estou com debian lenny com o proftpd mas não consigo colocar ele para rodar..no começo até consegui colocar algum arquivo na pasta dando upload mas não conseguia fazer um download do site ftp...fui mexendo e a coisa piorou, agora não consigo mais acessar a minha pasta no /home/ftp/fernando olhem o log:
Aug 02 14:45:40 debian proftpd[4539] localhost (192.168.0.101[192.168.0.101]): USER anonymous: no such user found from 192.168.0.101 [192.168.0.101] to 192.168.0.200:2121
Aug 02 14:45:43 debian proftpd[4539] localhost (192.168.0.101[192.168.0.101]): FTP session closed.
Aug 02 14:46:04 debian proftpd[4540] localhost (192.168.0.101[192.168.0.101]): FTP session opened.
Aug 02 14:46:04 debian proftpd[4540] localhost (192.168.0.101[192.168.0.101]): USER fernando: Login successful.
Aug 02 17:46:04 debian proftpd[4540] localhost (192.168.0.101[192.168.0.101]): Preparing to chroot to directory '/home/ftp/fernando'
Aug 02 17:46:19 debian proftpd[4472] localhost (192.168.0.101[192.168.0.101]): Data transfer stall timeout: 600 seconds
Aug 02 17:46:19 debian proftpd[4472] localhost (192.168.0.101[192.168.0.101]): FTP session closed.
Aug 02 17:46:41 debian proftpd[4487] localhost (192.168.0.101[192.168.0.101]): Data transfer stall timeout: 600 seconds
Aug 02 17:46:41 debian proftpd[4487] localhost (192.168.0.101[192.168.0.101]): FTP session closed.
^C
a sessão fica fechando o que pode ser?
segue meu proftpd.conf:
# /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
# Includes DSO modules
Include /etc/proftpd/modules.conf
# Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 on
# If set on you can experience a longer connection delay in many cases.
IdentLookups off
UseIPv6 off
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayChdir .message true
ListOptions "-l"
DenyFilter \*.*/
# Use this to jail all users in their homes
DefaultRoot ~
# Users require a valid shell listed in /etc/shells to login.
# Use this directive to release that constrain.
RequireValidShell on
# Port 21 is the standard FTP port.
Port 2121
# In some cases you have to specify passive ports range to by-pass
# firewall limitations. Ephemeral ports can be used for that, but
# feel free to use a more narrow range.
PassivePorts 49152 65534
# If your host was NATted, this option is useful in order to
# allow passive tranfers to work. You have to use your public
# address and opening the passive ports used on your firewall as well.
MasqueradeAddress fernandogalvao.homelinux.com
# This is useful for masquerading address with dynamic IPs:
# refresh any configured MasqueradeAddress directives every 8 hours
<IfModule mod_dynmasq.c>
# DynMasqRefresh 28800
</IfModule>
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User proftpd
Group nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask 022 022
# Normally, we want files to be overwriteable.
AllowOverwrite on
# Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
# PersistentPasswd off
# This is required to use both PAM-based authentication and local passwords
# AuthOrder *mod_auth_pam.c mod_auth_unix.c
# Be warned: use of this directive impacts CPU average load!
# Uncomment this if you like to see progress and transfer rate with ftpwho
# in downloads. That is not needed for uploads rates.
# UseSendFile off
# Choose a SQL backend among MySQL or PostgreSQL.
# Both modules are loaded in default configuration, so you have to specify the backend
# or comment out the unused module in /etc/proftpd/modules.conf.
# Use 'mysql' or 'postgres' as possible values.
#<IfModule mod_sql.c>
# SQLBackend mysql
#</IfModule>
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
<IfModule mod_quotatab.c>
QuotaEngine off
</IfModule>
<IfModule mod_ratio.c>
Ratios off
</IfModule>
# Delay engine reduces impact of the so-called Timing Attack described in
# [ LSS | Security | eXposed by LSS | Detalji ]
# It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine off
ControlsMaxClients 2
ControlsLog /var/log/proftpd/controls.log
ControlsInterval 5
ControlsSocket /var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine off
</IfModule>
# Alternative authentication frameworks
#Include /etc/proftpd/ldap.conf
#Include /etc/proftpd/sql.conf
# This is used for FTPS connections
#Include /etc/proftpd/tls.conf
# A basic anonymous configuration, no upload directories.
#<Anonymous ~ftp>
# User ftp
# Group nogroup
# # We want clients to be able to login with "anonymous" as well as "ftp"
# UserAlias anonymous ftp
# # Cosmetic changes, all files belongs to ftp user
# DirFakeUser on ftp
# DirFakeGroup on ftp
# RequireValidShell off
# # Limit the maximum number of anonymous logins
# MaxClients 10
# # We want 'welcome.msg' displayed at login, and '.message' displayed
# # in each newly chdired directory.
# DisplayLogin welcome.msg
# DisplayFirstChdir .message
# # Limit WRITE everywhere in the anonymous chroot
# <Directory *>
# <Limit WRITE>
# DenyAll
# </Limit>
# </Directory>
# # Uncomment this if you're brave.
# <Directory incoming>
# # # Umask 022 is a good standard umask to prevent new files and dirs
# # # (second parm) from being group and world writable.
# Umask 022 022
# <Limit READ WRITE>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
# </Anonymous>
o que falta para eu me conectar? preciso criar duas pastas no /home/ftp/fernando, uma download e outra upload onde eu possa dar um upload externamente e que eu possa depois fazer um download da pasta download quando for preciso no caso vou deixar para baixar aplicativos que uso nos clientes e quando for achando um interessante entro via FTP e transfiro dando um upload e quando estiver em outro cliente baixo da pasta upload, como faço?
Citação
