- Saiu a versão 3.18 do MK
Lançada a versão 3.18 do MK (stable)
What's new in 3.18:
*) IPv6 address auto-configuration: added recursive DNS server option;
*) fixed problem - sometimes firewall did not work after reboot on RB1xx;
*) do not send IPv6 packets over PPTP, L2TP or PPPoE - could confuse some
servers or clients;
*) allow queues to have all traffic, not only ip (for example vpn);
*) added ability to specify dns name in bandwidth test in WinBox;
*) fixed problem - sometimes RB1xx (and RB4xx) could not start up or startup was very long;
*) improved ipv6 sniffing;
*) improve torch and sniffer behavior under high load;
*) improved queue statistics;
*) fix xen make-routeros-image command;
*) fix potential wireless crash under load when negotiating encryption;
*) fix several MPLS issues in mpls-test;
*) fixed support for Novatel Wireless Ovation MC950D HSUPA;
*) fixed some bugs in routing-test OSPF;
*) added support for D-Link DUB-E100 USB Ethernet adapter;
*) fixed user-manager database rebuild command to succeed in case of
malformed database disk image;
*) sms - added descriptions for error codes;
*) sms - added automatic 'smsc' (service centre address) value detection,
to work around first time error when sending SMS without specifying
an 'smsc' value;
*) fixed - during uptime 4:20 .. 5:00 interface traffic (byte and packet
count) was being reported 100 times larger than the actual value;
*) provide L2TP server address in Called-Station-Id when doing authentication over RADIUS;
*) added support for Sierra Wireless MC8790;
*) recalibrated noise floor adjustment for R5H;
*) updated drivers & kernel - fixed fast clock issue on x86;
Última edição por Magal; 09-01-2009 às 15:13.
