    Padrão Problemas em add Bridge em Hotspot
    Saudações Galera do Forun
    Seguinte Irmãos.
    To com uma RB600 na torre(maravilha de RB) ether1(link)--> hotspot --> wlan1(cliente), resolvi colocar mais 3 cartoes com 3 setoriais, so que quando add as wlans na bridge não funfa legal, hora funciona e hora nao funciona, da tipo erro de dns, chamo um site o navegador faz a pesquisa do site, nao abre. Fiz tudo certinho, coloquei o hotspot pra escutar na bridge, coloquei o ip na bridge mas mesmo assim nao funfa, quando removo a bridge e volto pra wlan1 como tava antes funciona normal, to usando a versao 3.10.
    Aguardo uma ajuda de vcs!
    [[email protected]] /ip hotspot> exp
    # jan/01/1970 00:20:26 by RouterOS 3.10
    # software id = 3875-PTT
    /ip hotspot profile
    set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default \
    rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
    add dns-name=hotspot.ellite.com.br hotspot-address=192.168.1.1 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap name=hsprof2 nas-port-type=\
    wireless-802.11 radius-accounting=yes radius-default-domain="" radius-interim-update=received radius-location-id="" radius-location-name="" rate-limit="" \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
    /ip hotspot
    add address-pool=hs-pool-2 addresses-per-mac=2 disabled=no idle-timeout=5m interface=bridge1 keepalive-timeout=none name=hotspot1 profile=hsprof2
    /ip hotspot user profile
    set default advertise=no idle-timeout=none keepalive-timeout=2m name=default open-status-page=always shared-users=1 status-autorefresh=1m transparent-proxy=\
    yes
    add address-pool=hs-pool-2 advertise=no idle-timeout=none keepalive-timeout=2m name=liberado open-status-page=always rate-limit=128k/128k shared-users=2 \
    status-autorefresh=1m transparent-proxy=yes
    /ip hotspot service-port
    set ftp disabled=no ports=21
    /ip hotspot user
    add comment="" disabled=no name=admin password=1234 profile=default
    add address=192.168.1.20 comment="" disabled=no name=willianrcn password=123 profile=liberado server=hotspot1
    Voce precisa setar o hotspot-address, tipo hotspot-address=192.168.1.1 que eh o ip da bridge. Setar o ip em ip address para a bridge e setar a interface do hotspot para bridge tambem.
