Página 1 de 42 123456 ... ÚltimoÚltimo
    Padrão squid - configurações de url_rewrite
    pessoal estou com MUITO cache MISS no orkut
    por mais que recarregue por varias vezes a mesma pagina...
    já tentei varios parametros de refresh pattern
    e nada
    tipo olhem esse exemplo:
    http://img2.orkut.com/images/milieu/...jpg?sig=2amsed
    e
    http://img4.orkut.com/images/milieu/...jpg?sig=2amsed
    é a mesma imagem so muda o imgX.orkut
    tentei usar o store rewrite mais nao tive sucesso!
    queria quebrar o link em img[0-9].orkut
    alguem sabe faze isso?!
    Alexandre?!??! heheheh
    Abraços!!
    /Z21cfz1.jpg?sig=1r0f1lw - DIRECT/209.85.193.94 image/jpeg
    1215401349.302 91 189.10.203.20 TCP_MISS/200 7612 GET http://img4.orkut.com/images/milieu/...jpg?sig=efkiqm - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.304 77 189.10.203.20 TCP_MISS/200 6790 GET http://img4.orkut.com/images/milieu/...pg?sig=1r0f1lw - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.387 244 127.0.0.1 TCP_MISS/200 6610 GET http://img3.orkut.com/images/milieu/...pg?sig=11hfjje - DIRECT/64.233.179.85 image/jpeg
    1215401349.389 247 189.10.203.20 TCP_MISS/200 6725 GET http://img3.orkut.com/images/milieu/...pg?sig=11hfjje - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.402 215 127.0.0.1 TCP_MISS/200 5559 GET http://img1.orkut.com/images/milieu/...pg?sig=1idcj27 - DIRECT/209.85.193.87 image/jpeg
    1215401349.404 219 189.10.203.20 TCP_MISS/200 5674 GET http://img1.orkut.com/images/milieu/...pg?sig=1idcj27 - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.426 236 127.0.0.1 TCP_MISS/200 5607 GET http://img3.orkut.com/images/milieu/...jpg?sig=y3kazm - DIRECT/64.233.179.85 image/jpeg
    1215401349.429 242 189.10.203.20 TCP_MISS/200 5722 GET http://img3.orkut.com/images/milieu/...jpg?sig=y3kazm - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.446 219 127.0.0.1 TCP_MISS/200 5830 GET http://img1.orkut.com/images/milieu/...pg?sig=1bayv6t - DIRECT/209.85.193.86 image/jpeg
    1215401349.448 223 189.10.203.20 TCP_MISS/200 5945 GET http://img1.orkut.com/images/milieu/...pg?sig=1bayv6t - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.584 407 127.0.0.1 TCP_MISS/200 6270 GET http://img3.orkut.com/images/milieu/...jpg?sig=7w7awl - DIRECT/64.233.179.86 image/jpeg
    1215401349.586 411 189.10.203.20 TCP_MISS/200 6385 GET http://img3.orkut.com/images/milieu/...jpg?sig=7w7awl - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401349.609 409 127.0.0.1 TCP_MISS/200 12488 GET http://img4.orkut.com/images/milieu/...pg?sig=1oriumw - DIRECT/64.233.179.86 image/jpeg
    1215401349.656 472 127.0.0.1 TCP_MISS/200 8192 GET http://img4.orkut.com/images/milieu/...jpg?sig=20fjzh - DIRECT/64.233.179.85 image/jpeg
    1215401349.795 615 189.10.203.20 TCP_MISS/200 8307 GET http://img4.orkut.com/images/milieu/...jpg?sig=20fjzh - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401350.332 1137 189.10.203.20 TCP_MISS/200 12603 GET http://img4.orkut.com/images/milieu/...pg?sig=1oriumw - DEFAULT_PARENT/127.0.0.1 image/jpeg
    1215401350.569 391 127.0.0.1 TCP_MISS/200 11003 GET http://www.orkut.com.br/Home.aspx - DIRECT/209.85.193.94 text/html
    1215401351.537 471 127.0.0.1 TCP_MISS/200 9153 GET http://img4.orkut.com/images/milieu/...jpg?sig=2amsed - DIRECT/64.233.179.85 image/jpeg
    Arium,
    o campo onde está o TCP_MISS/200 é o campo do log onde aparece o status HTTP da página acessada. Este status 200, segundo a especificação do protocolo HTTP quer dizer que a página foi acessada e recuperada sem erro. Dentre outros status possíveis temos 302, redirecionado temporariamente; 404, página não encontrada; 500, erro interno do servidor, e vários outros.
    O que você tem que procurar, quando olhando o access.log do squid é o campo onde tem as informações DIRECT/209.85.193.94, que quer dizer que ele acessou a página diretamente e DEFAULT_PARENT/127.0.0.1, que diz que ele foi buscar o objeto no cache.
    O Orkut, bem como outras páginas dinâmicas na Internet, usam cabeçalho de no-cache, que é respeitado pelo Squid para garantir que a página esteja sempre atualizada.
    desculpa amigo acho que nao fui claro!
    o que botei o lance ali apenas como exemplo..
    na realidade o que eu quero é saber o usar o store rewrite ou alguma forma de transformar
    img2.orkut.com.br, img3.orkut.com.br , img4.orkut.com.br, im5g.orkut.com.br enfim imgX.orkut.com tudo em im1.orkut.com.br afim de facilitar a guarda no cache e ter mais sucessos no hit!
    Bom vo me intrometer, ariun vc nao entendeu, mais ele esta falando que nao esta sendo feito cache destas paginas, o pessoal do google usa um comando
    Response.AddHeader "PRAGMA", "NO-CACHE"
    assim o squid nao faz cache com elas, vc pode usar o comando
    response.expiresAbsolute=dateAdd("yyyy",1,now) 'vencera dentro de um ano
    Assim o squid guarda ela um ano, os padroes ajudao muito a vc controlar a acesso a seu site mesmo com o cliente usando cache, o pessoal do google ta fazendo isso, e se vc tentar burlar isso pode ter problemas de recaregamento de fotos erradas, que foi justamente o problema que levou eles a fazerem estas configuraçoes!
    Desculpe por nao te ajudar!
    tudo bem mais eu soh quero aprender a fazer redirecionamento heheheheh
    quanto esse comando:
    response.expiresAbsolute=dateAdd("y yyy",1,now)
    eu desconhecia! li o manual do squid não encontrei
    como faço pra usa-lo? é interessante em algumas ocasiões
    esse comando é, na verdade, uma parâmetro de uma página em ASP. É a mesma coisa de você usar o Header no PHP ou setar um cookie para expirar dentro de um ano usando javascript.
    o store_rewrite que você está procurando, na verdade é o url_rewrite e seus parâmetros subsequentes. Você vai precisar de um programa externo ao Squid para fazer o rewrite das urls, eu sinceramente não conheço nenhum e não acho que valeria a pena por questões de performance.
