    Moderador Avatar de minelli
    Aug 2006
    Padrão What's new in 3.11
    What's new in 3.11:
    *) fixed bug - in some cases web proxy https with parent-proxy did not work;
    *) added default-route-distance setting for DHCP client;
    *) mesh protocol - bridge interface in a mesh did not work well, fixed;
    *) multicast - fixed bootstrap router (BSR) mechanism;
    *) user manager - users can now be redirected to HotSpot login page after
    PayPal payment;
    *) added ability to dst. nat only address or port, not both at the same time;
    *) ospf - fixed default route;
    *) ipsec - fixed tunnel mode with dynamically generated policy;
    *) port remote-access - fixed allowed-addresses check;
    *) ethernet half duplex modes on rb400 series work now;
    *) console - fixed entering of IPv6 prefixes;
    *) console - fixed crash on window size change;
    *) console - bit operations (& ^ | << >>) now work with numbers, too;
    *) console - brace syntax for array declarations ( { value ; value ; value } )
    now can be used also where () expressions can be used, previously
    worked only inside the expressions. Example:
    :foreach i in {1;2;3;4} do={ut $i}
    *) console - inside expressions ',' operator can be used to concatenate arrays,
    unlike '.' which works with strings. Arguments that are not arrays are
    treated like arrays with single element. Example:
    {1,2,3;4,5,6;7,8,9} produces value {{1;2;3};{4;5;6};{7;8;9}}
    (1,{2},{{3;4}},5,{},{6,7},8) produces value {1;2;{3;4};5;{6;7},8}
    *) console - 'move' commands no allow list of source items to be empty and
    to contain duplicate items. The porpose is to simplify scripts that use
    'find' commands to move items. Example:
    move ([find dynamic],[find inactive]) - moves all 'dynamic' and
    'inactive' items to the end of the list, does not raise error if
    any item is both 'dynamic' and 'inactive', or if there are no items;
    *) console - 'move' command does not update item numbers anymore;
    PayPal payment;
    Isso eh bom ! Será ???
    Quem será o primeiro a testar ????
    Última edição por admskill; 09-07-2008 às 00:48.
    Aug 2007
    São Paulo, Brazil, Brazil
    Citação Postado originalmente por minelli Ver Post
    What's new in 3.11:
    PayPal payment;
    Foi mau mais nao entendi nada
    hauhaua
    Vou postar, quero ver os comentarios sobre essa versão do MK.
    eu ja estou testando o versao 3.11 , qualquer novidade posto aki para compartilhar com os amigos
    por favor edielson, me mande boas noticias do Sr. Webproxy !
