    Padrão Saiu a Versao do Mikrotik 3.17 e v4.0 b1
    What's new in 3.17:
    *) added support for Intel 10Gb PCI Express driver;
    *) made Huawei E220 USB modem work again;
    *) added support for Novatel Wireless Ovation MC950D HSUPA;
    *) fixed PCQ fairness when pcq-total-limit is reached;
    *) fixed fetch tool to work when dst-path is not specified (broken in 3.16);
    *) fetch tool - added keep-result command line argument;
    *) allow to specify routing-table for ping, trace-route, and telnet;
    *) fixed an IPsec bug;
    *) fixed /ip firewall address-list;
    *) added propagate-ttl option for MPLS;
    *) fix very long wireless scan-list issues;
    *) fixed problem - sometimes PCQ could stop data pass-through if pcq-rate was set;
    *) fixed problem - L2TP could stop working when one of clients stopped responding
    at wrong time;
    *) fixed problem - reduced size of supout.rif files;
    *) graphing - support for 10 Gbit interfaces;
    *) routing-test - added support for multi-instance OSPF;
    *) user manager - fixed bug for PayPal payments with long parameter list;
    *) user manager - database load command supports external storage
    for temporary files;
    *) user manager - added support for all UTC time-zone offsets,
    including +5:30, +5:45, etc.;
    *) allow queues to have all traffic, not only ip (for example vpn)
    *) improved ipv6 sniffing
    *) improve torch and sniffer behavior under high load
    *) improved queue statistics
    Known issues:
    *) on some SMP x86 boxes clocks are not right, time runs very fast on them, as a result
    queues & wireless-test nstreme does not work;
    What's new in 4.0beta1:
    *) added support for MetaROUTERs;
    *) all test packages are regular ones;
    *) console - can mix named and unnamed arguments, can use names for unnamed
    argument values. For example all of the following commands are
    accepted now:
    /ping 10.11.12.13 count=4
    /ping address=10.11.12.13 count=4
    /ping count=4 10.11.12.13
    Última edição por edielsonps; 05-12-2008 às 11:57.
    Citação Postado originalmente por thenet Ver Post
    a 3.7 é stable?
    a versao 3.17 esta stable.. mais ainda nao usei em produção so fiz alguns teste mais ja tem alguns bug. As novas versões estão vindo com mais bug do que correções.
    sempre uso a versao 3.13.
    e esta versao 4 é q porta foi lançado um outro tipo e Placa Router e ela vai usar a versao 4.
    Última edição por edielsonps; 06-12-2008 às 15:16.
    Thumbs down 3.17 estavel esta"bomba"
    Colegas,
    Estava usando a 2.9.51 e fiz a besteira de instalar e por pra testar a 3.17, mas pra minha surpresa não consegui fazer funcionar o controle de banda!
    P2P também está horrível, passa tudo que não passa nas anteriores.
    Mesmo marcando pacotes, dropando tudo os desgraçados ainda passam!!!
    O bit-torrent é um infeliz! Fiz de tudo e não teve jeito.
    Nem me atrevi a ir adiante e testar outras coisa, tipo Web-Proxy e talz...
    Cansei de perder cabelos, vou amanhã mesmo fazer o downgrade.
    Alguém sabe de alguma 3.x que esteja fazendo o controle de banda, web-proxy, etc e talz em ordem, filezinha?
    Se alguém conseguir fazer funcionar tudo em ordem na 3.17, por favor dê as dicas pra galera.
    Flw.
    Citação Postado originalmente por falcaobr Ver Post
    Colegas,
    Flw.
    Esse problema do P2P ocorre em todas as versões os únicos protocolos que ficam barrados são emule e Ares, limewire fuciona mesmo com drop all p2p no firewall eo Bitorrent para quem usa utorrent basta marcar Protocol Encryption =Forced. Solução para P2P e controle de conexão com o min possivel.
    PS: Meu CF com a versão 3.x esta jogado na gaveta. rsrsrs
    Colegas,
    Flw.
    to ainda na 3.10 sem me encomodar
