    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão MK 3.22 nova versão
    Saiu a versão 3.22 do MK.
    Obs: Pularam da 3.20 para a 3.22, a 3.21 não ficou disponível para download!!
    MK newsletter 16
    Link para Downloads:http://www.mikrotik.com/download.html
    What's new in 3.22:
    *) added advanced switch features for RB450G;
    *) added support for MetaROUTER on RB450G;
    *) added support for adding physical interfaces to Metarouters;
    *) added set-bgp-prepend-path action to routing filters;
    *) added WinBox OSPFv3 support to routing-test package;
    *) added WinBox IPv6 routes support to routing-test package;
    *) console - added 'hide-sensitive' option to the export command;
    *) user manager - fixed customer remove interface bug;
    *) fixed Cisco BGP VPLS autodiscovery in mpls-test package;
    *) fixed LDP to not disconnect on unknown capabilities of remote
    peer (should help establish LDP session with Junos);
    *) fixed ethernet port name reordering on RB493;
    *) bonding mode balance-alb now works on RB1xx, RB4xx, RB616, RB600, RB750,
    RB1000;
    *) added '/interface ethernet print stats' command for RB450G and RB750;
    *) fixed CSPF in routing-test to properly interpret link bandwidth;
    *) added support for C-motech CNU-680 CDMA 1x EV-DO 450Mhz USB Modem;
    What's new in 3.21:
    *) backported MetaROUTER support for RB4xx from v4;
    *) added WinBox MPLS & VPLS support mpls-test package;
    *) added WinBox BGP support to routing-test package;
    *) api - added query support for 'print' command;
    *) added support for bsd-syslog;
    *) added TFTP server;
    *) added authorization and TLS support to email tool;
    *) added pppoe-scanner;
    *) added tftp protocol support to fetch tool;
    *) fixed ipsec policy priority to work as documented;
    *) fixed BGP route selection in routing package;
    *) allow to use IPsec aggressive mode with pre-shared keys;
    *) fixed some problems in mesh protocol;
    *) fixed https proxying with parent proxy;
    *) fixed Prism shared IRQ issue;
    *) fixed multiple MPLS/VPLS bugs in mpls-test;
    *) fixed boot problems on some RB1000s;
    *) added /interface mesh traceroute command;
    *) fixed web proxy source address selection;
    *) fixed pcq queue - pcq sometimes could get through more traffic
    than specified in max-limit;
    Última edição por Magal; 16-03-2009 às 12:05.
    cara só uma duvida, para migrar de uma versao 2.9 para essa é preciso refazer as configs ou pode restaurar um backup em cima dela??? vlww
    Dá até pra migrar tranquilo ... mas vc vai ter que re-fazer as config do web-proxy !
    Citação Postado originalmente por Magal Ver Post
    MK newsletter 16
    What's new in 3.22:
    RB1000;
    What's new in 3.21:
    Essa versão tem muitas coisas interessantes, entre elas o server tftp e as novas configurações para a ferramenta de email (parece que agora envia email, com autenticação)... Parece que foi resolvido o tal problema das queue que estoravam o limite... Agora vamos esperar para ver quantos colocam em produção para indentificar novos erros. rsss
    Padrão Novas opções incluidas na versão 3.22!
    Opa, o pessoal da MK esta trabalhando firme para corrigir os bugs da versão 3x e tmb esta incluindo novidades. como podemos ver no changelog da nova versão, foi incluida a opção de enviar um backup por email mas com autenticação!!! isso é mto bom, já q a maioria utiliza caixas de emails de terceiros e n tem como contruir um servidor propio de emails sem autenticação para q o mk envie o backup na hora e dias desejados. o pessoal da MK esta ficando de parabénz, sempre melhorando este maravilhoso sistema q é o Mikrotik.
    Mar 2007
    Rio de Janeiro
    Copia o pacote .npk para o MK e da um boot.
    Se alguem testar essa versão em PC-AP e ficar bom, fale ai pra nois!
    Mar 2007
    Rio de Janeiro
    Vou testar hoje mesmo para ver se corrigiu o problema no controle de banda da 3.20!!
    vlwww magal....outra coisa....sera que essa versao veio com alguma coisa pra melhorar o filtro dos P2P que usam criptografia?
    Padrão Como atualizar
    amigos descupa pela perguntar so novo em MK eu tenho o Pc-MK com a versao 3.20 como eu fasso pra atualizar pra 3.22 fico muito grato quem pode me ajudar ..
    Bom, eu coloquei em produção logo, em um PC-AP... Pelomenos levantou, rs... Notei queda no uso do link, pode ser clientes ainda não conectados, irei avaliar.
    Citação Postado originalmente por cooperrj Ver Post
    Também farei testes " extreme" por aqui e postos resultados..
    Mar 2007
    Rio de Janeiro
    Já tem 12 horas rodando e o controle de banda está ok.
    estou testando tambem a versão 3.22 e até agora esta tudo ok
    Mar 2007
    Rio de Janeiro
    Espero que essa versão seja boa, porque a 3.20 foi só dor de cabeça.
    Última edição por Magal; 19-03-2009 às 20:48.
    Pra mim esta rodando mais de 12hs e esta ok... Sem problemas...
    Jan 2004
    Capital do Triângulo
    hummmm.... vamos pensar... de novo....
    se uma conexão é criptografada significa que eu (o sistema ou alguma aplicação do mesmo) não consigo saber o que contém seus pacotes, CORRETO??? ou será que não é isso???
    pois bem, se eu não consigo saber do que se trata tal conexão (porque ela está criptografada) como é que posso fazer qualquer coisa a respeito da mesma???????? chutômetro???
    Jan 2004
    Citação Postado originalmente por djacesso Ver Post
    A questão não é ser novo... é ser preguiçoso... Deve ter uns 200 mil posts dizendo como se faz isso, mas você tem preguiça de procurar e prefere perguntar...
    é muito difícil fazer a atualização, depois de baixar do site internacional, envie para o menu FILES (arrastar e colar) e reinicie o sistema.
    Assino em baixo de tudo que o mestre sergio fala... =)
