  1. Bom Dia pessoal.
    tenho dois micros com MK instalados rodando v.2.9.27 e as regras do firewall funcionam muito bem.
    adquiri agora algumas routerboard , só que as mesmas regras não funcionam, notei quando observei que pacotes nas portas 135-139 não estão sendo bloqueados, os contadores ficam todos no zero.
    Alguem tem idéia pq isso acontece???
  2. Deve ser a ordem das regras, deve ter uma regra antes dessa que ta liberando... exporta suas regras e coloca aqui pra ver...
    vlw
  3. add chain=input connection-state=invalid action=drop comment="Drop invalid \
    connections" disabled=no
    add chain=input connection-state=related action=accept comment="Accept related \
    add chain=input connection-state=established action=accept comment="Accept \
    established connections" disabled=no
    add chain=input protocol=tcp connection-limit=10,32 \
    action=add-src-to-address-list address-list=black_list \
    address-list-timeout=1d comment="detecta DoS attack 1 IP" disabled=no
    add chain=input protocol=udp action=accept comment="UDP" disabled=no
    add chain=forward protocol=tcp dst-port=25 src-address-list=spammer \
    action=drop comment="Regra 1 Anti-Spammer" disabled=no
    add chain=forward protocol=tcp dst-port=25 connection-limit=30,32 limit=50,5 \
    src-address-list=!spammer action=add-src-to-address-list \
    address-list=spammer address-list-timeout=1d comment="Regra 2 \
    add chain=input action=drop comment="Loga and dropa todo o resto" disabled=no
    add chain=forward connection-state=established action=accept \
    comment="Conexcoes Estabelecidas" disabled=no
    add chain=forward connection-state=related action=accept comment="Related \
    add chain=forward connection-state=invalid action=drop comment="Drop invalid \
    add chain=forward protocol=udp action=accept comment="UDP" disabled=no
    add chain=forward protocol=tcp dst-port=445-449 action=drop comment="Drop \
    Blaster Worm" disabled=no
    add chain=forward protocol=udp dst-port=445-449 action=drop comment="Drop \
    add chain=forward protocol=tcp dst-port=593 action=drop comment="" disabled=no
    add chain=forward protocol=udp dst-port=593 action=drop comment="" disabled=no
    add chain=forward protocol=tcp dst-port=1214 action=drop comment="" \
    disabled=no
    add chain=forward protocol=tcp dst-port=5554 action=drop comment="" \
    disabled=no
    add chain=forward protocol=tcp dst-port=135-139 action=drop comment="Drop \
    add chain=forward protocol=udp dst-port=135-139 action=drop comment="Drop \
    Messenger Worm" disabled=no
    add chain=forward protocol=tcp dst-port=1024-1030 action=drop \
    comment="________" disabled=no
    add chain=forward protocol=tcp dst-port=1080 action=drop comment="Dropa \
    MyDoom" disabled=no
    add chain=forward protocol=tcp dst-port=1214 action=drop comment="________" \
    disabled=no
    add chain=forward protocol=tcp dst-port=1363 action=drop comment="ndm \
    requester" disabled=no
    add chain=forward protocol=tcp dst-port=1364 action=drop comment="ndm server" \
    disabled=no
    add chain=forward protocol=tcp dst-port=1368 action=drop comment="screen cast" \
    disabled=no
    add chain=forward protocol=tcp dst-port=1373 action=drop comment="hromgrafx" \
    disabled=no
    add chain=forward protocol=tcp dst-port=1377 action=drop comment="cichlid" \
    disabled=no
    add chain=forward protocol=tcp dst-port=1433-1434 action=drop comment="Worm" \
    disabled=no
    add chain=forward protocol=tcp dst-port=2745 action=drop comment="Bagle Virus" \
    disabled=no
    add chain=forward protocol=tcp dst-port=2283 action=drop comment="Dropa \
    Dumaru.Y" disabled=no
    add chain=forward protocol=tcp dst-port=2535 action=drop comment="Dropa \
    Beagle" disabled=no
    add chain=forward protocol=tcp dst-port=2745 action=drop comment="Drop \
    Beagle.C-K" disabled=no
    add chain=forward protocol=tcp dst-port=3127-3128 action=drop comment="Drop \
    MyDoom" disabled=no
    add chain=forward protocol=tcp dst-port=3410 action=drop comment="Drop \
    Backdoor OptixPro" disabled=no
    add chain=forward protocol=tcp dst-port=4444 action=drop comment="Worm" \
    disabled=no
    add chain=forward protocol=udp dst-port=4444 action=drop comment="Worm" \
    disabled=no
    add chain=forward protocol=tcp dst-port=5554 action=drop comment="Dropa \
    Sasser" disabled=no
    add chain=forward protocol=tcp dst-port=8866 action=drop comment="Dropa \
    Beagle.B" disabled=no
    add chain=forward protocol=tcp dst-port=9898 action=drop comment="Drop \
    Dabber.A-B" disabled=no
    add chain=forward protocol=tcp dst-port=10000 action=drop comment="Drop \
    add chain=forward protocol=tcp dst-port=10080 action=drop comment="Drop \
    MyDoom.B" disabled=no
    add chain=forward protocol=tcp dst-port=12345 action=drop comment="Dropa \
    NetBus" disabled=no
    add chain=forward protocol=tcp dst-port=17300 action=drop comment="Dropa \
    Kuang2" disabled=no
    add chain=forward protocol=tcp dst-port=27374 action=drop comment="Drop \
    SubSeven" disabled=no
    Está são as regras que utilizo, mais como disse acredito que não seja a ordem, pois em um MK que tenho rodando elas funcionam super bem, só que na routerboards que adquiri não.
    Agradeço desde já qualquer ajuda.
  4. Notei que vc esta usando as regras de virus somente no canal forward, esperimente essa regra no inicio de todas:
    add chain=input action=jump jump-target=virus comment="Joga input para canal virus" disabled=no
    add chain=forward action=jump jump-target=virus comment="Joga forward para canal virus" disabled=no
    agora é so mandar todas as regras de drop pasarem pelo canal virus, não forward.
    testa ai...
    vlw
  5. Cara se ainda não deu certo o teu firewall você tem que ir somente em bridge settings e marcar use ip firewall que é o primeiro
  1. Respostas: 4
    Último Post: 25-02-2017, 11:00
  2. Problema com velocidade que nao bate na casa do cliente!
    Por Mestre no fórum Servidores de Rede
    Último Post: 27-01-2014, 10:40
  3. PROBLEMAS COM MSN QUE NAO CONECTA
    Por Cobausque no fórum Servidores de Rede
    Respostas: 5
    Último Post: 31-01-2011, 09:46
  4. Respostas: 3
    Último Post: 15-09-2009, 11:27
  5. Problema com algo que nao sei!!
    Por olifile no fórum Servidores de Rede
    Último Post: 28-01-2006, 22:38
