leandro@linux-mucw:~/Desktop> sh hplip-2.8.7.run
Creating directory hplip-2.8.7
Verifying archive integrity... All good.
Uncompressing HPLIP 2.8.7 Self Extracting Archive........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
HP Linux Imaging and Printing System (ver. 2.8.7)
HPLIP Installer ver. 4.0
Copyright (c) 2001-8 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Installer log saved in: hplip-install_Wed-20-Aug-2008_19:29:36.log
note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.
INSTALLATION MODE
Automatic mode will install the full HPLIP solution with the most common options.
Custom mode allows you to chose installation options to fit specific requirements.
Please choose the installation mode (a=automatic*, c=custom, q=quit) : a
Initializing. Please wait...
INTRODUCTION
This installer will install HPLIP version 2.8.7 on your computer.
Please close any running package management systems now (YaST, Adept, Synaptic, Up2date, etc).
DISTRO/OS CONFIRMATION
Distro appears to be SUSE Linux 11.0.
Is "SUSE Linux 11.0" your correct distro/OS and version (y=yes*, n=no, q=quit) ? y
SELECT HPLIP OPTIONS
Would you like to enable support for parallel (LPT
connected printers? (y=yes, n=no*, q=quit) ? n
ENTER ROOT/SUPERUSER PASSWORD
Please enter the root/superuser password:
/error: No output seen in over 300 sec... (Is the CD-ROM/DVD source repository enabled? It shouldn't be!)
Password incorrect. 2 attempt(s) left.
