    Padrão como desligar mensagens do audit no console e no syslog
    Alguem ai sabe como desligar isso ?
    Código :
    Jun  4 05:31:01 california kernel: [5378901.231039] audit(1212568261.812:1107874): login pid=8403 uid=0 old auid=4294967295 new auid=0
    Jun  4 05:31:01 california kernel: [5378901.236633] audit(1212568261.818:1107875): user pid=8403 uid=0 auid=0 msg='PAM: session open acct="root" : exe="/usr/sbin/crond" (hostname=?, addr=?, terminal=cron res=success)'
    Jun  4 05:31:05 california kernel: [5378905.345380] audit(1212568265.933:1107876): user pid=7904 uid=0 auid=0 msg='PAM: setcred acct="root" : exe="/usr/sbin/crond" (hostname=?, addr=?, terminal=cron res=success)'
    Jun  4 05:31:05 california kernel: [5378905.346431] audit(1212568265.935:1107877): user pid=7904 uid=0 auid=0 msg='PAM: session close acct="root" : exe="/usr/sbin/crond" (hostname=?, addr=?, terminal=cron res=success)'
    Jun  4 05:31:14 california kernel: [5378914.210201] audit(1212568274.812:1107878): user pid=7902 uid=0 auid=0 msg='PAM: setcred acct="root" : exe="/usr/sbin/crond" (hostname=?, addr=?, terminal=cron res=success)'
    Jun  4 05:31:14 california kernel: [5378914.211438] audit(1212568274.813:1107879): user pid=7902 uid=0 auid=0 msg='PAM: session close acct="root" : exe="/usr/sbin/crond" (hostname=?, addr=?, terminal=cron res=success)'
    remotamente via ssh, nao atrapalha.. mas .. quando mexendo localmente, esse negocio enche o saco !!!
    se alguem souber como desliga isso .. por favor me ajuda !!!
    Arrow
    Dando uma olhada na net.
    Achei alguns posts que atrelavam esse problema ao SElinux.
    Cs 1.6 Server Red Hat - Lafox.Net Forum
    'Re: [PATCH] refpolicy: apps_vmware changes' - MARC
    Re: SOLVED: error ClamAV daemon
    Ab, Duca.
    tudo q eu faço nao resolve uhauhauhauhhuauhahu
    ja ateh matei o processo pelo kill .. mas continua uhauhahu
    eu to achando que alguma coisa do audit foi embutida no kernel :P
    pq até o timespam dos logs mudou
    [5429843.413469]
    heheh
    fiz ate
    rpm -e audit-1.5.5-7.el5
    massssssss continua.. hahua misterioooooooo
    valew pelos links..
    vou tentar recompilar o kernel e procurar algo com audit ..
    Padrão Use o dmesg
    Para parar com o audit na console faça:
    dmesg -n 2
    []s
