  1. É a coisa foi feia, dois dias depois do lançamento da 3.12 já saiu a 3.13.
    What's new in 3.13:
    *) hotspot - fixed dst-nat for SMTP (broken in 3.11);
    *) dhcp client - added support for DHCP option 121 (classless route);
    *) fixed simple queues - changing simple queues could lock up i386 routers
    *) routing-test - added support for multiple recursive nexthops;
    *) routing-test - fixed BGP AS number byteorder, broken in 3.12;
    What's new in 3.12:
    *) fixed problem - static queues on PPPoE, PPTP, L2TP interfaces became invalid
    on client reconnect;
    *) changed behaviour of simple queues - queues with no limit and type default-small
    and no children actually do not get installed, as if there was no queue;
    *) console - allow "{}" array syntax only for some command arguments, as it
    does not make sense in most cases and interferes with the existing
    scripts. Now "/system script add source={....}" works as it did
    before 3.11;
    *) graphing - fixed crash when dynamic interfaces/queues disappear;
    *) fixed IPv6 address auto-configuration on routerboards;
    *) added support for OSPFv3;
    *) improved PCQ queueing algorithm;
    *) dhcp server - pass Agent-Remote-Id and Agent-Circuit-Id to Radius server;
    *) user manager - option to use test gateway for Authorize.Net payments;
    *) fixed bug - web server could lock up at startup
    (no access to hotspot login page after that);
    *) routing-test - added support for 4-octet BGP AS numbers;
    *) routing-test - added default-originate feature for BGP peers;
    *) routing-test - added IPv6 BGP networks and aggregates;
    Última edição por Magal; 28-08-2008 às 23:25.
  2. A 3.13 está bem melhor, até agora sem problemas nas RBs.
  3. Citação Postado originalmente por magal Ver Post
    no meu servidor ficou show
  1. Saiu a versão 3.24 do MK
    Por Magal no fórum Redes
    Respostas: 8
    Último Post: 25-05-2009, 13:30
  2. Saiu a versão 3.20 do MK
    Respostas: 21
    Último Post: 09-02-2009, 20:13
  3. Saiu a versão 3.19 do MK
    Último Post: 19-01-2009, 14:08
  4. Saiu a versão 3.18 do MK
    Último Post: 09-01-2009, 14:10
  5. Saiu a versão 3.13 do MK
    Respostas: 9
    Último Post: 16-08-2008, 09:21
