    Thumbs up Proxim Tsunami MP.11a: disminuir latencia
    o pessoal que tem Tsunami MP.11a, tem como disminuir a latencia de ping q é um pouco elevado com trafego.
    http://support.proxim.com/cgi-bin/proxim.cfg/php/enduser/std_adp.php?p_faqid=2774&p_created=1210782500&p_sid=7lptNH4j&p_accessibility=0&p_redirect=&p_lva=2363&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xMTQ2LDExNDYmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=&p_topview=1
    1- From the WORP-Base of your MP.11/ QB.11 radio, go to ConfigureQoSQoS SF Class and you will see that the default setting for UL-Unlimited BE and DL-Unlimited BE for Latency (ms) is set to 20 as shown.
    http://proximtechnicalservice.com/su...s-sf-class.jpg
    2- Select the Edit/Delete Table Entries radio button and change the Lat(ms) parameter for UL-Unlimited BE and DL-Unlimited BE from 20 to 5 as shown.
    http://proximtechnicalservice.com/su...class-edit.jpg
    3- Click OK and the change should take effect immediately. You will need to Reboot via the Commands tab to permanently save this change.
    IMPORTANT: If you are only sending short packets across your wireless link, then please do not modify the latency, since this will result in a loss of throughput.
    ah lembrando q estou convertendo desde AP-600a, RSU e SU para BSU.
    tambem habilito todos os canais.
    Lee
Nome:	         MP_11a-4_0.gif
Visualizações:	239
Tamanho: 	47,0 KB
