    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão PseudoBridge
    Em Inglês:
    station-pseudobridge - wireless station that can be put in bridge. MAC NAT is performed on all traffic sent over the wireless interface, so that it look like coming from the station's MAC address regardless of the actual sender (the standard does not allow station to send packets with different MAC address from its own). Reverse translation (when replies arrive from the AP to the pseudobridge station) is based on the ARP table. Non-IP protocols are being sent to the default MAC address (the last MAC address, which the station has received a non-IP packet from). That means that if there is more than one client that uses non-IP protocols (for example, PPPoE) behind the station, none of them will be able to work correctly
    station-pseudobridge-clone - similar to the station-pseudobridge, but the station will clone MAC address of a particular device (set in the station-bridge-clone-mac property), i.e. it will change itsown address to the one of a different device. In case no address is set in the station-bridge-clone-mac property, the station postpones connecting to an AP until some packet, with the source MAC address different from any of the router itself, needs to be transmitted over that interface. It then connects to an AP with the MAC address of the device that have sent that packet.
    Em Espanhol:
    Muchas veces se sabe preguntar cuando se va a configurar una red inalámbrica en Mikrotik para que sirven los modos pseudo-bridge y pseudo-bridge-clone-mac acá va un explicación de ello.
    No es verdad que se puede hacer un bridge transparente con modo=pseudobridge.
    El modo pseudobridge: La interfaz inalámbrica puede ser colocada en un bridge. Un MAC-NAT se realiza para todo el tráfico enviado a través de la interfaz inalámbrica, de manera que parezca que viene de la estación registrada, independiente de la MAC de origen. La norma no permite enviar paquetes con diferentes mac de un mismo origen. La traducción inversa (cuando llegan las respuestas del AP a la estación pseudo-bridge) se basa en la tabla ARP.
    Protocolos No-IP son enviados a la MAC-Address por defecto (la última dirección MAC que ha recibido de un paquete No-IP) esto significa que si hay algún cliente que use protocolos No-IP (como el PPPoE) detrás de la estación, ninguno de ellos será capaz de funcionar correctamente.
    Modo pseudobridge-clone: Similar al station-pseudobridge, pero la estación va a clonar la MAC Address de un dispositivo en particular (seteado en la station-bridge-clone-mac propiedad), por ejemplo, esta cambiara su propia dirección mac a la de una de un dispositivo diferente.
    En caso de que no se ingrese una direccion en la station-bridge-clone-mac propiedad, la estación postpondrá las conexiones hacía un AP hasta que algún paquete, con una MAC address origen diferente de cualquier router en si, tiene que ser trasmitido a traves de la interface. Es entonces que se conecta al AP con la MAC address del dispositivo que ha enviado el paquete.
    Última edição por Magal; 29-10-2008 às 17:08.
