    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão Saiu o MK 3.14 Final
    Link para download: http://www.mikrotik.com/download.html
    What's new in 3.14:
    *) fixed '/xen console' command;
    *) fixed problem - queue bursts did not work;
    *) added support for OSPF NSSA in routing-test;
    3.14rc1:
    *) updated drivers, some of the changes:
    synchronous cards should work in frame relay mode;
    SIP connection tracking is more standards conformant;
    valid TCP connection packets will not be marked as invalid;
    *) mlppp - fixed problem when small packets could not be transmited
    while more than 2 links were active;
    *) bgp - fixed attribute flags checking;
    *) fixed dhcp client - routes were not added back after lease expires
    and then is acquired again;
    *) fixed handling of multiple identical address-list entries
    *) ospf could become unresponsive in some situations, fixed;
    *) winbox - fixed problem: when moving multiple items at once,
    correct order was not maintained;
    *) fixed automatic fan control on RB600;
    *) added ipv6 firewall address-list;
    *) fixed some bugs in mesh protocol driver;
    *) fetch tool - added basic HTTP authentication;
    *) 6to4 tunnel - allow to specify remote address;
    Última edição por Magal; 19-09-2008 às 12:59.
    A priori, preciso de ajuda para atualizar o meu 3.10 licenciado instalado num PC sem risco de perder a licença. Não sei nem por onde começar.
