    Padrão Como Resolver isso no proxy Transparente
    olha pessoal oque esta aparecendo nos access.log do squid e esta consumindo toda a conecao da internet
    sendo que a rede interne é 192.168.1.0/24
    Alguem ja pegou isso e como resolver??
    Obrigado
    89.239.131.225 TCP_MISS/200 279 CONNECT 64.12.161.185:443 - DIRECT/64.12.161.185 -
    1220658349.850 10400 90.188.136.178 TCP_MISS/200 143 CONNECT 205.188.153.98:443 - DIRECT/205.188.153.98 -
    1220658350.059 5585 89.239.131.225 TCP_MISS/200 184 CONNECT login.icq.com:443 - DIRECT/64.12.161.153 -
    1220658350.225 8411 89.239.131.225 TCP_MISS/200 184 CONNECT 205.188.179.233:443 - DIRECT/205.188.179.233 -
    1220658350.245 5229 78.155.204.124 TCP_MISS/200 143 CONNECT 205.188.153.249:443 - DIRECT/205.188.153.249 -
    1220658350.373 2604 212.135.30.163 TCP_MISS/200 185 CONNECT 205.188.179.233:443 - DIRECT/205.188.179.233 -
    1220658350.966 9481 80.101.0.52 TCP_MISS/200 206 CONNECT 205.188.179.233:443 - DIRECT/205.188.179.233 -
    1220658351.119 5926 87.116.161.61 TCP_MISS/200 142 CONNECT 64.12.161.153:443 - DIRECT/64.12.161.153 -
    1220658351.214 2565 78.29.78.95 TCP_MISS/200 186 CONNECT login.icq.com:443 - DIRECT/64.12.161.153 -
    1220658351.552 20679 89.239.131.225 TCP_MISS/200 184 CONNECT 64.12.161.153:443 - DIRECT/64.12.161.153 -
    1220658351.571 5541 78.155.204.124 TCP_MISS/200 39 CONNECT 64.12.161.153:443 - DIRECT/64.12.161.153 -
    1220658351.922 2696 81.243.247.12 TCP_MISS/200 183 CONNECT 64.12.161.153:443 - DIRECT/64.12.161.153 -
    1220658352.199 19108 61.50.171.254 TCP_CLIENT_REFRESH_MISS/200 26379 GET DIRECT/218.30.115.123 text/html
    1220658352.283 22209 69.86.187.202 TCP_MISS/200 14530 GET http://www.youtube.com/watch? - DIRECT/208.117.236.72 text/html
    1220658352.606 3061 89.239.131.225 TCP_MISS/200 184 CONNECT 64.12.200.89:443 - DIRECT/64.12.200.89 -
    1220658352.915 1771 78.136.94.162 TCP_MISS/200 494 GET http://l05.member.ird.yahoo.com/config/pwtoken_get? - DIRECT/217.146.187.239 application/octet-stream
    1220658353.094 3038 89.239.131.225 TCP_MISS/200 184 CONNECT 64.12.200.89:443 - DIRECT/64.12.200.89 -
    1220658353.157 2001 83.134.10.56 TCP_MISS/200 482 GET http://l1.login.vip.aue.yahoo.com/co...p_verify_user? - DIRECT/124.108.97.193 text/html
    1220658354.030 14467 84.60.229.221 TCP_MISS/200 252 CONNECT 205.188.153.121:443 - DIRECT/205.188.153.121 -
    1220658354.244 14624 218.155.236.170 TCP_MISS/999 4363 GET Sign in to Yahoo! - DIRECT/203.209.228.45 text/h
    Última edição por evertonfritz; 05-09-2008 às 19:29.
    Dec 2000
    Boston
    amigo provavelmente vc deixou o seu squid aberto pro mundo e esta todo mundo usando seu servidor de proxy para conectar na internet.... oq voce pode fazer e configurar corretamente o seu squid limitando apenas para sua rede local via acl....
    Para voce entender oq estou falando de uma olhada no nosso wiki em nossa documentacao do squid
    Projetos/Squid-Doc - UnderLinux Wiki
    O engraçado é que sao os mesmo saite e ips
    por iptables com faço para bloquear isso no placa de rede da internet eth0??
    Dec 2000
    Boston
    se voce esta usando a porta 3128 para o squid seria
    Código :
    iptables -A INPUT -s 192.168.1.0/24 -p tcp --dport 3128 -j ACCEPT
    iptables -A INPUT -p tcp --dport 3128 -j DROP
    Desta forma vc vai liberar tudo que e 192.168.1.0/24 para a porta 3128
    e vai bloquear tudo diferente disso para acessar esta porta.
    Apr 2007
    Caruaru - Pernambuco
    Citação Postado originalmente por evertonfritz Ver Post
    Everton boa noite.
    Como no nosso amigo scorpion falou, seu servidor squid está liberado para todos e estão aproveitando. O que o Scorpion disse é que você configure o squid para aceitar apenas a sua rede interna e o resto negar.
    veja as suas ACL´s. Com certeza está deste tipo:
    acl all src 0.0.0.0/0
    Mude para:
    acl all src 192.168.0.0/24
    Isso irá permitir apenas que sua rede interna tenha acesso ao seu squid. Lembrando que no final do suas linhas de ACL´s, coloque esta:
    http_access deny all
    Isto informa que se nenhuma requisição se encaixar em nenhum comando acima desta linha, simplesmente o squid, não permitirá o acesso.
    vou postar aqui também as regras para bloqueio a IP Spoofing
    iptables -N syn-flood
    iptables -A INPUT -i eth0 -p tcp --syn -j syn-flood
    iptables -A syn-flood -m limit --limit 1/s --limit-burts 4 -j RETURN
    iptables -A syn-flood -j DROP
    Espero ter ajudado.
    Atenciosamente,
