  1. Boa Tarde,
    Distro: CentOS 5
    Bind: 9.3.4 + Chroot
    Meu problema é o seguinte instalei o bind e configurei tudo porém de uma forma estranha não consegui faze-lo funcionar vou mandar minha configs dele para caso alguem possa me ajudar a entender o problema.
    named.conf
    options {
    directory "/var/named";
    forwarders{
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    */ // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    zone "." {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    notify no;
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    notify no;
    key key_rndc {
    algorithm "hmac-md5";
    secret "89sxdjku39090s==";
    controls {
    inet 127.0.0.1 allow {localhost; } keys {key_rndc; };
    zone "meusite.com" IN {
    type master;
    file "db.meusite.com";
    zone "XXX.XXX.200.in-addr.arpa" IN {
    type master;
    file "db.meusite.com.rev";
    include "/etc/rndc.key";
    zona = db.meusite.com
    $TTL 86400
    @ IN SOA ns1.meusite.com. suporte.meusite.com. (
    2008120104 ; Serial
    10800 ; Refresh
    900 ; Retry
    604800 ; Expiry
    86400 ) ; Minimum
    @ IN NS ns1.meusite.com.
    @ IN NS ns2.meusite.com.
    @ IN MX 10 meusite.com.br.
    @ IN A 200.XXX.XXX.XX
    localhost IN A 127.0.0.1
    meusite.com. IN A 200.XXX.XXX.XX
    ns1 IN A 200.XXX.XXX.XX
    ns2 IN A 200.XXX.XXX.XX
    www IN A 200.XXX.XXX.XX
    zona reversa = db.meusite.com.rev
    $TTL 86400
    2008120104 ; serial
    10800 ; Refresh
    900 ; Retry
    604800 ; Expire
    86400 ) ; Minimum
    IN A 200.XXX.XXX.XX
    12 IN PTR ns2.meusite.com.
    13 IN PTR www.meusite.com.
    Fiz os seguintes testes:
    [meusite.com ~]# ping meusite.com
    PING meusite.com (200.XXX.XXX.XX) 56(84) bytes of data.
    64 bytes from ns1.meusite.com (200.XXX.XXX.XX): icmp_seq=1 ttl=64 time=0.015 ms
    64 bytes from ns1.meusite.com (200.XXX.XXX.XX): icmp_seq=2 ttl=64 time=0.007 ms
    [meusite.com ~]# ping 200.XXX.XXX.XX
    PING 200.XXX.XXX.XX (200.XXX.XXX.XX) 56(84) bytes of data.
    64 bytes from 200.XXX.XXX.XX: icmp_seq=1 ttl=64 time=0.019 ms
    64 bytes from 200.XXX.XXX.XX: icmp_seq=2 ttl=64 time=0.006 ms
    [meusite.com ~]# dig meusite.com
    ; <<>> DiG 9.3.4-P1 <<>> meusite.com
    ;; global options: printcmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 55354
    ;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
    ;; QUESTION SECTION:
    ;meusite.com. IN A
    ;; ANSWER SECTION:
    meusite.com. 86400 IN A 200.XXX.XXX.XX
    ;; AUTHORITY SECTION:
    meusite.com. 86400 IN NS ns1.meusite.com.
    meusite.com. 86400 IN NS ns2.meusite.com.
    ;; ADDITIONAL SECTION:
    ns1.meusite.com. 86400 IN A 200.XXX.XXX.XX
    ns2.meusite.com. 86400 IN A 200.XXX.XXX.XX
    ;; Query time: 0 msec
    ;; SERVER: 200.XXX.XXX.XX#53(200.XXX.XXX.XX)
    ;; WHEN: Tue Dec 2 20:04:24 2008
    ;; MSG SIZE rcvd: 113
    [meusite.com ~]# nslookup meusite.com
    Server: 200.XXX.XXX.XX
    Address: 200.XXX.XXX.XX#53
    Registro .br - Verificação DNS
    Nesse site coloquei o dominio e o ip do servidor e retornou o seguinte
    Domínio: meusite.com
    DNS: 200.XXX.XXX.XX
    Autoridade sobre o domínio
    Versão: 2008120104
    Tempo de resposta: 0.01 s
    Até ai tudo bem mas quando fui colocar dominio e dns ai venho o problema
    DNS: ns1.meusite.com
    DNS desconhecido
    Versão: 0
    Tempo de resposta: 0.00 s
    Não sei o que pode ter sido feito errado e estou um tempo já em cima disso,
    dai quando vou mudar o dns no site aparece uma messagem que não foi possivel, já tem 2 dias que configurei e não fiz nenhum progresso depois disso, mesmo por que fiz todos os teste com dig, host, hostname, ping, nslookup etc etc e tudo me retorna positivo e tudo como dizem nos sites que deveria que retornar não tenho mais ideias aonde possa estar o erro,
    fiz outros testes e tudo me retorna positivo, peço desculpas pelo tamanho do texto é que quis por o máximo de informações possiveis, uma listinha
    [meusite.com ~]# dig meusite.com @200.XXX.XXX.XX
    ;; ANSWER SECTION:
    [meusite.com ~]# hostname
    meusite.com
    [meusite.com ~]# host meusite.com
    meusite.com has address 200.XXX.XXX.XX
    meusite.com mail is handled by 10 meusite.com.br.
    Si alguem mais tiver uma sugestão, ficarei grato.
    Obrigado desde já.
    Agora que vi que tem uma parte especializada no assunto se for possivel algum moderador mover pra lá agradeço.
    Última edição por bunbot; 02-12-2008 às 22:38.
  1. como configurar BIND para se comportar como um roteador?
    Por pcfaria no fórum Sistemas Operacionais
    Respostas: 5
    Último Post: 02-05-2011, 20:28
  2. Bind Sendo Master e Slave para um Mesmo Domínio
    Por Bruno2010 no fórum Servidores de Rede
    Último Post: 17-08-2010, 09:17
  3. Bind (configurando mais de um domínio)
    Por andunno no fórum Servidores de Rede
    Último Post: 23-10-2006, 07:57
  4. Bind e Active Directory
    Por uriassousa no fórum Servidores de Rede
    Último Post: 06-08-2002, 15:40
  5. ONTENDO UM IP POR DHCP
    Último Post: 22-05-2002, 12:32
