    Padrão Mikrotik 3.15 is out!!
    acabou de sair a nova versao do mk, com varia melhoria sera que dessa ves o proxy funciona?
    What's new in 3.15:
    *) added workaround for non-standards compliant CPE with timestamp issue;
    *) added ability to manage multiple disks & stores under /store;
    *) added support for storing user-manager database on secondary media via /store;
    *) /store should be used to set up secondary disk as web proxy cache;
    *) added support for Mesh in WinBox;
    *) fixed client roaming in mesh protocol;
    *) fixed bug in MME routing protocol:
    routes sometimes were lost from routing table;
    *) fixed some bugs in routing-test;
    *) fixed traffic forwarding when VRF (virtual routing and forwarding) is used;
    *) fixed problem - USB did not work on Geode LX boards;
    *) fixed problem - farsync cards did not negotiate links;
    *) added support for Novatel EU870D;
    *) added support for Intel 82575EB & 8257GB gigabit ethernet PCI-Express cards;
    *) removed support for all synchronous cards but farsync;
    *) graphing - all target (source) addresses displayed in queue statistics page;
    *) bridge firewall broute table is removed - it did not work as expected anyway;
    *) ingress-priority matcher added to bridge firewall
    *) fixed use-dns property of console traceroute command, default now is
    use-dns=no;
    *) updated UK 5.8 FIXED regulatory domain info;
    *) /system ssh now by default uses name of logged in user instead of "admin";
    *) fixed support for some microSD cards on RB400;
    *) include Relay-Session-ID in packets sent by PPPoE client if required;
    *) added ability to specify src. address for radius client;
    *) dns cache - improved static entry behavior;
    *) fixed dial-on-demand on ppp interfaces;
    http://www.mikrotik.com/download.html
    outra novidade:
    foi acresentado um botao MESH
    Última edição por Snake_jp; 16-10-2008 às 15:30.
    pra quem tem a versão comprada he so baixa a atualização e faze o upgrade?
    Citação Postado originalmente por 14735 Ver Post
    isso mesmo, eu acabei de atualizar meus servers aqui.
    notei uma melhora e algumas configuracoes no proxy mudaram.
    outra coisa agora existe um novo comando /store onde pelo que me parece vc pode setar entre varoi hds pro cache por exemplo, so que ate agora eu n consegui fazer ele setar meu cache pro segundo hd. se alguem tiver usando essa versao eu souber algo eu agradec'o
    essa nova versão he para rb ou pc ou os 2?
    no site oficial do mikrotik em downloads voce escolhe o tipo de RB ou INTEL/AMD PC
    pessoal,
    cautela para atualizar,
    conselho (por experiencia propria)
    atualizem o backup primeiro, e testem em bancada, pois podem ocorrer alguns imprevistos e os clientes ficarem parados até a correção do problema.
    Att.
    Jan 2004
    Capital do Triângulo
    Citação Postado originalmente por nandop1240 Ver Post
    pessoal,
    Att.
    Principalmente se usar x86. Quem usa RB nem precisa se preocupar muito, mas x86 eles andam avacalhando mesmo.
    pessoal,
    Att.
    isso mesmo, um dos meus servidores depois que atualizei ele ficou travando, voltando apenas resetar a maquina.
    mas acho q isso nao e problema da versao 3.15 pq isso acontecia na versao 3.14 tamben. ai tive q fazer um downgrade
    pra versao 3.13. mas em dois outros servers esta funcionando normalmente.
    cara, facil de vc saber essas coisas... quando vc seleciona a série da placa ou do computador.. ai muda pra últim versão disponível. Assim vc sabe logo se tem versão para sua placa, e pra seu servidor.. ou só pra um... ou só pra outro !
    Testei aqui no x86 e o controle de banda nada, mesmo fazendo por mangle e queue tree e simple, não rola.
    Mr rg depois de apanhar muito com mikrotik....de ter escutado varios preços de pessoas para programar meu mikrotik, enfim, conseguiu sozinho, obrigado pela sua ajuda...sobre web-proxy, estou colocando aos poucos regras de firewall...até agora ta sem problema. Atualizei pra esta versao 3.15 e está funcionando o queue simple e queue tree.
    galera confirmado mesmo algum bug na versão 3.15 ?como anda os teste de quem já atualizou as torres ?
    Citação Postado originalmente por Snake_jp Ver Post
    What's new in 3.15:
    use-dns=no;
    outra novidade:
    Desde a última versão o proxy do Mikrotik funciona perfeitamente.
    aqui ta tudo beleza
    e o proxy ta funcionando razoavelmente bem
    Padrão Cache full
    O meu web-proxy tá funcionando para as páginas porém, eu gostaria muito de fazer cache full, não estou conseguindo (preciso de uma ajudinha de vcs)...outra coisa na versao 3.15 existe um botao store, é pra adicionar mais de um hd como web-proxy é isso?
    Abraços,
    Para fazer o cache full você deve setar o valor do DSCP (ToS) referente a versão 3.x que é DSCP=4.
    Em relação ao store, seria o local de armazenamento.
    Padrão Versão 3.15
    A versão até o presente momento tem se saido a melhor possivel firewall , queues , cache full , tudo funcionando 100% inclusive até melhor que as anteriores
    Moderador Avatar de minelli
    Aug 2006
    Padrão Web-Proxy
    Pessoal minha duvida é quanto ao tamanho do arquivo armazenado no proxy.
    Padrão cache full
    mr. rg se nao for pedir muito...posta por favor a regra do cache full na versao 3.15 e realmente nao vejo também onde colocar o tamanho do arquivo na versão 3.15
    Abraços,
