  1. aqui eu uso fedora 10, rodando:
    squid (Version 3.0.stable13) como proxy/webcache
    dhcp (MACxIP)
    tenho o seguinte cenario, uma rede onde nao posso barrar nada (skype, msn, hotmail, acesso a web, etc).
    mas tenho que encontrar um meio de aumentar a seguranca do servidor ou/e ate mesmo dos usuarios (ataques).
    esse eh o firewall atual que estou usando:
    #Rede Interna= eth0
    #Internet= eth1
    ifup eth0
    ifup eth1
    service dhcpd restart
    service squid start
    echo "Iniciando Interfaces de Rede...............................[ OK ]"
    # # carregando modulos
    modprobe iptable_nat
    modprobe ip_conntrack_ftp
    modprobe ip_nat_ftp
    modprobe ipt_MASQUERADE
    modprobe ipt_MARK
    modprobe ipt_mark
    modprobe ipt_mac
    modprobe ipt_tos
    modprobe iptable_mangle
    # # limpando regras
    iptables -F
    iptables -X
    iptables -Z
    iptables -F INPUT
    iptables -F OUTPUT
    iptables -F FORWARD
    iptables -F -t nat
    iptables -X -t nat
    iptables -F -t mangle
    iptables -X -t mangle
    # # Determina a politica
    iptables -t filter -P INPUT ACCEPT
    iptables -t filter -P FORWARD ACCEPT
    iptables -t filter -P OUTPUT ACCEPT
    iptables -t nat -P PREROUTING ACCEPT
    iptables -t nat -P POSTROUTING ACCEPT
    iptables -t nat -P OUTPUT ACCEPT
    iptables -t mangle -P PREROUTING ACCEPT
    iptables -t mangle -P POSTROUTING ACCEPT
    iptables -t mangle -P OUTPUT ACCEPT
    iptables -t mangle -P INPUT ACCEPT
    iptables -t mangle -P FORWARD ACCEPT
    # # Aceita os pacotes que realmente devem entrar
    iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    # # Aceita todo o trafego vndo do loopback e indo para o loopback
    iptables -t filter -A INPUT -i lo -j ACCEPT
    # # Protecoes # # # #
    # 1> Protecao contra IP spoofing
    # 2> Protege contra synflood
    # 3> Protecao contra icmp Broadcasting
    # 4> Bloqueia tracerout
    # 5> Protecao contra Dos
    # 6> Protecao diversa contra portscanners, ping of death, ataque DOS, etc.
    echo 1 > /proc/sys/net/ipv4/conf/default/rp_filter
    echo "1" > /proc/sys/net/ipv4/tcp_syncookies
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
    iptables -A INPUT -p udp --dport 33435:33525 -j DROP
    iptables -A FORWARD -p tcp --syn -m limit --limit 1/s -j ACCEPT
    iptables -A INPUT -m state --state INVALID -j DROP
    # Outras protecoes
    # Impedimos que um atacante possa maliciosamente alterar alguma rota, e
    # Impossibilita que o atacante determine o "caminho" que o pacote vai percorrer (roteadores) ate seu destino
    echo 1 > /proc/sys/net/ipv4/icmp_ignore_bogus_error_responses
    echo 0 > /proc/sys/net/ipv4/conf/all/accept_redirects
    echo 0 > /proc/sys/net/ipv4/conf/all/accept_source_route
    # # Fim Protecoes # # # #
    # # Proxy Transpatent
    iptables -t nat -A PREROUTING -s 172.167.0.0/24 -p tcp -d ! 200.201.174.207 --dport 80 -j REDIRECT --to-port 3128
    iptables -t nat -A PREROUTING -i 172.167.0.0/24 -p udp -d ! 200.201.174.207 --dport 80 -j REDIRECT --to-port 3128
    # # Ativa roteamento no kernel
    iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
    echo 1 > /proc/sys/net/ipv4/conf/all/proxy_arp
    echo 1 > /proc/sys/net/ipv4/ip_dynaddr
    # #SSH
    iptables -A INPUT -p tcp --dport 2210 --syn -j ACCEPT
    # # Bandlimit
    bandlimit restart
    # # Fecha o resto
    #iptables -A INPUT -p tcp --syn -j DROP
    #iptables -A INPUT -j DROP
    #iptables -A FORWARD -j DROP
    se eu altero as politicas padrao, e adiciono algum drop, minha rede nao navega
    se no final eu fecho a resto, minha rede tbm nao navega.
    1 questao >mas afinal, o que posso fazer para incrementar esse firewall, de modo que nao barre nada na navegacao da rede interna, mas tenha um pouco de seguranca referente a ataques ou acesso nao autorizado externo?
    Segue meu squid
    http_port 192.168.70.1:3128 transparent
    icp_port 0
    htcp_port 0
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 256 MB
    cache_swap_low 80
    cache_swap_high 85
    maximum_object_size 64 MB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 128 KB
    ipcache_size 3072
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy heap LFUDA
    memory_replacement_policy heap GDSF
    cache_dir ufs /var/spool/squid/cache1 2048 16 64
    cache_dir ufs /var/spool/squid/cache2 2048 16 64
    cache_dir ufs /var/spool/squid/cache3 2048 16 64
    cache_dir ufs /var/spool/squid/cache4 2048 16 64
    cache_dir ufs /var/spool/squid/cache5 2048 16 64
    cache_log /var/log/squid/cache.log
    cache_store_log none
    dns_nameservers 201.10.128.2
    dns_nameservers 201.10.120.3
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    auth_param basic casesensitive off
    refresh_pattern (cgi-bin|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    quick_abort_min 0 KB
    quick_abort_max 0 KB
    quick_abort_pct 100
    negative_ttl 3 minutes
    positive_dns_ttl 5 minutes
    half_closed_clients off
    acl BADPORTS port 7 9 11 19 22 23 25 53 110 119 513 514 3128 8080
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 563 # https
    acl CONNECT method CONNECT
    # ---- Cache do Windows Update ----
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern msgruser.dlservice.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    ##nao esquecer de trocar a faixa de ip pela da sua rede
    acl rede src 192.168.70.0/255.255.255.0
    http_access allow localhost
    http_access allow rede
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny BADPORTS
    http_access deny all
    #icp_access allow rede
    cache_effective_user squid
    cache_effective_group squid
    visible_hostname andrio.jasper
    memory_pools off
    forwarded_for off
    strip_query_terms off
    coredump_dir none
    detect_broken_pconn on
    pipeline_prefetch on
    2 questao >nesse script, teria algo que poderia mudar?
    3 questao> outra coisa que pensei em implementar na rede, seria vlan para cada usuario, mas nao sei como faco isso, alguem ai poderia me ajudar?
  2. ao que diz respeito a segurança (ataques )
    voce pode instalar o snort
    a respeito da vlan...
    so se a sua estrutura de rede for grande mesmo...
    e acho que nem seria por motivos de segurança e sim desempenho.
    por favor, me corrijam se eu estiver errado.
    boa sorte...
  3. Tu usa criptografia?
    Pensa numa criptografia mas consistente como WPA2 + radius.
  4. IMHO, deixar as politicas todas como ACCEPT é pedir pra ter problemas. Eu normalmente deixo as politicas como DROP e depois faço ACCEPT apenas para as portas/serviços que realmente serão utilizadas.
    Isso (naturalmente) implica em que vc terá que procurar saber TODAS as portas/serviços fluindo na sua rede.
    bom divertimento
  5. se eu dou drop nas politicas la em cima, minha rede nao navega...
    se eu dou drop na ultima regra, minha rede nao navega...
    o que eu precisaria, eh uma regra que nao barre nada na rede, mas dificulta o acesso externo/nao autorizado, ataques e/ou ate mesmo trojans.
    o q poderia mudar nesse script iptables??
    poderia me ajudar?
    referente a vlan, a rede abrange 90 usuarios.
    queria saber como fazer a vlan para cada usuario...
    com a vlan, alem da questao de desempenho, tbm afetaria a seguranca dos usuarios (propriamente dizendo). ja que um usuario nao iria receber pacote de outro usuario (virus, etc).
    referente ao squid, o q acharam do config?
    Última edição por AndrioPJ; 09-03-2009 às 09:20.
  1. Ajuda com script de firewall no fedora
    Por pearljam no fórum Servidores de Rede
    Último Post: 12-09-2007, 08:45
  2. Mquinas da rede sem internet mas com windowsUpdate
    Por flep no fórum Servidores de Rede
    Último Post: 24-02-2006, 09:45
  3. Ajuda com script (bash)
    Por sarna no fórum Linguagens de Programação
    Último Post: 08-03-2005, 21:42
  4. Ajuda com script para travar programa
    Por gamefe no fórum Linguagens de Programação
    Último Post: 10-02-2005, 16:13
  5. ajuda com script
    Por dboom no fórum Servidores de Rede
    Último Post: 01-02-2004, 22:13
