    Padrão Calculo para POE (english)
    Apesar de estar em ingles, este material sem duvid ajuda.
    Alguem se habilita a traduzir ai vai!
    The Main Problem
    The problem with POE is voltage loss in thecable. CAT5 conductors were never designed to carry significantcurrent, and are very thin. Consequently, the resistance of (say) a 20mPOE cable is significant; 1.8 ohms per conductor to be precise. As wepass the current necessary to power the AP though such a cable, thereis an associated voltage loss. And if the voltage at the AP end of thecable falls too low, the AP does not work at all, or performs at lowefficency.One common symptom of a poorly engineered POE cable is:
    • AP at the end of a POE cable appears to work fine when idle (i.e. little or no wireless traffic)
    • AP continually reboots as soon as the AP starts a high-speedfile transfer, where the file transfer data is being sent from the APto a 'client'.
    The reason: As the AP starts transmitting, itdraws more current over the POE cable. That means a bigger voltagedrop, and the voltage at the AP is no longer sufficient. So, itcrashes, reboots, and starts over.An Example
    It all comes back to that basic equation known as Ohm's Law, which states:
    (Voltage Drop in cable) = (Cable resistance) x (Current)
    or
    V = I x RLets say we have the following:
    • 20m POE cable. The round-trip resistance totals 1.8 ohms.
    • An AP that:
      • draws 200 mA (idle)
      • draws 500 mA (transmitting full speed)
      • requires 5.0V (+/- 0.5V) for proper operation
      • comes with a 5.0V regulated power supply
    So, we can calculate the voltage loss in the cable as follows:
    V = I x R
    Idle: V = 0.200 x 1.8 = 0.36
    Transmitting: V = 0.500 x 1.8 = 0.90
    That means the voltage at the AP is:
    Idle: 5.0 - 0.36 = 4.63 V (OK - as it above 4.5V)
    Transmitting: 5.0 - 0.90 = 4.10 V (Not OK - as it is below 4.5V)
    Engineering Your Own POE Cable
    You need to do the following:
    • Operate your AP as normal (i.e. no POE cable)in such a way that it is transmitting full speed. Typically you willsetup a simple wireless network (AP and Client), connecting two PCswith high speed ethernet interfaces (NICs), and start a long filetransfer using File Transfer Protocol (ftp) or similar.
    • Measure these values:
      • DC Voltage at the AP (Va)
      • DC Current into the AP (Ia)
    • Note the required AP voltage (Vr). This is often written on the AP, or in the manual.
    • Calculate the maximum length of CAT5 POE cable using this equation:
      Max Length = (Va - Vr) / (Ia x 0.094). [Note: 0.094 is the resistance per meter of CAT5e cable]
    An example:
    Vr = 12 Volts (written on AP)
    Va = 13 Volts (measured with AP transmitting)
    Ia = 400 mA (measured with AP transmitting)
    Max Cable Length = (13 - 12)/(0.400 x 0.094) = 26 meters.Where does the 0.094 ohms/m come from?
    CAT5e has a maximum DC resistance specification of 0.0938/m. (See this link.) We wire the 4 unused conductors in a POE cable like this:
    where each pair of wires is shorted at each end (ie each pair is wired in parallel). So considering a 1m length of cable:
    • Resistance of one conductor = 0.094 ohms
    • Resistance of two conductors wired in parallel = (0.094/2) = 0.047 ohms
    • Round Trip Resistance for both conductor pairs = (2 x 0.047) = 0.094 ohms
    Thats All folks.
    Lightbulb Tradução
    O PROBLEMA PRINCIPAL
    O problema com POE é a perda de vontagem do cabo. Cabos CAT5 não foram desenvolvidos para levar uma corrente significante, e também são muito finos. Consequentemente, a resistentência para (digamos) 20 metros de POE é signigicante; 1.8 ohms por condutor para ser preciso. Quando passamos a corrente necessária para ligar um AP através do cabo, há uma perda associada de voltagem. E se a voltagem que é levada até o fim do cabo para alimentar o AP cair muito, o AP não funciona, ou atua com baixa eficiência. Um sintoma comum de um POE mal planejado é:
    * O AP ligado no final do cabo parece funcionar quando está sem ser usado/acessado (pouca ou nenhuma transmissão wireless)
    * O AP reinicia continuamente quando lhe é requisitado alta velocidade e tamanho de arquivos, onde o arquivo está sendo transferido do AP para um "cliente"
    A razão: Quando o AP começa a transmissão, ele drena mais corrente do POE. Isso mostra uma grande perda de voltagem, e a voltagem no AP não é mais suficiente. Então, trava, reinicia, e inicia denovo. (Um exemplo)
    Tudo volta à equação conhecida lei de Ohm, que define: (Queda de voltagem no cabo) = (Resitência do cabo) x (Corrente)
    ou
    V - I x R Vamos dizer que temos o seguinte:
    *20 metros de cabo POE. A resitência (ida e volta) total de 1.8 ohms
    * Um AP que:
    -drena 200mA (sem ser usado)
    -drena 500mA (pleno funcionament/uso)
    -requer 5.0V (+/- 0.5v) para funcionamento normal
    -vem com uma fonte reguladora de 5.0V
    Então, podemos calcular a queda de voltagem no cabo como a seguir:
    V = I x R
    Sem transmissões: V = 0.200 x 1.8 = 0.36
    Transmitindo: V = 0.500 x 1.8 = 0.90
    Isso siginifica que a voltagem do AP é:
    Sem transmissões: 5.0 - 0.36 = 4.63V (Está OK - acima requer 4.5V)
    Transmitindo: 5.0 - 0.90 = 4.10 V (Não OK - acima requer 4.5V)
    Planejando seu próprio POE:
    Você precisará:
    * Operar seu AP normalmente (ex: sem POE) de uma forma que esteja trabalhando plenamente.
    Tipicamente, você irá configurar uma rede sem fio simples (AP e Cliente), conectando dois PCs com interfaces de rede de alta velocidade(NICs), e começar uma longa tranferência de arquivos usando FTP ou similar.
    * Meça esses valores:
    -Voltagem DC no AP (Va)
    -Corrente DC no AP (Ia)
    * Note a voltagem requerida pelo AP (Vr). Geralmente está escrito no AP ou no manual.
    * Calcule o tamanho máximo do cabo(CAT5) POE usando essa equação:
    - Tamanho máximo = (Va - Vr) / (Ia x 0.094). [Nota:0.094 é a resistência por metro de uma cabo CAT5e]
    Um exemplo:
    Vr = 12 Volts (escrito no AP)
    Va = 13 Volts (Medido com o AP em pleno funcionamento)
    Ia = 400 mA (Medido com o AP em pleno funcionamento)
    Tamanho máximo cabo = (13 -12) / (0.400 x 0.094) = 26 Metros. De onde os 0.094 ohms/m vem?
    Cabos CAT5e tem uma resistência máxima específica de 0.0938/m (Clique no LINK ). Nós cabeamos os 4 condutores não usados com um cabo POE como esse:
    onde cada par de cabo é cabeada em paralelo em cada fim. Então, considerando 1 metro de cabo:
    * Resistência de um condutor = 0.094 ohms
    * Resistência de dois condutores cabeados em paralelo = (0.094/2) = 0.047 ohms
    * Resistência ida e volta de ambos pares = 2 x 0.047) = 0.094 ohms
    Isso é tudo pessoal.
    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    COMPLEMENTANDO:
    A diferença de potencial entre os terminais de um circuito é igual ao produto da resistência desse circuito pela intensidade da corrente elétrica que passa por tal circuito.
    Exemplo prático: Num circuito elétrico, uma corrente de 2 ampères ao passar por um resistor de 10 ohm, provoca uma diferença de potencial elétrico de 20 volts sobre esta resistência.
    Veja como fica a representação da lei de OHM atravéz de uma fórmula matemática:
    V = R . I
    CORRENTE:
    - A intensidade da corrente elétrica que percorre o circuito é igual à divisão da diferença de potencial entre os terminais desse circuito pela resistência que esse circuito apresenta à passagem da corrente elétrica.
    Exemplo prático: Num circuito, quando aplicamos uma diferença de potencial (tensão) de 20 volts sobre os terminais de uma resistência de 10 ohm, provoca uma corrente elétrica de 2 ampères.
    I = V / R
    RESISTÊNCIA:
    - A resistência que um circuito, apresenta a passagem da corrente elétrica é igual à divisão da diferença de potencial (tensão) entre os terminais desse circuito pela intensidade da corrente que por ele passa.
    Exemplo prático: Num circuito em que aplicamos uma diferença de potencial de 20 volt e medimos uma corrente elétrica de 2 ampère, obtemos uma resistência a passagem da corrente de 10 ohm.
    R = V / I
    POTÊNCIA:
    Existe ainda uma grandeza que é muito utilizada em eletrônica, não faz parte da lei de OHM mas está ligada diretamente a ela. É a potência elétrica.
    Saber qual a potência elétrica na dissipação de calor dos componentes eletrônicos e seus circuitos é de extrema importância para o bom funcionamento dos mesmos.
    A potencia elétrica produzida é medida em WATTS, sua unidade é o W e seu símbolo de grandeza é o P.
    Exemplo prático: Num circuito, onde aplicamos uma diferença de potencial de 20 volts e obtemos uma corrente elétrica de 2 ampères, produzimos uma potência elétrica de 40 watts. Teoricamente nosso circuito formado pela resistência de 10 ohm teria que suportar uma potência de 40 W.
    Veja como fica a representação atravéz de uma fórmula matemática:
    P = V . I
    A potência elétrica é igual ao produto da tensão pela intensidade de corrente que percore a resistência.
    Estas fórmula são utilizadas com frequência na elaboração de circuitos elétricos e eletrônicos, tenha ela sempre em mente.
    Traduzir é uma coisa, agora, realmente saber o que está sendo dito é outra Valew magal pela tradução da tradução hehe
    Então resumindo, até quantos metros pode-se usar um cabo para PoE sem perda??
    0 (zero).
    Sempre haverá perda, volta e meia eu pesquiso um meio de injetar 36v 4-10A e usar um circuito regulador em cara dispositivo a ser alimentado. Uma fonte alimentado vários dispositivos.
