    Padrão quedas frequentes rb 133 mt 3.13
    olá, boa tarde a todos,
    Amigos alguém já passou por essa situação, onde ocorrem desconexões frequentes dos clientes na wireless, rb 133 com mt 3.13, cartão mikrotik r52...mesmo com clientes usando kit pci ou ap (ovislink) tmb ocorrem, o sinal está otimo. Segue as logs:
    14:09:36 wireless,info 00:4F:62:11:FF:[email protected] Shopping: disconnected, request to disconnect from registration table
    14:09:38 wireless,info 00:4F:62:11:FF:[email protected] Shopping: connected
    14:09:38 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, request to disconnect from registration table
    14:09:38 wireless,info AP Shopping: data from unknown device 00:0E:2E:85:A1:XX, sent deauth
    14:09:39 wireless,info AP Shopping: data from unknown device 00:0E:2E:85:A1:XX, sent deauth
    14:09:50 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:12:18 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:12:18 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:12:18 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:12:49 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:12:49 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:12:49 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:17:01 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:17:01 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:17:01 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:17:01 wireless,info 00:02:72:6D2:[email protected] Shopping: reassociating
    14:17:01 wireless,info 00:02:72:6D2:[email protected] Shopping: disconnected, ok
    14:17:02 wireless,info 00:02:72:6D2:[email protected] Shopping: connected
    14:23:51 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:23:51 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:23:51 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:27:15 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:27:15 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:27:15 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    14:28:34 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: reassociating
    14:28:34 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: disconnected, ok
    14:28:34 wireless,info 00:0E:2E:85:A1:[email protected] Shopping: connected
    alguma sugestão? obrigado
    Tbm to com uma RB dando esse erro e o povo reclamando, da esse log tbm:
    o que é issso SENT DEAUTH ???
    tem como bloquear??
    olha peguei um script aki mesmo no forum pra bloquear o vilão sent deauth
    Código :
    /ip firewall filter
    add action=tarpit chain=input comment="bloqueio de sent deauth " \
        connection-limit=3,32 disabled=no protocol=tcp src-address-list=\
        blocked-addr
    so que no meu caso nao valeu em nada esta do mesmo jeito nao sei com vc's testa ai .
    aki tbm fica assim e os clientes reclama muito disso pq em alguns casos o cliente tem que reiniciar o pc para conseguir conectar novamente na minha rede .
    tbm estou a procura de uma sulução para essa maldição hehehe .
    Citação Postado originalmente por 14735 Ver Post
    Código :
    /ip firewall filter
        blocked-addr
    alguém sabe o q exatamente faz esse script, e sabe o motivo real de o cliente ser desconectado com sent deauth ?
    obrigado e t+
    Pesquisei no forum um poco, mas so tem essa regra de bloqueio do Sent Deauth.... so q aki na minhha RB tbm nao funciono, ate atualizei ela pra V 3.15 q me disseram q era bug de versão, e nada...
