  1. meu squid.conf
    http_port 3128 transparent
    visible_hostname freedom
    cache_mem 64 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 2048 16 256
    refresh_pattern . 15 20% 2280
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 21 80 443 563 70 210 280 488 59 777 901 1025-65535
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    acl redelocal src 192.168.0.0/24
    http_access allow localhost
    http_access allow redelocal
    http_access deny all
    mensagem de erro...
    Root@Freedom:/etc/squid# tail -f /var/log/messages /var/log/squid/access.log
    ==> /var/log/messages <==
    Feb 18 17:39:31 Freedom pulseaudio[4933]: main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operação não permitida
    Feb 18 17:39:31 Freedom pulseaudio[4933]: main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operação não permitida
    Feb 18 17:47:21 Freedom kernel: [ 535.560103] eth1: link down
    Feb 18 17:47:33 Freedom kernel: [ 548.219592] eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
    Feb 18 17:49:25 Freedom squid[4534]: Squid Parent: child process 4536 exited with status 0
    Feb 18 17:49:27 Freedom squid[5742]: Squid Parent: child process 5745 started
    Feb 18 17:55:58 Freedom squid[5742]: Squid Parent: child process 5745 exited with status 0
    Feb 18 17:56:28 Freedom squid[6175]: Squid Parent: child process 6178 started
    Feb 18 18:02:35 Freedom squid[6175]: Squid Parent: child process 6178 exited with status 0
    Feb 18 18:02:58 Freedom squid[6562]: Squid Parent: child process 6565 started
    ==> /var/log/squid/access.log <==
    alguém poderia me dizer onde está o meu erro?
    por favor?
    o sqid não funciona
  2. Qual o seu SO? Está paracendo que o squid não está se dando bem com seu kernel.
  3. bem.. aparentemente seu squid "morre" logo após partir; vamos tentar saber o por que:
    (como root):
    #squid -Dd 3
    isso fará com que todas as mensagems (debug) sejam visiveis no console, com sorte, saberemos o que é
    Última edição por irado; 18-02-2009 às 20:36.
  4. Citação Postado originalmente por osmano807 Ver Post
    Eu uso Ubuntu
  5. Citação Postado originalmente por irado Ver Post
    (como root):
    #squid -Dd 3
    a resposta foi:
    root@Freedom:/home/servidorx# squid -Dd 3
    2009/02/19 16:55:30| Squid is already running! Process ID 6565
  1. Menssagem de erro!!
    Por Curioso no fórum Redes
    Respostas: 6
    Último Post: 03-10-2005, 07:17
  2. Mensagens de erro Squid
    Por TheHawk no fórum Servidores de Rede
    Respostas: 18
    Último Post: 21-05-2005, 15:24
  3. Alterar Mensagem de Erro "Squid"
    Por rfm no fórum Servidores de Rede
    Último Post: 21-02-2005, 12:15
  4. Menssagem de erro no qmail
    Último Post: 03-02-2005, 20:41
  5. Mensagem de Erro Squid
    Por roller no fórum Servidores de Rede
    Último Post: 16-11-2004, 14:55
