    Padrão ubuntu + squidguard...a cuca tá fervendo...
    Olá pesoal !!!
    Estou tentando implantar o squidguard no ubuntu server aqui mas após feitas as configurações o erro no log do squidgurad é esse aqui:
    2008-12-28 20:52:27 [5219] destblock good missing active content, set inactive
    2008-12-28 20:52:27 [5219] destblock local missing active content, set inactive
    2008-12-28 20:52:27 [5219] squidGuard 1.2.0 started (1230504747.355)
    2008-12-28 20:52:27 [5219] db update done
    2008-12-28 20:52:27 [5219] squidGuard stopped (1230504747.356)
    Alguém pode me dar uma luz? Estou apanhando mais que cachorro doido (rssssssssss)
    reconfigurei tudo e agora o erro é esse aqui:
    2008-12-28 22:05:48 [4434] init domainlist /var/lib/squidguard/db/blacklists/drugs/domains
    2008-12-28 22:05:48 [4434] create new dbfile /var/lib/squidguard/db/blacklists/drugs/domains.db
    2008-12-28 22:05:48 [4434] init urllist /var/lib/squidguard/db/blacklists/drugs/urls
    2008-12-28 22:05:48 [4434] create new dbfile /var/lib/squidguard/db/blacklists/drugs/urls.db
    2008-12-28 22:05:48 [4434] init domainlist /var/lib/squidguard/db/blacklists/aggressive/domains
    2008-12-28 22:05:48 [4434] create new dbfile /var/lib/squidguard/db/blacklists/aggressive/domains.db
    2008-12-28 22:05:48 [4434] init urllist /var/lib/squidguard/db/blacklists/aggressive/urls
    2008-12-28 22:05:48 [4434] create new dbfile /var/lib/squidguard/db/blacklists/aggressive/urls.db
    2008-12-28 22:05:48 [4434] init domainlist /var/lib/squidguard/db/blacklists/porn/domains
    2008-12-28 22:06:02 [4434] create new dbfile /var/lib/squidguard/db/blacklists/porn/domains.db
    2008-12-28 22:06:02 [4434] init urllist /var/lib/squidguard/db/blacklists/porn/urls
    2008-12-28 22:06:03 [4434] create new dbfile /var/lib/squidguard/db/blacklists/porn/urls.db
    2008-12-28 22:06:03 [4434] init domainlist /var/lib/squidguard/db/blacklists/spyware/domains
    2008-12-28 22:06:03 [4434] create new dbfile /var/lib/squidguard/db/blacklists/spyware/domains.db
    2008-12-28 22:06:03 [4434] init urllist /var/lib/squidguard/db/blacklists/spyware/urls
    2008-12-28 22:06:03 [4434] create new dbfile /var/lib/squidguard/db/blacklists/spyware/urls.db
    2008-12-28 22:06:03 [4434] init domainlist /var/lib/squidguard/db/blacklists/violence/domains
    2008-12-28 22:06:03 [4434] create new dbfile /var/lib/squidguard/db/blacklists/violence/domains.db
    2008-12-28 22:06:03 [4434] init urllist /var/lib/squidguard/db/blacklists/violence/urls
    2008-12-28 22:06:03 [4434] create new dbfile /var/lib/squidguard/db/blacklists/violence/urls.db
    2008-12-28 22:06:03 [4434] squidGuard 1.2.0 started (1230509148.535)
    2008-12-28 22:06:03 [4434] db update done
    2008-12-28 22:06:03 [4434] squidGuard stopped (1230509163.334)
    Amigo,
    Verifica as permissões dos arquivos do squidguard (/var/lib/squidguard), tem que estar com o mesmo usuário que o processo roda, no debian é proxy.proxy:
    [[email protected] squidguard]# ls -l
    total 8
    drwxrws--- 2 proxy proxy 4096 2007-02-03 04:50 db
    Sds,
    Olá!
    No ubuntu é proxy: proxy, mas já consegui resolver e olha só o que era:
    estou usando o squid 3, quando execulto a regra (squid -R -C all) ele faz os log's na pasta squid, mas quando reinicio o squid, os log's são feitos no mesmo arquivo do squid log, mesmo a regra mandando ele fazer em outro local, e vendo os log's do squid guard no local do log do squid3 a inicialização do squidguard está normal, ou seja:
    Após a regras squid -R -C all é necessário reiniciar o servidor para que o squid e o squidguard rodem juntos de forma sincronizada, e os logs de inicialização dos dois estão na pasta .../squid3
    Ví isso em um forum dos gringos...mas vlw a força.
    Última edição por Roberto21; 29-12-2008 às 15:27.
