  1. olha só pessoal:
    1215614161.525 3 189.10.203.25 TCP_OFFLINE_HIT/200 459 GET http://download966.avast.com/iavs4x/....def.vpu.stamp - NONE/- application/octet-stream
    1215614167.713 18 189.10.203.25 TCP_OFFLINE_HIT/200 459 GET http://download631.avast.com/iavs4x/..._pro.vpu.stamp - NONE/- application/octet-stream
    1215614168.292 509 189.10.203.25 TCP_MISS/200 993 GET http://download631.avast.com/iavs4x/prod-av_pro.vpu - DIRECT/74.55.74.106 application/octet-stream
    1215614190.682 24 189.10.203.25 TCP_OFFLINE_HIT/200 459 GET http://download970.avast.com/iavs4x/....def.vpu.stamp - NONE/- application/octet-stream
    1215614200.951 2 189.10.203.25 TCP_OFFLINE_HIT/200 457 GET http://download616.avast.com/iavs4x/..._pro.vpu.stamp - NONE/- application/octet-stream
    1215614201.026 38 189.10.203.25 TCP_OFFLINE_HIT/200 1098 GET http://download616.avast.com/iavs4x/prod-av_pro.vpu - NONE/- application/octet-stream
    1215614201.145 1 189.10.203.25 TCP_OFFLINE_HIT/200 1115 GET http://download616.avast.com/iavs4x/...ps-8062601.vpu - NONE/- application/octet-stream
    1215614202.007 714 189.10.203.25 TCP_MISS/404 587 GET http://download616.avast.com/iavs4x/vps-8062600.vpu - DIRECT/75.125.246.130 text/html
    1215614203.034 765 189.10.203.25 TCP_MISS/404 587 GET http://download504.avast.com/iavs4x/vps-8062600.vpu - DIRECT/75.126.53.170 text/html
    1215614203.782 469 189.10.203.25 TCP_MISS/404 587 GET http://download959.avast.com/iavs4x/vps-8062600.vpu - DIRECT/74.86.232.39 text/html
    1215614235.293 750 189.10.203.25 TCP_MISS/204 243 POST http://download676.avast.com/cgi-bin/iavs4stats.cgi - DIRECT/74.52.200.130 text/plain
    nada de atualizar!!!
    dah erro 403, 404 tudo que é tipo!
    unico trem que to usando é esse:
    refresh_pattern avast.com/.*\.(def|vpu|vpaa|stamp|cgi) 43200 100% 43200 reload-into-ims
    ideias?
    já fiz teste com always_direct tbm nao brilhou
  2. Nessas horas vale apena "tirar esse IP de destino do squid".
    Põe uma regra de iptables pro destino como accept, dessa forma o tráfego não passa pelo squid...
    Última edição por Magnun; 09-07-2008 às 14:57.
  3. mais ai nao cacheia tbm heheheh
  4. Esse é um problema... Não tinha percebido que seu objetivo era o chache... foi mal...
    Às vezes é melhor não ter cache do que não ter atualização
    Já verificou se ele abre somente a porta 80 pra isso?? Talvez esteja faltando redirecionar mais alguma coisa...
  5. só 80 e nao tenho nada bloqueado :/
  1. Windows Vista SPK1 não acessa Através de Proxy Transparente!
    Por slipbad no fórum Servidores de Rede
    Respostas: 16
    Último Post: 25-08-2008, 08:29
  2. Conectividade Social Através de Proxy Transparente no Suse 9.3
    Por elcinfo no fórum Sistemas Operacionais
    Último Post: 12-03-2006, 08:42
  3. Respostas: 0
    Último Post: 31-07-2003, 13:22
  4. Usar Squid atraves de outro Proxy
    Por lucianotome no fórum Servidores de Rede
    Último Post: 20-05-2003, 10:24
