    Padrão Samba + Ldap -
    Amigos,
    Configurei um Samba + Ldap como PDC. Criei o usuário root no Ldap e logado como administrador local na minha máquina Win XP, tentei adicionar no domínio e recebo a mensagem: "Não foi possível localizar o nome de usuário".
    Verifiquei no grupo "Computers" do ldap e foi criada a conta para a máquina. Que usuário é esse que não foi encontrado?
    Segue o meu smb.conf
    [global]
    kernel oplocks = yes
    workgroup = SULSOFT
    server string = Servidor Hannabarbera
    announce as = NT Server
    nt acl support = yes
    wins support = yes
    # This will prevent nmbd to search for NetBIOS names through DNS.
    dns proxy = no
    # support for the Windows privilege model
    enable privileges = yes
    # Adicionar maquinas no Ldap
    add machine script = /usr/sbin/smbldap-useradd -t 5 -w "%u"
    # What naming service and in what order should we use to resolve host names
    name resolve order = lmhosts host wins bcast
    #### Networking ####
    # The specific set of interfaces / networks to bind to
    ;interfaces = eth0
    ;bind interfaces only = true
    #### Debugging/Accounting ####
    # This tells Samba to use a separate log file for each machine
    log file = /var/log/samba/%m.log
    log level = 2
    # Put a capping on the size of the log files (in Kb).
    max log size = 5000
    # We want Samba to log a minimum amount of information to syslog.
    syslog only = no
    syslog = 0
    ####### Authentication #######
    security = user
    encrypt passwords = true
    # Passwords no Ldap
    passdb backend = ldapsam:ldap://127.0.0.1
    ldap suffix = dc=sulsoft,dc=com,dc=br
    ldap machine suffix = ou=computers
    ldap user suffix = ou=users
    ldap group suffix = ou=groups
    ldap admin dn = cn=admin,dc=sulsoft,dc=com,dc=br
    ldap delete dn = no
    ldap password sync = yes
    # For Unix password sync to work on a Debian GNU/Linux system, the following
    passwd program = /usr/sbin/smbldap-passwd -u %u
    passwd chat = "Alterar senha para *\nNova senha*" %n\n "*Repita a nova senha*" %n\n"
    ########## Domains ###########
    # CONTROLADOR DE DOMINIO
    local master = yes
    domain master = yes
    os level = 150
    preferred master = yes
    logon script = %U.bat
    domain logons = yes
    logon path = \\%L\Profiles\%U
    logon drive = H:
    ########## Printing ##########
    # If you want to automatically load your printer list rather
    # than setting them up individually then you'll need this
    load printers = yes
    # Impressao gerenciada pelo Cups
    printing = cups
    printcap name = cups
    cups options = raw
    # When using [print$], root is implicitly a 'printer admin', but you can
    # also give this right to other users to add drivers and set printer
    # properties
    ; printer admin = @ntadmin
    ############ Misc ############
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # The following parameter is useful only if you have the linpopup package
    ; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
    #======================= Share Definitions =======================
    [homes]
    comment = Home Directories - SulSoft
    path = /home/sulsoft/%U
    browseable = no
    writable = yes
    veto files = /*.mp3/*.avi/*.mpeg/*.mpg/*.asf/*.divx/*.wma/*.pif/*.scr/*.wmv/
    [Central_de_arquivos]
    comment = Central de arquivos
    path = /home/Dados/Central_de_arquivos
    browseable = yes
    writable = yes
    valid users = @users
    public = no
    [Publico]
    comment = Pasta publica
    path = /home/Dados/Publico
    browseable = yes
    writable = yes
    public = yes
    [Storage]
    comment = Repositorio de arquivos
    path = /home/Dados/Storage
    browseable = yes
    writable = yes
    public = no
    valid users = alexandro
    [backups]
    comment = Backups de arquivos
    path = /home/Dados/backups
    browseable = no
    writable = yes
    public = no
    [netlogon]
    comment = Network Logon Service
    path = /home/Dados/netlogon
    browseable = no
    public = yes
    writable = no
    share modes = no
    #[profiles]
    # comment = Users profiles
    # path = /home/samba/profiles
    # public = no
    # guest ok = no
    # browseable = no
    # writable = yes
    # veto files = /*.mp3/*.avi/*.mpeg/*.mpg/*.asf/*.divx/*.wma/*.pif/*.scr/
    [printers]
    comment = All Printers
    browseable = no
    path = /var/spool/samba
    printable = yes
    public = yes
    guest ok = yes
    writable = no
    [print$]
    path = /var/lib/samba/printers
    browseable = no
    read only = yes
    guest ok = yes
    read only = yes
    write list = @admin, root
    Padrão depois do pico de energia samba da "dominio indisponivel"
    Perdao eu estava lendo o seu topico e acabei fazendo essa besteira.
    sobre sua questao qual linux tu ta usando versao do ldap e do samba.
    tive um problema assim com fedora e nao consegui resolver entao eu passei pro centos 5.2 e fiz as mesma configuraçoes e funciono e outro detalhe pra vc colocar alguma maquina no dominio vc tem q ter um administrador pra ter um faça esse comando.
    Criar um grupo chamado admins com o comando smbldap-groupadd usando o gid 512 (smbldap-groupadd -g 512 admins)
    • Criar um grupo chamado usuarios com o comando smbldap-groupadd usando o gid 513 (smbldap-groupadd -g 513 usuarios)
    • Mapear o grupo unix admins com o grupo NT Domain Admins usando o comando net (net groupmap add rid=512 unixgroup=admins ntgroup="Domain Admins")
    • Mapear o grupo unix usuarios com o grupo NT Domain Users usando o comando net (net groupmap add rid=513 unixgroup=usuarios ntgroup="Domain Users")
    • Criar uma contar para o usuário administrator da base LDAP com direitos de administrador e definir a senha smbldap-useradd -g 512 -m -a administrator
    smbldap-usermod -u 0 administrator
    smbldap-passwd administrator
    Última edição por noir; 17-10-2008 às 15:33. Razão: criei topico no lugar errado
    Noir, sugiro criar o seu próprio tópico, pois assim você atrapalha na minha dúvida e deixa tudo confuso.
    Moderadores, favor separar o tópico, pois a resposta não é relacionada ao assunto inicial.
    Obrigado!
    Alex.
