEY"
    do
    "$IPT" -A INPUT -s "$micro_ssh" -i "$INT_INT" -p tcp --dport 22 -j ACCEPT
    done
    # Liberando icmp.
    for icmp_type in echo-reply echo-request
    do
    "$IPT" -A INPUT -s "$LAN" -i "$INT_INT" -p icmp --icmp-type "$icmp_type" -j ACCEPT
    done
    # Chain OUTPUT
    "$IPT" -A OUTPUT -o lo -j ACCEPT
    # Liberando icmp.
    do
    "$IPT" -A OUTPUT -d "$LAN" -o "$INT_INT" -p icmp --icmp-type "$icmp_type" -j ACCEPT
    done
    # Liberando dns.
    for dns in "$DNS1" "$DNS2"
    do
    "$IPT" -A OUTPUT -d "$dns" -o "$INT_EXT" -p tcp --dport 53 -j ACCEPT
    "$IPT" -A OUTPUT -d "$dns" -o "$INT_EXT" -p udp --dport 53 -j ACCEPT
    done
    # Chain FORWARD
    # Liberando comunicacao entre o PABX e o servidor SIP.
    "$IPT" -A FORWARD -s "$PABX" -i "$INT_INT" -d "$SIP" -p udp --dport 1024:65535 -j ACCEPT
    # Liberando a VPN.
    for am in "$M1" "$M2" "$M3" "$M4" "$M5" "$M6"
    do
    "$IPT" -A FORWARD -s "$am" -i "$INT_INT" -d "$VPN" -p tcp -m multiport --dport 500,4500 -j ACCEPT
    "$IPT" -A FORWARD -s "$am" -i "$INT_INT" -d "$VPN" -p udp -m multiport --dport 500,4500 -j ACCEPT
    done
    # Liberando dns.
    for micros in "$M1" "$M2" "$M3" "$M4" "$M5" "$M6" "$MUTLEY"
    do
    "$IPT" -A FORWARD -s "$micros" -i "$INT_INT" -d "$DNS1" -p tcp --dport 53 -j ACCEPT
    "$IPT" -A FORWARD -s "$micros" -i "$INT_INT" -d "$DNS1" -p udp --dport 53 -j ACCEPT
    "$IPT" -A FORWARD -s "$micros" -i "$INT_INT" -d "$DNS2" -p tcp --dport 53 -j ACCEPT
    "$IPT" -A FORWARD -s "$micros" -i "$INT_INT" -d "$DNS2" -p udp --dport 53 -j ACCEPT
    done
    "$IPT" -A FORWARD -d "$PABX" -p tcp --dport 22 -j ACCEPT
    "$IPT" -A FORWARD -d "$PABX" -p tcp --dport 987 -j ACCEPT
    "$IPT" -A FORWARD -d "$PABX" -p udp --dport 987 -j ACCEPT
    opinião com relação a quê??
