  1. O suid aqui ta ficando lerdo quando o cache fica com 1GB do Hd dai limpo ele vouta ao normal.
    Servidor paralelo
    *************** Maquina: *********************
    Celeron 1.6 Ghz
    HD Sata 160GB
    RAM: 1Gb
    Sistema Fedora 8
    ***************** MK: *****************************
    RB: 433AH
    ************************* Squid.conf *********************************
    http_port 8080 transparent
    icp_port 0
    hierarchy_stoplist cgi-bin ?
    acl video_cache dstdomain .youtube.com video.google.com .llnwd.net .dailymotion.com .googlevideo.com
    acl google_earth dstdomain kh.google.com
    acl flashvideo urlpath_regex .swf .flv .avi .mov
    no_cache allow video_cache
    no_cache allow google_earth
    no_cache allow flashvideo
    no_cache deny QUERY
    cache_mem 128 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 60 MB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 64 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 95
    fqdncache_size 1024
    cache_replacement_policy heap LFUDA
    memory_replacement_policy heap GDSF
    cache_dir aufs /var/spool/squid 20000 128 128
    # cache_dir ufs /var/spool/squid 20000 128 128
    mime_table /etc/squid/mime.conf
    pid_filename /var/run/squid.pid
    debug_options ALL,1
    log_fqdn off
    #Suggested default:
    refresh_pattern . 0 20% 4320
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    # coloque susa redes validas aqui
    acl internet src 192.168.0.0/16
    # redes invalidas, nao tem perigo pois nunca virao da internet
    acl intranetb src 172.16.1.0/24 192.168.5.0/24
    acl SSL_ports port 443 563 82
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 563 # https
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow internet
    http_access allow intranetb
    http_access deny all
    cache_mgr google.com.br
    cache_effective_user squid
    cache_effective_group squid
    visible_hostname localhost
    access_log /var/log/squid/access.log squid
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    # client_netmask 255.255.255.255
    icon_directory /usr/share/squid/icons
    coredump_dir /var/spool/squid
    Última edição por hmvhost; 20-09-2008 às 18:26.
  2. Citação Postado originalmente por hmvhost Ver Post
    Servidor paralelo
    Celeron 1.6 Ghz
    HD Sata 160GB
    RAM: 1Gb
    Sistema Fedora 8
    RB: 433AH
    "cache_mem 128 MB " coloque mais memoria para o cache e faça um teste
  3. total used free shared buffers cached
    Mem: 2066560 1294520 772040 0 97456 733796
    -/+ buffers/cache: 463268 1603292
    Swap: 0 0 0
    Coloquei mais um GB de ram mais esta lento ainda!
  4. Meu caro,
    dependendo da quantidades de clientes que você possui o seu servidor Squid não é adequado. Use processador da linha Pentium, Athlon ou Xeon de pelo menos 2.0GHz. Ponha 4GB de RAM ou mais. Reinstale o seu sistema e aloque uns 3GB de RAM para o Squid.
  5. Ja to desistindo não consigo entrar em acordo agora a tarde o consumo de memoria chego a 2.2GB
    com 10 clientes online
  1. Squid Lento
    Por Hawthorn no fórum Servidores de Rede
    Último Post: 03-04-2004, 21:49
  2. Squid Lento
    Por guardian_metal no fórum Servidores de Rede
    Respostas: 8
    Último Post: 26-01-2004, 17:40
  3. Squid Lento
    Último Post: 25-07-2003, 12:26
  4. squid lento ftp
    Por polaco no fórum Servidores de Rede
    Último Post: 09-05-2003, 09:39
  5. SQUID LENTO
    Por Kernel_Panic no fórum Servidores de Rede
    Último Post: 24-02-2003, 18:15
