    Padrão SAMBA - ERROS sem fim....me ajudem por favor!!
    Galera, sou novo em linux e por aqui, mais estou com estes problemas e erros no samba que não estou encontrando solução no google, será que alguém poderia me ajudar como começar a corrigir estes erros????
    Obrigado a todos que se dispuderem....
    Processing section "[homes]"
    [2008/11/27 11:23:06, 2] param/loadparm.c:do_section(3712)
    Processing section "[profiles]"
    Processing section "[profilesNT]"
    Processing section "[comercial]"
    Processing section "[cdrom]"
    Processing section "[emp_arquivos]"
    Processing section "[financeiro]"
    Processing section "[diretoria]"
    Processing section "[printers]"
    [2008/11/27 11:23:06, 3] param/loadparm.c:lp_add_ipc(2637)
    adding IPC service
    [2008/11/27 11:23:06, 3] printing/pcap.ccap_cache_reload(117)
    reloading printcap cache
    [2008/11/27 11:23:06, 3] printing/pcap.ccap_cache_reload(223)
    reload status: ok
    reload status: ok
    [2008/11/27 11:23:06, 2] lib/interface.c:add_interface(81)
    added interface ip=192.168.0.150 bcast=192.168.0.255 nmask=255.255.255.0
    [2008/11/27 11:23:06, 3] smbd/server.c:main(877)
    loaded services
    [2008/11/27 11:23:06, 3] smbd/server.c:main(892)
    Becoming a daemon.
    [2008/11/27 11:23:06, 2] lib/tallocmsg.c:register_msg_pool_usage(61)
    Registered MSG_REQ_POOL_USAGE
    [2008/11/27 11:23:06, 2] lib/dmallocmsg.c:register_dmalloc_msgs(71)
    Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
    [2008/11/27 11:23:06, 3] smbd/sec_ctx.cush_sec_ctx(208)
    push_sec_ctx(0, 0) : sec_ctx_stack_ndx = 1
    [2008/11/27 11:23:06, 3] smbd/uid.cush_conn_ctx(353)
    push_conn_ctx(0) : conn_ctx_stack_ndx = 0
    [2008/11/27 11:23:06, 3] smbd/sec_ctx.c:set_sec_ctx(241)
    setting sec ctx (0, 0) - sec_ctx_stack_ndx = 1
    push_sec_ctx(0, 0) : sec_ctx_stack_ndx = 2
    push_conn_ctx(0) : conn_ctx_stack_ndx = 1
    setting sec ctx (0, 0) - sec_ctx_stack_ndx = 2
    [2008/11/27 11:23:06, 3] smbd/sec_ctx.cop_sec_ctx(339)
    pop_sec_ctx (0, 0) - sec_ctx_stack_ndx = 1
    pop_sec_ctx (0, 0) - sec_ctx_stack_ndx = 0
    [2008/11/27 11:23:06, 3] lib/privileges.c:get_privileges(261)
    get_privileges: No privileges assigned to SID [S-1-22-1-0]
    get_privileges: No privileges assigned to SID [S-1-5-2]
    get_privileges: No privileges assigned to SID [S-1-5-11]
    [2008/11/27 11:23:06, 3] lib/util_seaccess.c:se_access_check(250)
    [2008/11/27 11:23:06, 3] lib/util_seaccess.c:se_access_check(251)
    se_access_check: user sid is S-1-22-1-0
    se_access_check: also S-1-5-32-544
    se_access_check: also S-1-1-0
    se_access_check: also S-1-5-2
    se_access_check: also S-1-5-11
    get_privileges: No privileges assigned to SID [S-1-5-21-1502207660-3908411059- 184791540-501]
    Padrão Galera peço encarecidamente a ajuda de vc's
    Quem puder ajudar....por favor....estou enviando o smb.conf abaixo, estou revirando a internet aqui mais não consigo respostas para estes erros.....
    Obrigado novamente!!
    servcata:/home/pub/profilesNT/rodrigo# testparm
    Load smb config files from /etc/samba/smb.conf
    Loaded services file OK.
    Server role: ROLE_DOMAIN_PDC
    Press enter to see a dump of your service definitions
    [global]
    unix charset = iso8859-1
    workgroup = ariosu
    realm = ariosul
    netbios aliases = ariosu
    server string = servcata
    passwd program = /usr/bin/smbpasswd %u
    passwd chat = *New*password*%n\n*Retype*new*password*%n\n*passwd:*all*au thentication*tokens*updated*sucessfully*
    log level = 3
    log file = /var/log/samba/log.%m
    max log size = 2048
    max xmit = 65535
    name resolve order = lmhosts host wins bdcast
    deadtime = 15
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    printcap name = /etc/printcap
    add machine script = /usr/sbin/useradd -d /dev/null -s /bin/false -g mac hines %u
    logon path = \\192.168.0.150\profilesNT\%U
    logon drive = w:
    logon home = \\%L\%U\.profile
    domain logons = Yes
    os level = 99
    preferred master = Yes
    domain master = Yes
    dns proxy = No
    wins support = Yes
    panic action = /usr/share/samba/panic-action %d
    change notify timeout = 300
    printing = cups
    print command =
    lpq command = %p
    lprm command =
    case sensitive = No
    delete veto files = Yes
    veto files = *.mp3
    [homes]
    comment = Home Directories
    create mask = 0700
    directory mask = 0700
    [profiles]
    comment = Profiles Users
    path = /home/pub/profiles
    read only = No
    create mask = 0600
    browseable = No
    [profilesNT]
    path = /home/pub/profilesNT
    read only = No
    create mask = 0600
    browseable = No
    [comercial]
    comment = comercial
    path = /home/emp_arquivos/comercial
    valid users = @comercial, @marketing
    read list = @comercial, @marketing
    write list = @comercial, @marketing
    read only = No
    inherit permissions = Yes
    [cdrom]
    comment = CDrom Servcata
    path = /tmp
    create mask = 0777
    guest ok = Yes
    preexec = /bin/mount/cdrom
    preexec close = Yes
    [emp_arquivos]
    comment = Empresa Arquivos
    force user = todos
    force group = todos
    read only = No
    create mask = 0600
    inherit owner = Yes
    guest ok = Yes
    afs share = Yes
    vfs objects = recycle
    recycle:repository = .lixeira
    recycle:keeptree = yes
    recycle:versions = yes
    [financeiro]
    path = /home/emp_arquivos/financeiro
    write list = @financeiro
    force user = @financeiro
    force group = @financeiro
    read only = No
    create mask = 0770
    directory mask = 0770
    inherit owner = Yes
    browseable = No
    [diretoria]
    comment = arquivos da diretoria
    path = /home/emp_arquivos/diretoria
    write list = @diretoria
    read only = No
    [printers]
    path = /tmp
    read only = No
    guest ok = Yes
    printable = Yes
    lpq command = lpstat -o %p
    lprm command = cancel %p-%j
    browseable = No
    Voce poderia comecar com "feijao com arroz".
    Coloca o samba simples mesmo e ve se o erro continua, e va adicionando as opcoes aos poucos, pelo ao menos eu sempre faco assim, desse jeito eu vejo exatamente onde esta o problema. Seu smb.conf existem muitas opcoes que eu desconheco, por isso nao posso dizer onde esta o erro. Espero ter ajudado.
    concordo com o celsonery
    va do basico para o avançado e não o contrario...
    comente os compartilhamentos deixando apenas um e vai testando um por um
    assim vc pode indentificar se o problema esta em um compartilhamento.
    posta ai depois se achar a solução pq eu tambem nunca vi estes erros ai!
    experimenta tirar ele de dominio pra grupo de trabalho.
    Padrão Obrigado....
    Galera agradeço muito a ajuda de vc's, vou tentar essas possibilidades, o problema que a máquina está em uso na empresa, pra eu fazer estes testes vou ter que ver a melhor forma.
    Mais obrigado mesmo!!!
    Valew.....
