    Dec 2000
    Boston
    Padrão testando ciscobox
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1/128 Scope:Host
    UP LOOPBACK RUNNING MTU:16436 Metric:1
    RX packets:881281481 errors:0 dropped:0 overruns:0 frame:0
    TX packets:881281481 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:2241330615899 (2.0 TiB) TX bytes:2241330615899 (2.0 TiB)
    Serial0/0 is administratively down, line protocol is down
    Internet protocol processing disabled
    Flow export v5 is enabled for main cache
    Exporting flows to xxx.xxx.xxx.xxx (xxxx)
    Exporting using source interface FastEthernet1/1/0
    Version 5 flow records, origin-as
    44026762040 flows exported in 3134225585 udp datagrams
    107348 flows failed due to lack of export packet
    30633 export packets were sent up to process level
    0 export packets were dropped due to no fib
    1382978 export packets were dropped due to adjacency issues
    0 export packets were dropped due to fragmentation failures
    0 export packets were dropped due to encapsulation fixup failures
