  1. Posta o que saiu no comando configure. (A saída de texto, ou mesmo um config.log)
  2. Citação Postado originalmente por osmano807 Ver Post
    descompactei, entrei na pasta do ipaudit
    ./configure
    quando dou o comando make ou make install
    nenhum alvo indicado e nenhum arquivo make encontrado
  3. Acho que me expressei errado, é assim:
    ./configure
    checking for alguma coisa ... no
    checking for outra coisa ... sim
    É isso que quero que poste
  4. Citação Postado originalmente por osmano807 Ver Post
    ./configure
    [root@Firewall-Lauro compile]# ./configure
    Configuring for ipaudit-web...
    checking for a BSD-compatible install... /usr/bin/install -c
    checking for gcc... gcc
    checking for C compiler default output... a.out
    checking whether the C compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ANSI C... none needed
    checking for gmake... gmake
    checking build system type... i686-pc-linux-gnu
    checking host system type... i686-pc-linux-gnu
    checking whether the ipaudit user exists... yes, you win!
    checking whether the ipaudit group exists... you're still a winner!
    checking for the ipaudit home directory... /home/ipaudit
    checking if /home/ipaudit exists and is a directory... yes
    checking for id... /usr/bin/id
    checking for perl... /usr/bin/perl
    checking if /usr/bin/perl is version 5.004 or greater... yes
    checking for gnuplot... no
    configure: WARNING: *** GNUPLOT was not found, defaulting to /usr/bin/gnuplot
    checking for zcat... /bin/zcat
    checking for zgrep... /usr/bin/zgrep
    checking for gzip... /bin/gzip
    checking for tar... /bin/tar
    checking for gawk... gawk
    checking for gawk... /bin/gawk
    checking for the Time::ParseDate perl module... no
    configure: WARNING: *** Time::ParseDate was not found (Recommended)
    checking for gethostent in -lnsl... yes
    checking for getprotobyname in -lsocket... no
    checking for connect in -linet... no
    checking for pcap_datalink in -lpcap... no
    *** Fatal: libpcap library was not found!
    *** This library can be found at TCPDUMP/LIBPCAP public repository.
    *** If libpcap is installed, but wasn't found, try
    *** using the --with-pcap* options.
  5. Simples, instala TCPDUMP/LIBPCAP ,o módulo Time::ParseDate do perl e pode também instalar o gnuplot.
    Link da TCPDUMP/LIBPCAP
    É só instalar.
    O módulo perl instala assim (se me lembro bem):
    Código :
    perl -MCPAN -e shell
    install Time::ParseDate
  1. Instalação do Ipaudit
    Por emerson2703 no fórum Servidores de Rede
    Último Post: 04-04-2009, 08:51
  2. Configuração do monitoramento com IPaudit
    Último Post: 13-02-2009, 15:04
